Geico266
Posted: Tue Sep 02, 2008 5:17 am Post subject: In Flight Adjustable Oil Cooler |
I did a search and could not find this item talked about here, if it has I apologize. It is worth talking about this time of year though.
http://www.nonstopaviation.com/rv10-controller-cooler-p-14566.html
Pretty nice product for getting oil temps up in the winter. Makes cross country flights in the winter months better for the engine by getting the oil (210F+) hot at least once a flight to keep moisture levels in the crankcase low.
dlm46007(at)cox.net Guest
Posted: Tue Sep 02, 2008 5:56 am Post subject: In Flight Adjustable Oil Cooler |
IIRC correctly there is already a thermal switch in the oil filter /cooler
that restricts oil to the cooler until an appropriate temperature is
reached.
wcurtis(at)nerv10.com Guest
robin1(at)mrmoisture.com Guest
Posted: Tue Sep 02, 2008 8:21 am Post subject: In Flight Adjustable Oil Cooler |
We added the gate style control to the oil cooler housing to be able to
control the temp with the pull of a knob. This is common in other RV
models.
Photos attached.
Robin
66.34 KB |
503 Time(s) |
62.19 KB |
523 Time(s) |
