Rochester dual indicator
bouguy
PostPosted: Mon Jul 14, 2008 12:13 am    Post subject: Rochester dual indicator Reply with quote
hi ,
i have a Rochester dual indicator , Oil temp and Oil Press ,
Cessna Part N° S3279-1 coming from a 28volts Skyhawk .
i would like to use it but as i have no Parts catalog , am not
able to determine probe and sender references .
is somebody able to help me ?
thanks a lot ,
Guy , Barracuda builder .
Sad
nuckolls.bob(at)cox.net
PostPosted: Mon Jul 14, 2008 4:40 am    Post subject: Rochester dual indicator Reply with quote
At 01:13 AM 7/14/2008 -0700, you wrote:
hi ,
thanks a lot ,
Man! That goes back a few years. I'll see if any of
my old friends at Cessna can pull the S-sheet for me
on the gage cluster. I think it calls out the
companion parts and their Cessna standard number.
Those documents will at least speak to performance
of the senders. I think the OilT is a custom thermistor
and OilP is a carbon pile pressure to resistance
transducer. They all had common Rochester source
numbers from the automotive industry. The BIG question
will be whether or not they're still made as automotive
spares.
I'll see what I can find out for you.
( -Thomas Paine 1776- )
bouguy
PostPosted: Mon Jul 14, 2008 11:35 pm    Post subject: Re: Rochester dual indicator Reply with quote
hi Bob ,
thank you very much ...
Guy .
bouguy
PostPosted: Fri Aug 15, 2008 11:10 pm    Post subject: Re: Rochester dual indicator Reply with quote
hi ,
thanks a lot ,
PostPosted: Sat Aug 16, 2008 7:03 am    Post subject: Rochester dual indicator Reply with quote
At 12:10 AM 8/16/2008 -0700, you wrote:
hi ,
thanks a lot ,
The S-number is probably one you read off the cluster. That
a Cessna Standards number that I can go look up and tell you
what the specs are for the instrument and probably the Rochester
number it was supplied under to Cessna. It will probably
reference the companion sensors too and those can be
researched. However . . .
Can I try to talk you out of using these parts? You're assuming
that these are good parts in spite of their pedigree. If one
of them is bad now or in the future, where will you get a
replacement? There's a host of alternative gages in the automotive
and aviation worlds that are of equal quality but modern design
and production. Check out these devices:
http://aircraftspruce.com/catalog/inpages/mitchoilpress.php
http://aircraftspruce.com/catalog/inpages/mitchoiltemp.php
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3723
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=3727
If you're building a 28v airplane, you can easily craft a 28v to
14v down-regulator to supply power to the modern automotive
instruments.
If you REALLY want to use the salvage parts, I'll see what
bouguy
PostPosted: Sun Aug 17, 2008 12:39 am    Post subject: Re: Rochester dual indicator Reply with quote
Hi Bob ,
these instruments are not old and are 2 1/4 standard dimensions ;
they are not embedded in a cluster ; look at the attachement .
so if i need to change them there will be no problem !
they are fitting the latest C172 i have seen .
if you may have information on senders it will be great ;
if not i will try to find another solution , but for the time i
try to save money .
thanks for your help ,
Boullu guy .
 Filesize:  395.22 KB
 Viewed:  750 Time(s)
PostPosted: Sun Aug 17, 2008 6:16 am    Post subject: Rochester dual indicator Reply with quote
At 01:39 AM 8/17/2008 -0700, you wrote:
Hi Bob ,
try to save money .
Understand. I was not aware that Rochester was still
building for Cessna . . . but it doesn't surprise me.
I guess I should have picked up on the magnitude of
the S-number you quoted. When I worked there, the
current production products were in the 1000's range.
I'll see what I can find out about these parts.
