In Flight Adjustable Oil Cooler
Geico266
PostPosted: Tue Sep 02, 2008 5:17 am    Post subject: In Flight Adjustable Oil Cooler Reply with quote
I did a search and could not find this item talked about here, if it has I apologize. It is worth talking about this time of year though.
http://www.nonstopaviation.com/rv10-controller-cooler-p-14566.html
Pretty nice product for getting oil temps up in the winter. Makes cross country flights in the winter months better for the engine by getting the oil (210F+) hot at least once a flight to keep moisture levels in the crankcase low.
dlm46007(at)cox.net
PostPosted: Tue Sep 02, 2008 5:56 am    Post subject: In Flight Adjustable Oil Cooler Reply with quote
IIRC correctly there is already a thermal switch in the oil filter /cooler
that restricts oil to the cooler until an appropriate temperature is
reached.
wcurtis(at)nerv10.com
PostPosted: Tue Sep 02, 2008 7:12 am    Post subject: In Flight Adjustable Oil Cooler Reply with quote
It's the Vernatherm valve. However there can still be some benefit to blocking off the cooler.
Here is a picture: http://www.sacskyranch.com/53e22144apart.jpg
and an article on how it operates.
http://www.sacskyranch.com/eng18.htm
William
http://nerv10.com/wcurtis/
robin1(at)mrmoisture.com
PostPosted: Tue Sep 02, 2008 8:21 am    Post subject: In Flight Adjustable Oil Cooler Reply with quote
We added the gate style control to the oil cooler housing to be able to
control the temp with the pull of a knob. This is common in other RV
models.
Photos attached.
Robin
 Filesize:  66.34 KB
 Viewed:  502 Time(s)
 Filesize:  62.19 KB
 Viewed:  522 Time(s)
