Dual throttle 601xl
rmacpunk(at)netzero.net
PostPosted: Tue Oct 14, 2008 3:41 pm    Post subject: Dual throttle 601xl Reply with quote
Has anyone come up with a smoother operating dual throttle linkage? With the curve downward on each throttle cable mine is not smooth. There must be a better way. Bob
psm(at)att.net
PostPosted: Tue Oct 14, 2008 4:02 pm    Post subject: Dual throttle 601xl Reply with quote
Hi Bob,
I didn't like the dual throttle in the kit, so I did a major redesign for my plane. I copied the torque tube and moved it inside the cockpit. It mounts with the arms hanging down to the bottom of the horizontal channel that runs between the firewall and instrument panel. It also mounts to brackets on both side skins. The arms are long enough that they hang down to the same level as the throttle on the engine. The throttle cable goes through the firewall at throttle height and makes its way to a new brass fitting that is only an inch long instead of the long one from the Jabiru USA kit.
I mounted the throttle knobs on the side of the cabin where my short arms can reach without leaning out of the seat. I also put the carb heat knob with the pilot's throttle knob.
All in, it was a huge change and took several weeks of effort. I do think it was worth it since the throttle is very smooth now from either the pilot or copilot side.
I can probably dig up some photos if you want them. I don't have any drawings. To build one just like mine you will need some 3/8 O.D. tubing and some flat stock to weld to it in three places. I reused the nylon bearings for the center mount location and made some new ones for the skin mount.
Good luck,
Paul
Xl getting close
At 04:39 PM 10/14/2008, you wrote:
[quote]Has anyone come up with a smoother operating dual throttle linkage? With the curve downward on each throttle cable mine is not smooth. There must be a better way. Bob[b]
vk3eka(at)bigpond.net.au
PostPosted: Tue Oct 14, 2008 4:11 pm    Post subject: Dual throttle 601xl Reply with quote
Paul,
I’d like to see some pictures. I am installing an O-200 but would appreciate some ideas.
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Paul Mulwitz
Sent: Wednesday, 15 October 2008 11:02 AM
Subject: Re: Dual throttle 601xl
Hi Bob,
Good luck,
Paul
Xl getting close
psm(at)att.net
PostPosted: Tue Oct 14, 2008 5:20 pm    Post subject: Dual throttle 601xl Reply with quote
OK Peter,
Here are some pictures:
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.0[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.1[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.2[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.3[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.4[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.5[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.6[/img]
[img]cid:7.1.0.9.0.20081014181123.04e34b58(at)att.net.7[/img]
At 05:10 PM 10/14/2008, you wrote:
Paul,
Cheers
Peter
Wonthaggi Australia
 Filesize:  29.47 KB
 Viewed:  659 Time(s)
 Filesize:  33.98 KB
 Viewed:  657 Time(s)
 Filesize:  25.6 KB
 Viewed:  654 Time(s)
 Filesize:  37.51 KB
 Viewed:  680 Time(s)
 Filesize:  53 KB
 Viewed:  643 Time(s)
 Filesize:  28.66 KB
 Viewed:  609 Time(s)
 Filesize:  30.87 KB
 Viewed:  679 Time(s)
 Filesize:  42.42 KB
 Viewed:  634 Time(s)
eldenej(at)yahoo.com
PostPosted: Tue Oct 14, 2008 6:15 pm    Post subject: Dual throttle 601xl Reply with quote
Paul,
I, too, would much like to see whatever pictures you may have. I am at the point of needing to install my duals for the Jabiru, and am not much impressed.
Elden J.
xl, 3300
--- On Wed, 10/15/08, Peter W Johnson <vk3eka(at)bigpond.net.au> wrote:
Subject: RE: Dual throttle 601xl
Date: Wednesday, October 15, 2008, 8:10 AM
Paul,
I¢d like to see some pictures. I am installing an O-200 but would appreciate some ideas.
Cheers
Peter
Wonthaggi Australia
Hi Bob,
Good luck,
Paul
Xl getting close
PostPosted: Tue Oct 14, 2008 9:12 pm    Post subject: Dual throttle 601xl Reply with quote
Paul,
Looks good.
Many thanks
Peter.
Sent: Wednesday, 15 October 2008 12:20 PM
OK Peter,
Paul,
Id like to see some pictures. I am installing an O-200 but would appreciate some ideas.
Cheers
Peter
Wonthaggi Australia
 Filesize:  29.47 KB
 Viewed:  638 Time(s)
 Filesize:  33.98 KB
 Viewed:  641 Time(s)
 Filesize:  25.6 KB
 Viewed:  607 Time(s)
 Filesize:  37.51 KB
 Viewed:  616 Time(s)
 Filesize:  53 KB
 Viewed:  607 Time(s)
 Filesize:  28.66 KB
 Viewed:  614 Time(s)
 Filesize:  30.87 KB
 Viewed:  593 Time(s)
 Filesize:  42.42 KB
 Viewed:  615 Time(s)
DaveG601XL
PostPosted: Wed Oct 15, 2008 5:08 am    Post subject: Re: Dual throttle 601xl Reply with quote
If I had to do it over again, I might do it like Paul did. I am flying now with the Jabiru FWF dual throttle system and it does work OK after a bunch of tweaks. Here are some lessons learned from my installation:
Make the throttle length from panel to firewall as straight as possible, i.e. as short as it will allow, to eliminate friction of any cable bends.
Without the forward upper skin in place, the panel and firewall flex around a lot, adding to some frustration when pushing/pulling the throttle during your assembly trails. Put some temporary bracing between them to stiffen it up.
Adding to the previous point, I added doublers to the panel and firewall where the throttle passes through to eliminate flexing there.
I angled the throttle-end adjuster down a little bit where it penetrates the firewall to reduce some of the bend where the wire exits.
I backed this same throttle-end adjuster as far rearward as I could to reduce the bend where the wire exits.
I opened up the nylon blocks to reduce friction between them and the cross rod.
I lubed the throttle cables with teflon spray lube where appropriate.
I used a drill to cone-out the throttle end adjusters both where one penetrates the firewall and well as the one that penetrates the upper firewall shelf. This gets rid of any sharp corners for the wire or cable to rub on. Be sure to get all debris out of the adjuster.
So far, after 39 flight hours, I have had no problems with the throttle system. It works relatively smoothly, but I will say that there is enough friction in the system that I rarely use the friction locks.
Good luck,
David Gallagher
Cincinnati, OH area
