matronics(at)bob.brennan. Guest
Posted: Tue Aug 12, 2008 10:09 am Post subject: Aircraft ID plate |
I am having my UK built Kitfox II certified (hopefully!!) tomorrow morning as Experimental Light Sport. I am doing last minute additions that you Yanks want but the Brits never cared about - such as decals and placards and an ELT. But I am a bit confused by the requirement for a permanent fireproof Aircraft ID plate, as called out by FAR Part 45 subparts 11 & 13.
http://www.flightsimaviation.com/data/FARS/part_45-13.html
I understand the need for one, and have a blank one in front of me from Aircraft Spruce, and need to engrave and pop-rivet it onto the plane before tomorrow. Hopefully those of you who already have a plate on your aircraft can answer:
1. There's no place to enter the N number(?)
2. I assume "Prod. Cert." is left blank as amateur built?
3. For "Type Cert." should I put "Experimental Light Sport" or "ELSA" or what? Considering I don't have the Airworthiness Certificate yet but ELSA is what I am applying for...
4. FAR 45.11 states "the aircraft identification plate must be secured to the aircraft fuselage exterior so that it is legible to a person on the ground, and must be either adjacent to and aft of the rear-most entrance door or on the fuselage surface near the tail surfaces." How does that apply to a Kitfox??
Engraved stainless is tough to erase, and ordering a new plate will take days, so I need to get it right first time.
Thanks in advance,
Bob Brennan
1991 UK Model 2 Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Tue Aug 12, 2008 10:53 am Post subject: Re: Aircraft ID plate |
1. The registration number does not get entered on the dataplate. (N-numbers can change, but this tag is permanent to the aircraft)
2&3. Production and Type Certificates apply to manufactured aircraft, since yours is an experimental/homebuilt, those blocks will be left blank.
4. Usually tags are riveted on the left rear of an aircraft fuselage, in front of and below the horizontal stabilizer. I didn't build my kitfox, so I'm not sure what structure to rivet to.
Make sure that the Make/Builder, Model, and Serial Number blocks are filled in exactly as they are on all of your paperwork. Those are the only required entries for the tag.
_________________ Kitfox IV-1200
Indianapolis, IN |
Guy Buchanan
Posted: Tue Aug 12, 2008 11:08 am Post subject: Aircraft ID plate |
At 11:53 AM 8/12/2008, you wrote:
| Quote: | Make sure that the Make/Builder, Model, and Serial Number blocks are
Ditto this. EXACTLY. (Had to re-do mine.) As to structure, mine's
attached to fabric only, with a metal backing plate. They just want
it in the vicinity when the plane burns up.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Posted: Tue Aug 12, 2008 11:22 am Post subject: Aircraft ID plate |
Thanks Ryan and Guy,
I was thinking of riveting it to the inspection panel under the rear
empennage but my DAR just called and said no - has to be part of the plane
and visible from the outside. He has agreed to riveting it to the dash along
with the other placards, although I'm not sure he knows that the dash is
only held on by those "lord mounts" to a plastic gas tank... Oh well, his
suggestion, his approval...
Second question - although nearly done - I am mounting the ELT now and just
like the data plate there ain't much to fix it too except for cloth and
tubes. So I am opting for bolting it to the seat tray, as close to center as
possible, facing forward as required. There I can get to it easily to switch
it on manually, or unclamp it to take with me (it's made for that). Anybody
care to note where/how their ELT is mounted please?
Bob Brennan
Wrightsville Pa
dave
Posted: Tue Aug 12, 2008 11:34 am Post subject: Re: Aircraft ID plate |
Bob, Although I am in Canada I can tell you that I have run into this before. I had had it ok'd to rivet to the gap cover under the horiz stab by one inspector but yet another ones would say it must be attached to a fireproof non removable place. Mine is rivets to firewall between the right side rudder pedals and since it can be seen from outside it was alright with him.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
rawheels
Posted: Tue Aug 12, 2008 11:39 am Post subject: Re: Aircraft ID plate |
I understand why it can't be on the inspection panel, because that would make it removable and no longer a permanent id tag. However, I'm not seeing the logic of the o.k. on mounting it to the panel. That makes it neither on the exterior, aft of the door, nor near the tail surface as the reg requires.
Indianapolis, IN |
Posted: Tue Aug 12, 2008 11:46 am Post subject: Aircraft ID plate |
Thanks Dave and Ryan,
Yes it's a tough call on a Kitfox, and I might not have picked a plastic gas
tank which would be the first thing to burn to mount to... But my DAR has
done Kitfoxes before and is the one that will hand me a Certificate (I
hope!) so I will go with his suggestion. He said it's mostly for the DEA,
checking on drug smuggling in small planes I guess. Although since anybody
can buy a blank plate from Aircraft Spruce and get a Dremel engraver, like
me, I'm sure drug smugglers aren't *that* stupid!
Any advice on ELT mounting before I drill holes?
thesupe(at)hotmail.com Guest
Posted: Tue Aug 12, 2008 12:06 pm Post subject: Aircraft ID plate |
Hi Bob C here is how I mounted my ELT in my Avid MK IV. That is the tubeing behind the seat C under the turtle deck. Kitfox 2 tubing might be different C my Kitfox 4 project is C but the ELT could be put in the same place on it if need be in a similar fashion. Jim Chuk Kitfox 4 building C Avids flying MN
[quote] From: matronics(at)bob.brennan.name
Subject: RE: Re: Aircraft ID plate
Date: Tue C 12 Aug 2008 15:21:56 -0400
--> Kitfox-List message posted by: 'Bob Brennan' <matronics(at)bob.brennan.name>
Thanks Ryan and Guy C
with the other placards C although I'm not sure he knows that the dash is
only held on by those 'lord mounts' to a plastic gas tank... Oh well C his
suggestion C his approval...
tubes. So I am opting for bolting it to the seat tray C as close to center as
possible C facing forward as required. There I can get to it easily to switch
it on manually C or unclamp it to take with me (it's made for that). Anybody
Bob Brennan
Wrightsville Pa
160.22 KB |
733 Time(s) |
157.17 KB |
711 Time(s) |
Posted: Tue Aug 12, 2008 12:20 pm Post subject: Aircraft ID plate |
Thanks Jim, and it looks like the same model ELT as well. The Model 2 tubing is very different yes, and the flaperon control rods travel through that area when folding/unfolding which is why I can't put storage bags or anything else there easily.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy Chuk
Sent: 12 August 2008 4:06 pm
Hi Bob, here is how I mounted my ELT in my Avid MK IV. That is the tubeing behind the seat, under the turtle deck. Kitfox 2 tubing might be different, my Kitfox 4 project is, but the ELT could be put in the same place on it if need be in a similar fashion. Jim Chuk Kitfox 4 building, Avids flying MN
Date: Tue, 12 Aug 2008 15:21:56 -0400
only held on by those 'lord mounts' to a plastic gas tank... Oh well, his
Bob Brennan
Wrightsville Pa
msm_9949(at)yahoo.com Guest
Posted: Tue Aug 12, 2008 12:55 pm Post subject: Aircraft ID plate |
Hi Bob.
On my model 2, the ID plate is riveted to the aluminum inspection panel just below the horizontal stab on the left side. FAA considered that "part of the plane", I guess.
As for the ELT, I made a triangular mount out of aluminum angle and attached it with adel clamps at 3 points to tubing just forward of the header tank, at the mid-line behind the seats. It's accessible through the triangular opening in the cloth liner covering the area just behind the seat.
Marco Menezes N99KX
Model 2 582-90 C-Box
--- On Tue, 8/12/08, Bob Brennan <matronics(at)bob.brennan.name> wrote:
[quote]From: Bob Brennan <matronics(at)bob.brennan.name>
Date: Tuesday, August 12, 2008, 3:21 PM
[quote]--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name> Thanks Ryan and Guy, I was thinking of riveting it to the inspection panel under the rear empennage but my DAR just called and said no - has to be part of the plane and visible from the outside. He has agreed to riveting it to the dash along with the other placards, although I'm not sure he knows that the dash is only held on by those "lord mounts" to a plastic gas tank... Oh well, his suggestion, his approval... Second question - although nearly done - I am mounting the ELT now and just like the data plate there ain't much to fix it too except for cloth and tubes. So I am opting for bolting it to the seat tray, as close to center as possible, facing forward as required. There I can get to it easily to switch it on manually, or unclamp it to take with me (it's made for that). Anybody care to note where/how their ELT is mounted please? Bob Brennan 1991 UK Model 2 Kitfox Rotax 582 with 3 blade prop Wrightsville Pa --
Posted: Tue Aug 12, 2008 1:39 pm Post subject: Aircraft ID plate |
Hi Bob C I wonder if you are thinking about different tubing? I would think that the flaperon linkage is well forward of the tubing that I'm hooked to C I know it is on the Avid. This is about 18" behind and just about level with the top of the seat. Jim Chuk Kitfox 4 building C Avids flying C Mn
Date: Tue C 12 Aug 2008 16:19:39 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Tahoma;} Thanks Jim C and it looks like the same model ELT as well. The Model 2 tubing is very different yes C and the flaperon control rods travel through that area when folding/unfolding which is why I can't put storage bags or anything else there easily.
Bob Brennan
Wrightsville Pa
mcrutchlow(at)hughes.net Guest
Posted: Tue Aug 12, 2008 2:20 pm Post subject: Aircraft ID plate |
I bolted my ELT to the passenger seat tray facing forward. The remote is
wired to the instrument panel to make it legal in Canada. I can reach
the switch on the ELT from the pilot seat or I can use the remote
switch. Seems to work fine in the location and it can be removed quite
easily.
Mike C.
Model II, 582
occom
Posted: Tue Aug 12, 2008 3:46 pm Post subject: Aircraft ID plate |
If an ELT goes off in the woods and nobody (Sarsat) is listening, does it make a noise??
Anyway, here's pics of my install, I'll have to change to 406 I guess.
45.65 KB |
676 Time(s) |
45.52 KB |
615 Time(s) |
Fox5flyer Guest
Posted: Tue Aug 12, 2008 4:32 pm Post subject: Aircraft ID plate |
gas
Every data plate I've seen on a Kitfox and most other airplanes is
back on the fuselage under the front part of the empennage. I just used a
doubler and pop riveted it to the fabric.\
| Quote: | He said it's mostly for the DEA,
Actually, it's so the DEA can figure out who your are after they
shoot you out of the sky.
Just make sure you can get to it for maintenance and most of all,
consider your balance.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 391+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Posted: Tue Aug 12, 2008 4:47 pm Post subject: Aircraft ID plate |
That's what I did, on the pilot's side. It seems to be a good location and
easily accessible. The only problem I am having now is mounting the antenna
- it's supposed to be a minimum of 5ft from the radio antenna and since that
is dead amidships it doesn't leave many options. I was thinking of mounting
it about 6" from the radio antenna using the same plate, and figuring that
if the ELT goes off automatically in a crash I will be in no shape to be
using the radio anyway, and vice-versa. If I'm capable of using the radio I
can just turn the ELT off, if not - it will work as it should.
But I'm also reluctant to add more drag, do I really need that 2nd antenna?
Does everyone with and ELT have a dedicated external antenna?
For the inspection tomorrow I have connected the ELT to the antenna and put
the hand-held antenna on my radio, which is a hand-held anyway. I won't be
using the radio for a while so can consider options after I start flying
again.
Bob Brennan
Wrightsville Pa
Posted: Tue Aug 12, 2008 4:50 pm Post subject: Aircraft ID plate |
Good to see lots of you using the same cheap model. And I found it without even posting a request!
I see you have the antenna mounted internally. I considered that but what about the metallic UV-resistant coating that goes on before the color coat of paint? I would think that would be like broadcasting inside a Faraday Cage ie not a "good thing"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dave
Sent: 12 August 2008 7:46 pm
Subject: Re: Re: Aircraft ID plate
dave
Posted: Tue Aug 12, 2008 4:52 pm Post subject: Re: Aircraft ID plate |
| Quote: | If an ELT goes off in the woods and nobody (Sarsat) is listening, does it make a noise??
Dave , just tune to 121.5 -- it makes no audible noise.
COPA is still fighting the new 406 ELT
You must be going the amateur built route for registration ? How did you attach the mounting plate to the tubes? I think in AC 43.11 there might be a requirement fora certain G force that it can withstand. your MDRA inspector will know best.
Posted: Tue Aug 12, 2008 5:06 pm Post subject: Aircraft ID plate |
That's a similar, but different, philosophical question to the age old dilemma "if a man says something in the woods and there is no woman there to hear him, is he still wrong?"
occom
Posted: Tue Aug 12, 2008 5:27 pm Post subject: Aircraft ID plate |
Hi Dave, I wasn't really looking for a noise, it was a statement modelled on
an old philosophical question.
I truly hope that COPA is successful but It's not looking good.
In any case the rack is clamped to the fuselage using Adel clamps, and the
antenna is internal because the manual allows for it. I agree that the
silver coat may impede radiation somewhat, but it seems to work ok.
lcfitt(at)sbcglobal.net Guest
Posted: Tue Aug 12, 2008 7:17 pm Post subject: Aircraft ID plate |
When I destroyed our Model IV in the emergency landing, one of the first
questions I had while waiting to be transorted to the ER was where is your
ELT. It had triggered and the signal was loud and clear with it's internal
antenna.
Lowell
