Canopy Safety
Goto page 1, 2  Next
jaybannist(at)cs.com
PostPosted: Fri Oct 17, 2008 11:58 am    Post subject: Canopy Safety Reply with quote
As you may know, the canopy of the AMD 601XLi I was flying came open; flew up to about 50 degrees and the airplane became uncontrollable. As soon as I had recovered enough to get around, the very first thing I did was to install a safety cable to the canopy of my airplane, Lil Bruiser. I have attached drawing of what I installed. I made the cable just long enough, when pinned, that the canopy can be open a little for taxi on hot days. I am probably going to add a removable nylon strap that will be long enough to help pull the canopy down when seated. Let me know if you have any questions.
Jay in Dallas
Email message sent from CompuServe - visit us today at http://www.cs.com
CanopySafety.pdf
 Filename:  CanopySafety.pdf
 Filesize:  26.86 KB
 Downloaded:  571 Time(s)
Thruster87
PostPosted: Fri Oct 17, 2008 12:22 pm    Post subject: Re: Canopy Safety Reply with quote
Hi Jay,Have you ascertained as to why it opened ? or possible reasons ?as stated in a previous thread it seems the locking studs height may have been made a bit short thus not giving a positive lock [there are two clicks as the canopy locks, if it is too short it will only engage the first click and it may not stay locked ] Cheers T87
jmaynard
PostPosted: Fri Oct 17, 2008 12:37 pm    Post subject: Canopy Safety Reply with quote
That discussion does not apply to the aircraft Jay was flying. It, like
mine, has the new-style latch system as found on the 650.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
PostPosted: Fri Oct 17, 2008 1:13 pm    Post subject: Canopy Safety Reply with quote
Yes, I have ascertained why it came open. But that is beside the point.
As Jay Maynard pointed out, the latching system on the airplane I was flying is not like the CH 601XL latch.
Regardless of the latching system, I don't want a canopy to come open in flight, EVER AGAIN, for whatever reason, period. I don't doubt the integrity of either latching system; but neither one of them can absolutely overcome the carelessness or pilot error that too often occurs in aviation.
Jay in Dallas
(That is Jay Bannister)
bryanmmartin
PostPosted: Fri Oct 17, 2008 2:12 pm    Post subject: Canopy Safety Reply with quote
The accident airplane had the new canopy latching system currently
used on the CH650. This does not have the two stage latches of the old
system, it has two hooks connected to a torque tube that engage a stud
on each side of the canopy. With the old system, each side of the
canopy latched up independently of the other so that is was likely
that at least one side of the canopy would always fully latch when
closed and the unlatched side can be pulled closed with no danger of
unlatching the other side. I've had one side of my canopy come open in
flight but never both.
In my opinion, the new design needs some improvement. Because both
latch hooks are connected rigidly to the torque tube, if one is not
fully latched, neither will the other one be and, if one side does
latch and the other doesn't, attempting to latch the canopy in flight
will probably cause both sides to unlatch. (This is probably what
happened in this accident.) I think a slotted hole in the forward end
of the linkage (65-C-2-4) connecting the hook (65-C-1-1) to the torque
tube end, along with a spring connected to the bottom of the hook
pulling the hook towards the latched position would allow the hooks
enough free motion to latch up independently. This would also prevent
one side from unlatching if someone attempts to pull the other side
down to the latched position.
Cheers T87
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
Thruster87
PostPosted: Sat Oct 18, 2008 2:14 am    Post subject: Re: Canopy Safety Reply with quote
Jay in Dallas
That was a rather harsh reply as it may or could prevent a similar situation for someone else.The idea behind these forums is to discuss things in a healthy way and NOT SHOOT the Messenger as I was not aware the new canopy was in service already. Cheers T87
PostPosted: Sat Oct 18, 2008 6:16 am    Post subject: Canopy Safety Reply with quote
T87, whoever you are,
I am sorry you took my reply as "harsh", and as intending to shoot the messenger. That was a long way from my intention.
My accident was a little over two months ago and I am still recovering from my injuries. The CFII who was with me is still in the hospital and will probably be there hospital another six weeks. Even then, he will probably not be able to walk. His medical bills will be well over a million dollars, and I'm doubtful that he will ever fly again. The airplane was destroyed. All because the canopy came open.
Is that sufficient reason for me to be emphatic?
I will say it again (for the benefit of ALL): I don't want a canopy to come open in flight, EVER AGAIN, for whatever reason, period.
Jay Bannister
jmaynard
PostPosted: Sat Oct 18, 2008 7:04 am    Post subject: Canopy Safety Reply with quote
I posted about it back in June when I took delivery of my airplane. Even so,
I understand that not everyone may know about it.
I'll cut Jay B a lot of slack. He took some fairly serious injuries in his
crash, and I can certainly understand his desire to help others avoid the
same fate. When commenting on others' misfortune, it's a good idea to avoid
sounding like you're criticizing something that doesn't apply.
Jay Maynard, K5ZC
Thruster87
PostPosted: Sat Oct 18, 2008 1:04 pm    Post subject: Re: Canopy Safety Reply with quote
I was not aware of this accident so I only took it on what was said in the reply.Obviously one would try to avoid criticizing other's misfortunes.In aviation it has always been crucial to find reasons for accidents and I was just asking a simple question so it seemed at the time.Anyhow hope Jay gets back to 100% ASAP Cheers T87 [the T stands for a Thruster Aircraft and the 87 is the year it was made]
lwhitlow
PostPosted: Sat Oct 18, 2008 7:19 pm    Post subject: Re: Canopy Safety Reply with quote
Jay
I looked at your drawing and I'm a bit concerned.
It seems while your cable will prevent the canopy from opening in flight, it will also prevent rescuers from getting to you on the ground if you are incapacitated and unable to pull the pin.
Perhaps the pin could be moved to one side or the other and a punch in cap installed to allow someone from outside the aircraft to pull the pin and get you out if needed.
Glad to hear your getting better and my best wishes for your instructor as well
Larry Whitlow
Jay in Dallas
chris Sinfield
PostPosted: Sat Oct 18, 2008 7:31 pm    Post subject: Re: Canopy Safety Reply with quote
In Australia
we are recommending in the SAAA and the RAA are making it mandatory for putting in an extra safety latch or cable to all our Zodiac XL's with the older thinner Aero Plastics 80 thou canopy's. It appears that the older 2 stage locking mechanism is easy to not lock properly. This results in it only locking to the first stage and popping up just after take off.
It normally happens on the passenger side, as they don't like to slam the canopy , so lowering gently and not locking it fully.
Don't work , with the older thinner canopy if you have an accident and people need to get into the cabin to rescue you, the older thinner canopy would be easily broken by a fist, shoe or even yelling at it.. (well you would have to yell hard).
We can either have a cable system as Jan's one above or an extra lock on each side of the normal lock. If you upgrade to the newer canopy system you don't need to do this or get a Todd's Canopy as they are 120 thou.
I will try and attach some photos.
Chris.
Sydney
XL Jab3300
sliding lock
 Filesize:  32.56 KB
 Viewed:  691 Time(s)
PostPosted: Sat Oct 18, 2008 7:42 pm    Post subject: Canopy Safety Reply with quote
Larry,
I was concerned about that also. But as someone pointed out earlier, if rescuers get to the wreck and you can't get out, they are going to break the canopy bubble to get you out. The airplane is probably crunched anyway, so breaking the canopy bubble is no big deal. Even in my crash, the canopy was open, but the rescuers had to cut the instructor out of the fuselage with "Jaws of Life." I used the safety pin with a large ring, so I could get it out and release the canopy if I was able.
Jay in Dallas
brianrobertwood(at)gmail.
PostPosted: Sun Oct 19, 2008 5:01 am    Post subject: Canopy Safety Reply with quote
Here is an interesting video from Brazil on an improved latch for canopies
that hinge in the front. The video admits that they just adapted an idea
from another model, but it looks well executed. Just ignore the chatter in
Portuguese, the video is self explanatory.
http://www.youtube.com/watch?v=qSBkSyo__XY
Brian in Brazil
Usando o revolucionário cliente de e-mail do Opera:
http://www.opera.com/mail/
jmaynard
PostPosted: Sun Oct 19, 2008 6:05 am    Post subject: Canopy Safety Reply with quote
What does the canopy thickness have to do with the canopy latch? Not all of
the 80-thousadnths canopies have the old-style latch. Mine does not.
Jay Maynard, K5ZC
z601(at)anemicaardvark.co
PostPosted: Sun Oct 19, 2008 6:09 am    Post subject: Canopy Safety Reply with quote
I'm getting really confused in the flurry of postings about the latch. Are we
saying that the old latch design is the problem, or the new latch design?
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
PostPosted: Sun Oct 19, 2008 6:12 am    Post subject: Canopy Safety Reply with quote
Adding to what Jay M says, the canopy latch that failed for me was the newer style. So that alone doesn't "fix" the problem.
Jay in Dallas
PostPosted: Sun Oct 19, 2008 6:34 am    Post subject: Canopy Safety Reply with quote
Jim,
Neither latch is the problem. The problem is the people who do the latching.
The old style has independent latches on each side. They need to be pushed down until you hear two clicks. If there is only one click, due to mis-alignment in the installation or just not pushing hard enough, the latch is likely to come un-done. If the opposite latch has been properly latched, the canopy will not completely open. It can be re-latched independently from the opposite latch. If both latches are not properly latched, the canopy will probably open completely.
The new style latches are connected and operate together. The latches can be seen, so proper latching can be verified. However, if one side is not properly latched and comes un-done, it can not be re-latched withoug releasing the other latch. I can attest to that from personal experience!
In either case, a partially open canopy (even if it has the safety tether) should be left alone, the airplane landed and then the canopy properly latched. That is what the AMD POH says. However, it also says that the canopy will not rise more than about a foot. In my incident, the canopy rose to about 50 degrees and made the airplane uncontrollable in pitch.
Jay in Dallas
planecrazydld(at)yahoo.co
PostPosted: Sun Oct 19, 2008 8:52 am    Post subject: Canopy Safety Reply with quote
that is not chatter - it is usage of the most beautiful dialects of the most beautiful language in the world!
David L. Downey
Harleysville (SE) PA, USA
--- On Sun, 10/19/08, Brian Wood <brianrobertwood(at)gmail.com> wrote:
Subject: Canopy Safety
Date: Sunday, October 19, 2008, 8:59 AM
--> Zenith601-List message posted by: "Brian Wood"<brianrobertwood(at)gmail.com>Here is an interesting video from Brazil on an improved latch for canopies that hinge in the front. The video admits that they just adapted an idea from another model, but it looks
well executed. Just ignore the chatter in Portuguese, the video is self explanatory.http://www.youtube.com/watch?v=qSBkSyo__XYBrian in Brazil-- Usando o revolucionário cliente de e-mail d
___ahoo.com [quote][b]
ter_turn(at)yahoo.com
PostPosted: Sun Oct 19, 2008 11:27 am    Post subject: Canopy Safety Reply with quote
Oh, Jesus!!!
LOL
Terry Turnquist
601-XL Plans
David Downey <planecrazydld(at)yahoo.com> wrote:[quote] that is not chatter - it is usage of the most beautiful dialects of the most beautiful language in the world!
David L. Downey
[quote]From: Brian Wood [quote][b]
K Dilks
PostPosted: Mon Oct 20, 2008 3:36 am    Post subject: Re: Canopy Safety Reply with quote
My idea comes from one I saw on a Eurostar.
Fix a cord from the canopy bubble so you can pull it closed easily while sitting . second fit a pin on the end and mount bracket on the shelf behind to place pin in when closed . Leave 2-3 inches slack so if canopy is opened you can notice plus rescue folks can just cut it open . This way if doing a forced landing you can open the catch early , as per the doors on a plane to help getting out of a bent plane.
Sorry to hear about this accident. Hope both make full recovery.
Kev
Back home .................
Goto page 1, 2  Next
Page 1 of 2
