Posted: Wed Jul 16, 2008 9:52 am Post subject: Strategies for car gas at the airport |
The Rotax 912 prefers unleaded fuel. But there is none available at my
airport. I can burn 100LL if I add Decalin although there will be more
deposit build-up and I'll have to change oil more often. So I'm looking at
ways to haul car gas to the hanger. Since my 701 holds 20 gallons a couple
of 5 gal jerry cans isn't going to do it. And fueling a high-wing by hand
will be a challenge. I drive an SUV and not a pickup and I'm not wild about
hauling gas inside the car. But I will if I have to. And then there is the
whole issue of the shelf life of car gas.
How do others do this? One idea is to just fill the car and pump gas from
the car's tank. But I think there is an anti-siphon/theft device on most car
tank filler necks.
-- Craig
Rickey B.
Posted: Wed Jul 16, 2008 10:19 am Post subject: Strategies for car gas at the airport |
Craig, fill the tank on your car with the desired fuel. Stick a
siphon hose in the car tank at the plane. Connect the siphon hose to an
electric Facet pump with the hose on the other end in the wing tank.
Wire the pump with an end that plugs into the "cigar lighter" receptacle
in the car and keep an eye on the fuel level in the tanks. Very little
work on your part and rather safe, too. Just be careful not to drain the
car tank too low! You could, also, use the Gerry cans to supplement the
car tank if it is too small. You don't want to have to walk home!!
Rick
Do NOT archive.
at
couple
hand
about
the
from
car
tank filler necks.
-- Craig
psm(at)att.net Guest
Posted: Wed Jul 16, 2008 12:18 pm Post subject: Strategies for car gas at the airport |
Hi Craig,
One issue you might like to figure out. If you purchase gas at a gas
station and put it in your plane then you have paid a tax for road
use that you didn't use. You should be able to get a refund of this
tax which can be upwards of $.50 per gallon depending on where you live.
Paul
XL getting close
At 10:49 AM 7/16/2008, you wrote:
Quote: | How do others do this? One idea is to just fill the car and pump gas from
tank filler necks.
Gig Giacona
Posted: Wed Jul 16, 2008 12:19 pm Post subject: Re: Strategies for car gas at the airport |
If you flying a bunch, which I certainly hope to be doing once I get finished, you might consider mounting a 50 or 75 gallon tank on a small trailer. I'm thinking about doing that as well as mounting a hose and electric pump to the trailer. There is a gas station just a few miles from the airport and I have a hanger to keep it in.
Yes it will cost some money but there is a $1.75 spread between the cost of 100LL and 93 mogas around here and at 6 gph it won't take too long to make back the cost.
Or you could do what this guy did.
http://www.alexisparkinn.com/fuel_truck.htm
601XL Under Construction
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Wed Jul 16, 2008 12:23 pm Post subject: Strategies for car gas at the airport |
Craig
Donald Hall gave a talk about fuel systems at the Arlington Flyin. He
said that he has been using mogas for 20 years with the two pump systems
shown in the attached photos. He said that the large gascolators on the
pumps was very important to keep crud out of the gas tank. These photos
are my photos of his prints, so, they are not the best. My impression
was that he brought gas to the airplane in 5 5-gal containers and pumped
from there.
Pump_2 is an adaption of a commercial unit with an electrically driven
pump. If you Google something like "gas caddy" you'll find items that
look like pump_2 (without the gascolator), but they are not cheap.
Terry
tank filler necks.
-- Craig
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 slow build kit - Rudder done--finally; working on the stab
http://www.mykitlog.com/N47TP/
Description: |
Filesize: |
91.54 KB |
Viewed: |
503 Time(s) |
Description: |
Filesize: |
97.37 KB |
Viewed: |
522 Time(s) |
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
amyvega2005(at)earthlink. Guest
Posted: Wed Jul 16, 2008 12:40 pm Post subject: Strategies for car gas at the airport |
Paul,
have you gottena refund from the state for Road tax on the gas? that is great, i want to see if they really do that.
juan
Posted: Wed Jul 16, 2008 12:58 pm Post subject: Strategies for car gas at the airport |
Hi Juan,
No, I haven;t gotten a refund. Alas, I haven't used mogas in my
plane. One reason is my plane isn't finished yet. Another is I plan
to use 100LL out of the pump at my local airport.
My tax comment was based on what happens to farmers who use auto fuel
for agricultural purposes. It seems the same to me - highway taxes
paid at the pump wasn't earned by the state. This often isn't enough
fuel to make it worth collecting the refund, but airplanes use a lot of fuel.
Paul
XL almost there
juan
daveaustin2(at)primus.ca Guest
Posted: Wed Jul 16, 2008 1:36 pm Post subject: Strategies for car gas at the airport |
Up here in the frozen north (Canada) it is possible to get the fuel tax
rebate.
Dave Austin 601HDS - 912, Spitfire Mk VIII
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Jul 16, 2008 1:38 pm Post subject: Re: Strategies for car gas at the airport |
Yup you can get the refund, we use to do it "at home on the farm" There is paperwork and such but if you save up your receipts for once a year you could get a pretty nice check 4gph X 50hrs =200 gallons x .$50 =$100.00
I'm sure the paper work has changed, but then Mom did it so I have no idea what it was.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
bjohnson(at)satx.rr.com Guest
Posted: Wed Jul 16, 2008 1:53 pm Post subject: Strategies for car gas at the airport |
For those in Texas, the refund is only 20 cent per gallon..., worth it,
I guess depending on how much fuel you actually use..
the form is here: http://www.window.state.tx.us/taxinfo/taxforms/06-106.pdf
The specific page I found that indicates that aircraft and boats
qualify:
http://www.window.state.tx.us/taxinfo/audit/motorfue/2_gasoline.htm#exceptions
-Bruce
Paul Mulwitz wrote:
Quote: |
Hi Juan,
No, I haven;t gotten a refund. Alas, I haven't used mogas in my plane.
One reason is my plane isn't finished yet. Another is I plan to use
for agricultural purposes. It seems the same to me - highway taxes paid
at the pump wasn't earned by the state. This often isn't enough fuel to
Paul
XL almost there
> Paul,
> juan
Posted: Wed Jul 16, 2008 2:18 pm Post subject: Strategies for car gas at the airport |
Sweat! I am going to check it out for FLorida.
JUan
Posted: Wed Jul 16, 2008 4:20 pm Post subject: Strategies for car gas at the airport |
Hi Craig,
I purchased four 5-gallon red circular steel cans with a spring lid
that's handle actuated. The can comes with a yellow spout that's
perpendicular
with the sides. These are OSHA compliant gasoline cans, unlike some very
unstable plastic types. The spout doesn't leak and protects
the splatter of a first pour. Great geometry for a gas can, especially
for moving within a car. I need at least two more to equate the volume
of my plane and have a spare in case there's ever a leak found or
there's a need for fuel transfer, plane to car. Anything after 3
months, I begin to
run the stuff through my car and refresh the hangar supply. Never had
any trouble with the cans or the 87-octane that's stored in the hangar.
http://www.stacksandstacks.com/track/rd.html?id=176&product_page=108984_5-gallon-gas-can-type-1&sku=108985&utm_medium=shoppingengine&utm_source=googlebase
I'd recommend the can shown in the above link,
tank filler necks.
-- Craig
n601xs(at)gmail.com Guest
Posted: Wed Jul 16, 2008 6:04 pm Post subject: Strategies for car gas at the airport |
I just picked up a 12v Facet transfer pump from ACS, http://www.aircraftspruce.com/catalog/eppages/facetFuelit.php, they have a special where they include the battery option for free. I have the opposite problem, I need to break in my engine with 100LL and the field I'm at is mostly ultra-lights and LSA's and they don't carry Avgas. I used 2 5-gal cans with my Cessna and just topped the plane off every time I drove to the airport.
Craig S.
N601XS, 601xl lyc 0-235
Posted: Wed Jul 16, 2008 8:34 pm Post subject: Strategies for car gas at the airport |
Ah! Good idea to track the date of the gas and put the old in the car.
Thanks for the lead on the can.
-- Craig
cookwithgas
Posted: Thu Jul 17, 2008 4:24 am Post subject: Re: Strategies for car gas at the airport |
Craig:
I was at the gas station a while back and saw a guy with a large, red, flat tank laying in the back of his SUV. It had wheels and he was using it for his boat.
http://www.foreandaftmarine.com/MO-06792.htm
I'm sure a clever airplane-builder could figure out a way to rig up a pump to get the fuel up into the wing tank.
My Corvair loves 100LL so I never did go this route but it was my plan at one time.
Scott Laughlin
601XL/Corvair, PIC
Omaha, NE
LHusky
Joined: 19 Jun 2008 Posts: 86 Location: Madras, Oregon
Posted: Thu Jul 17, 2008 5:16 am Post subject: Strategies for car gas at the airport |
What I have planned is this. I bought a rear rack that will go into the 2" receiver on my SUV. I bought it for $40 bucks at Harbor Freight. I then went to a boat salvage yard and bought a 25 gallon fuel tank. I will bolt that to the rack and it will have 3 electric fuel pumps on it. I have a 12V outlet in the back of my 4Runner and will just plug it into the 3 to 1 extension outlet. When the tank is empty, it will be very easy to take off the truck and store. When it is full, it is secure and NOT in my vehicle. I just hope that I don't get hit in the rear. The tank is plastic, so that helps a little. The 3 pumps put out a lot of gas, so it won't take all day to fill her up. That is my solution. I used it with my ultralight for 3 years without a problem. This is just a bigger tank! I have done a test run and it will work great and fill both tanks in less than 10 minutes.
Larry Husky
Madras, Oregon
In a message dated 7/17/2008 5:27:49 A.M. Pacific Daylight Time, cookwithgas(at)HOTMAIL.COM writes:
Quote: | --> Zenith-List message posted by: "cookwithgas" <cookwithgas(at)hotmail.com>
Craig:
Scott Laughlin
601XL/Corvair, PIC
Omaha, NE
http://forums.matronics.com/viewtopic.php?p=193324#193324
Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
Gig Giacona
Posted: Thu Jul 17, 2008 5:29 am Post subject: Re: Strategies for car gas at the airport |
Since we are on the subject of homemade fueling systems keep one thing in mind.
SET UP A GROUNDING SYSTEM.
david_a_g_johnson(at)btin Guest
Posted: Thu Jul 17, 2008 6:22 am Post subject: Strategies for car gas at the airport |
I don't know where (or if) this is available in the USA - I would be
surprised if it isn't, but it sounds as though this is what he was using and
it has a hand-operated pump.
http://www.transair.co.uk/product4.asp?SID &Product_ID=7818
Dave Johnson
601XL Jab. 3300 - it WILL fly this year!!!
challgren(at)mac.com Guest
Posted: Thu Jul 17, 2008 9:20 am Post subject: Strategies for car gas at the airport |
List:
The product listed below seems to offer a good solution for those flying from their pastures. I have a similar 5 gallon refueling device with a pump that refuels my tractor. It does have a pump that takes about 200 strokes to transfer 5 gallons. However, I am concerned about whether the Flo N Go will work for a high wing airplane. My concern is with the last statement quoted: "Transfers fluids on level surfaces". Has anyone used it for refueling a 701?
Flo N Go Duramax Pump - Fuel TankThe DuraMAX fluid transfer siphon pump and patented Flo n' Go nand pump provide the only re-filling and fluid transfer system you will ever need. With environmentally responsible features, accidental spills and overfilling problems are stopped, providing a safer fluid transfer to you and the environment. So whether your fuel needs include water craft, hunting and camping, generator, outdoor power equipment or professional landscaping tool, the DuraMAX and Flo n' GO combination will make refuelling easy.
- Made from a durable high density polyethylene coloured vibrant red for use with gasoline, diesel or kerosene fuels
- Comes complete with a patented Flo n' Go hand pump & pump holder handle.
- 14 Gallon (53 Litre) capacity and a 10' (305 cm) long fuel hose.
- Includes a bolt on hanger for convenient hose storage.
- Quickly refuels, using a UL approved, mechanically vented fill cap.
- Transfers fluids on level surfaces with minimal priming.
On Jul 17, 2008, at 8:19 , David Johnson wrote:
[quote] [quote][b]
ggower_99(at)yahoo.com Guest
Posted: Fri Jul 18, 2008 9:18 am Post subject: Strategies for car gas at the airport |
After years of experience with the use red plastic containers, we dont have gasoline at our aerodrome. and airports here dont handle car gasoline, only 100LL. I am very happy using several 10 liter (about 3 gal) red containers.
They are not heavy to fill the 701 wing tanks, when I carry two at a time I am perfectly balanced. Instead of one 20 liter (5 gal) in one hand. The bigger the cntainer, the more dificult to move around.
I have 3 cardboard boxes with 2 containers each that I put as needed in the pick up bed. This way they dont roll around. I normally bring from 20 to 40 liters Is the amount of gasoline we normally use every flying saturday.
Saludos
Gary Gower
Flying from Chapala, Mexico
701 912S 202 hrs this last saturday
--- On Thu, 7/17/08, cookwithgas <cookwithgas(at)HOTMAIL.COM> wrote:
[quote]From: cookwithgas <cookwithgas(at)HOTMAIL.COM>
Subject: Re: Strategies for car gas at the airport
Date: Thursday, July 17, 2008, 8:24 AM
[quote]--> Zenith-List message posted by: "cookwithgas" <cookwithgas(at)hotmail.com> Craig: I was at the gas station a while back and saw a guy with a large, red, flat tank laying in the back of his SUV. It had wheels and he was using it for his boat. http://www.foreandaftmarine.com/MO-06792.htm I'm sure a clever airplane-builder could figure out a way to rig up a pump to get the fuel up into the wing tank. My Corvair loves 100LL so I never did go this route but it was my plan at one time. Scott Laughlin 601XL/Corvair, PIC Omaha, NE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=193324#193324 [quote][b]
