grantr
Posted: Fri Sep 26, 2008 12:46 pm Post subject: Check your carb floats!! |
Since I am new to light sport flying I don't know if this is a direct result of using gas with ethanol or not.
I pulled my float bowls the other day and examined the floats and found one that was literally flaking apart! I took a file and scrubbed on it to remove the flaking outside plastic covering then i used my finger nail and the next thing I new my nail sunk into the foam core of the float. If I had not pulled the bowl it is possible that the flakes of the outer covering of the float could have stopped up the jets in my carbs. So that float is useless now. Luckily I had a spare on hand and have 3 more ordered.
These are bing 54 carbs
jim
Posted: Fri Sep 26, 2008 1:50 pm Post subject: Check your carb floats!! |
That's a scary thought!!! I hope it isn't related to the ethanol use, but
it could well be.
Why don't you cut your bad float into pieces and soak the pieces in
various test solutions: ethanol, isopropyl alcohol, and maybe some cheap
whiskey and see if the damage accelerates.
ordered.
http://forums.matronics.com/viewtopic.php?p 6369#206369
_________________ Jim
N. Idaho |
Posted: Fri Sep 26, 2008 2:16 pm Post subject: Check your carb floats!! |
but
Jim Dunn:
If it was caused by alcohol we'd all be falling out of the sky. I have been
burning 10% for a long time with no problems.
_________________ John Hauck
Titus, Alabama |
Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Fri Sep 26, 2008 5:16 pm Post subject: Check your carb floats!! |
I flew my 503 for 105 hrs. between Oct. '07 and May '08 using service
station purchased 87 octane ethanol-laced fuel probably 90% of the
time. I checked my float bowls regularly and never had any problems
with the floats disintegrating. They were the original floats that
came with engine which was first flown in '03.
Jimmy Young
FS II, Houston
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
jim
Posted: Fri Sep 26, 2008 8:27 pm Post subject: Check your carb floats!! |
That's a relief -- thanks.
So far I haven't used gasohol in my Kolb. I know of only one station in 2
states that sells it; fortunately it is only 5 miles away so I buy all my
aircraft fuel there.
Jim
Jimmy Young
FS II, Houston
N. Idaho |
JetPilot
Posted: Mon Sep 29, 2008 8:45 am Post subject: Re: Check your carb floats!! |
Grant R.
Thanks for the Warning The condition you described would surely have caused an engine failure sooner or later had you not caught it. I will inspect my floats before I fly again. I will also tell the other Rotax guys that I fly with your story, and advise them to check their floats also. It takes only a minute to check, and could prevent a disastrous result.
Kolb MK-III Xtra, 912-S |
ez(at)embarqmail.com Guest
Posted: Mon Sep 29, 2008 9:48 am Post subject: Check your carb floats!! |
Grant,
This float condition is most likely NOT from using ethanol, but rather
from using a carb gum cleaner on them. I never use carb gum cleaners
on plastic parts. It has been known to have the effect on plastic that
you describe.
Gene
On Sep 26, 2008, at 4:46 PM, grantr wrote:
JetPilot
Posted: Thu Oct 02, 2008 7:41 pm Post subject: Re: Check your carb floats!! |
GrantR,
I checked the carburetor floats on my Rotax 912-S as I said I would, and I have the beginning of the same condition you describe The " Paint " or whatever it is they use to coat the floats with is just starting to bubble and peel on ONE out of the four floats... There was no debris coming loose in the carburetor bowl YET, but it was well on its way. I could easily break off some pieces of this paint like material with my finger that had separated, and was well on its way to falling off by itself.
My floats are about 2 years old, and as far as I know have never been used with ethanol. I have also NEVER used carb cleaner, or starter fluid, or anything in these carbs... My bowls are always so clean when I take them off I could drink wine out of them I have no idea what caused this to happen, but I will be replacing all the floats in the engine as if one has begun this process of shedding its covering, the rest are probably not far behind ! Attached is a picture of the bad float, its a bit hard to see, but look around the edges of the float where the paint is starting to bubble up.
Thanks for the warning Grant, it probably saved me a nasty surprise !
| Float Covering, " Paint " like material bubbling and comming off the float :( |
214.55 KB |
616 Time(s) |
Posted: Fri Oct 03, 2008 5:52 am Post subject: Check your carb floats!! |
Mike, good thing you inspected. Looks like you guys have uncovered a
problem. There may have been
a bad production batch with no way to know who got the bad ones. As
far as ethanol goes, unless
you have been using only avgas you have been exposed to ethanol.
Nearly all auto gas has some
in it now. Around here there is no pump labeling either.
Ethanol is a very universal solvent when in contact with polymers.
Very similar to acetone with
regard to both water and mineral solvent mix capabilities.
There will be more problems showing up down the road with both
aircraft and autos.
BB
On 2, Oct 2008, at 11:41 PM, JetPilot wrote:
GrantR,
[Shocked] The " Paint " or whatever it is they use to coat the
bubble up.
http://forums.matronics.com/viewtopic.php?p 7212#207212
http://forums.matronics.com//files/float_400.jpg
Posted: Fri Oct 03, 2008 6:29 am Post subject: Check your carb floats!! |
More stuff:
Marvel-schebler has had a similar go-around with float materials, in
some cases
having owners change from original metal to plastic, back to metal
and then back
to "new improved" plastic. ( I would have stayed with the metal -
screw the AD)
The current favored plastic is delrin or POM (polyoxymethylene)
which is a resin used as a binder in solid structures with either a
glass or teflon fiber filler.
The Bing floats look like foam with an epoxy cover. I would inspect
them frequently.
No plastic in my old solex
BB
Dennis.Kirby(at)kirtland. Guest
Posted: Fri Oct 03, 2008 11:02 am Post subject: Check your carb floats!! |
"JetPilot" wrote: << GrantR, I checked the carburetor floats on my Rotax
you describe >>
Has anyone asked what Lockwood or Ronnie Smith think about this
condition?
As those guys are Rotax experts, maybe they've seen this before and can
offer an explanation or solution.
Dennis Kirby
Mark-3, 912
New Mexico
grantr
Posted: Fri Oct 03, 2008 11:14 am Post subject: Re: Check your carb floats!! |
Mike,
Thats what mine looked like. One was in much worse shape with large bubbles. They do seem to like to bubble around the edges.
Possums
Posted: Tue Oct 07, 2008 6:16 pm Post subject: Check your carb floats!! |
I checked my 10 year old floats - found nothing wrong.... just so we
get the other side, it's easy to check.
At 04:46 PM 9/26/2008, you wrote:
_________________ Possum |
George Alexander
Posted: Fri Oct 10, 2008 6:19 pm Post subject: Re: Check your carb floats!! |
| grantr wrote: |
----SNIP----
After Grant's findings, pulled my carb bowls to examine the floats more closely than I do when I pull the bowls checking for stuff that ought not to be in the bowl.
Floats were not flaking and seem to be pretty solid.
However, thought I noticed one was lower in the fuel than the other. Set the bowl on a level surface and it was almost a 1/4 inch lower in the fuel. Pulled the other bowl and found exactly the same thing. The rear most float in both bowls was not sitting as high in the fuel as the forward ones.
Replaced the two that were down with new ones and all are about the same now.
Pictures are attached.
Dual carb, R503, Firestar II
Anyone want to speculate as to the reason just the left ones seem to be affected????
| With original floats on left side. |
36.35 KB |
627 Time(s) |
| With new floats on left side. |
32.08 KB |
589 Time(s) |
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
WhiskeyVictor36(at)aol.co Guest
Posted: Fri Oct 10, 2008 8:37 pm Post subject: Check your carb floats!! |
Hi George,
When the Kolb is parked, the rear of the engine is slightly lower than the front and the carbs are tilted toward the rear. Thus the rear floats are sitting in more fuel than the front ones, albeit a very small difference. While the Kolb is sitting in storage, the fuel in the float bowls evaporates and the rear floats are exposed to the fuel longer than the front ones. They get saturated with fuel and then don't float as high as the front ones which are more dried out. I have no idea if this is the case, but it sounds good, don't you think?
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 10/10/2008 10:22:33 P.M. Eastern Daylight Time, gtalexander(at)att.net writes:
| Quote: | Anyone want to speculate as to the reason just the left ones seem to be affected????
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
George Alexander
Posted: Sat Oct 11, 2008 7:27 am Post subject: Re: Check your carb floats!! |
| WhiskeyVictor36(at)aol.co wrote: |
Bill Varnes
Audubon NJ
Bill:
You win the prize... now I have to figure out what it is....
Your theory as to the reason is one that I had thought and also one offered up by "The Man" at THE Rotax Service Center in Central FL.
FS II R503
E-LSA N709FS
