Rudder pedal mounting
daveleikam(at)wi.rr.com
PostPosted: Mon Jun 30, 2008 7:32 pm    Post subject: Rudder pedal mounting Reply with quote
The instructions have you cut the F-6115 rudder pedal bearing block in half which removes material and causes the part to clamp the rudder pedal assemblies. Has anyone used spacers between the two halfs to prevent the action from being so stiff?
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
Tim Olson
PostPosted: Mon Jun 30, 2008 8:41 pm    Post subject: Rudder pedal mounting Reply with quote
It won't feel so bad when you actually get them mounted in
the plane and use your feet. Yes, by hand they feel really
stiff though.
Dave Leikam
Muskego, WI
Dave(at)AirCraftersLLC.co
PostPosted: Mon Jun 30, 2008 10:12 pm    Post subject: Rudder pedal mounting Reply with quote
I opened up the holes a bit for a looser fit. You don't need anything super precise there, and less friction is better.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Monday, June 30, 2008 8:29 PM
To: RV-10 matronics
Subject: Rudder pedal mounting
Dave Leikam
Muskego, WI
Bldgrv10450(at)comcast.ne
PostPosted: Tue Jul 01, 2008 12:35 am    Post subject: Rudder pedal mounting Reply with quote
Dave
I didn't use any spacers on mine. I do however have an alternate center support bushing and mounting bracket that attaches to the stock firewall support bracket, not shown in the photo.
Feedback and questions are welcome however please be understanding, I am typing one finger / left handed from rotater cuff surgery last week.
Paul Grimstad
RV-10 450
Portland, Or.
 Filesize:  289.45 KB
 Viewed:  381 Time(s)
drfred(at)suddenlinkmail.
PostPosted: Tue Jul 01, 2008 6:23 am    Post subject: Rudder pedal mounting Reply with quote
Paul :
Great looking set of pedals for the 10. Hope your recovery is
progressing well.
Fred Williams.
40515
working through the maze of wiring.
will put the windshield in with weld on and the sides with silpruf.
AV8ORJWC
PostPosted: Tue Jul 01, 2008 6:42 am    Post subject: Rudder pedal mounting Reply with quote
Wow, now that is what the factory should have designed. And the cables are concealed within the tunnel. Reminds me of building hot-rods. Is the foot pressure stiffer than stock?
Nice photo.
John Cox
RV-10 600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad
Sent: Tuesday, July 01, 2008 1:28 AM
Subject: Re: Rudder pedal mounting
Dave
Paul Grimstad
RV-10 450
Portland, Or.
jim(at)CombsFive.Com
PostPosted: Tue Jul 01, 2008 6:58 am    Post subject: Rudder pedal mounting Reply with quote
I added washers (same thickness as the band saw blade) between the two parts.
No gaps and no binding.
Jim Combs ======================================================
Date: 2008/06/30 Mon PM 11:29:15 EDT
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Dave Leikam
Muskego, WI
Deems Davis
PostPosted: Tue Jul 01, 2008 7:04 am    Post subject: Rudder pedal mounting Reply with quote
So when are you going to share (i.e. market) those beauties with the
rest of us ???????
Deems
and the brake cylinders and plumbing are 'hidden' on the back side!!!!!!
ricksked(at)embarqmail.co
PostPosted: Tue Jul 01, 2008 7:10 am    Post subject: Rudder pedal mounting Reply with quote
Heh He...should be the same....2 foot pounds...one for each foot on each pedal Smile
Rick Sked
40185
PostPosted: Tue Jul 01, 2008 8:12 am    Post subject: Rudder pedal mounting Reply with quote
Deems,
There is one builder that should be installing a set very soon. I will be
working closely with him on the details.
Marketing effort is slowly underway, for now we are just happy to be back to
building our 10 kit and working on pedal design for the RV6,7 & 9.
Additionally, I have several pedal sets sold and we are planning a small
production run. The system cost is $1,795.
Paul Grimstad
RV10 450
Portland, Or.
Kellym
PostPosted: Tue Jul 01, 2008 1:44 pm    Post subject: Rudder pedal mounting Reply with quote
I know a patent attorney or two if it would help speed them to market. Cool
rest of us ???????
Deems
Kelly McMullen
KCHD
