Fuel tank caps for 601XL
rhaskins(at)kumc.edu
PostPosted: Thu Jun 26, 2008 6:10 pm    Post subject: Fuel tank caps for 601XL Reply with quote
My building partner and I have discovered that the fuel tank caps that Zenith sent when screwed on do not sit flush with the wing. Apparently the vendor that sent the caps changed them without notifying Zenith. Zenith will not offer any help other than telling us to find out what other builders are doing to correct the problem. Has anyone else had this problem, and does anyone know of a fix? Thanks.
ding(at)tbscc.com
PostPosted: Thu Jun 26, 2008 6:38 pm    Post subject: Fuel tank caps for 601XL Reply with quote
Robert,
Are the caps bottoming out on the welded tank bung before the outer flange meets the skin?
Lynn   Corry, PA
dbrown(at)avecc.com
PostPosted: Thu Jun 26, 2008 8:43 pm    Post subject: Fuel tank caps for 601XL Reply with quote
I had the same problem on one tank.  I took a dremel tool with a metal cutting bit and cut a 45 degree countersink about 3/16”  all the way around.  It wasn’t easy, but I did it without messing up the threads.
David  N601EX
Iberplanes
PostPosted: Thu Jun 26, 2008 11:36 pm    Post subject: Fuel tank caps for 601XL Reply with quote
After checking my tanks, I found the same problem here. My kit was made in nov 07.
Any ideas?
Alberto Martin
www.iberplanes.es
Igualada - Barcelona - Spain
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300 [quote][b]
Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Afterfxllc(at)aol.com
PostPosted: Fri Jun 27, 2008 12:19 am    Post subject: Fuel tank caps for 601XL Reply with quote
Mine are from 4/17/08 and I don't see a problem with them. Could you post a pic of them so I can see what you are referring to?
Jeff
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
ding(at)tbscc.com
PostPosted: Fri Jun 27, 2008 2:51 am    Post subject: Fuel tank caps for 601XL Reply with quote
My kit was Feb., 2006 manufacture. I understand Zenith later started welding the threaded bung on the bottom side of the skin to lower it. I did the countersink job as well, and was careful with the threads. I needed more, and drove the bung down (bending the tank top skin) with a block of wood and a mallet. Worked very well, and allowed me to level the bung to be parallel with the top of the leading edge skin as an extra benefit. Use great caution not to let the filler threads gall or crossthread when installing the cap socket, it can happen very easily with the fine threads and direct alum. to alum. contact. I used antisieze compound after almost "sticking" one while fitting it. I also bought Baker Seal from ACS for the final installation, as it has antisieze properties in addition to sealing, but still allows future removal.
Lynn Dingfelder
601XL / Corvair done -- starting to paint
PostPosted: Fri Jun 27, 2008 6:54 pm    Post subject: Fuel tank caps for 601XL Reply with quote
I didn't do a good job of describing the problem. The reason that the caps are not flush with the skin is that the filler tubes, which are screwed into the tanks do not screw down far enough. The filler tubes have a beveled shoulder at the top, and the top of the tanks are not beveled. The cap and top of the filler tube extend each extend up beyond the outer skin
sperry50(at)comcast.net
PostPosted: Sat Jun 28, 2008 4:52 am    Post subject: Fuel tank caps for 601XL Reply with quote
Sounds like you need to call Zenith and get the “giant counter-sink”. Also, don’t forget the tap to clean the threads after you’ve done the counter sink.
Skip Perry
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Robert Haskins
Sent: Friday, June 27, 2008 10:51 PM
Subject: Re: Fuel tank caps for 601XL
&7~ 2,gSS [quote][b]
pavel569
PostPosted: Sat Jun 28, 2008 4:52 am    Post subject: Re: Fuel tank caps for 601XL Reply with quote
Picture worth thousand words.
rhaskins(at)kumc.edu wrote:
I didn't do a good job of describing the problem. The reason that the caps are not flush with the skin is that the filler tubes, which are screwed into the tanks do not screw down far enough. The filler tubes have a beveled shoulder at the top,�and the top of the tanks are not beveled. The cap and top of the filler tube extend each extend up beyond the outer skin
Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive"
PostPosted: Sat Jun 28, 2008 9:44 am    Post subject: Fuel tank caps for 601XL Reply with quote
I looked at my tanks and they are the same as the older kit I built a year ago. I think he has too much cork under the tanks and the top is too close to the skin. Most times I have to put 2 and sometimes 3 layers of cork around the filler neck to make the cap even with the skin. I'm sure some will remember the trouble with the filler neck not laying flush. I wish he would send a pick of the tank in the wing.
Jeff
PostPosted: Sat Jun 28, 2008 8:22 pm    Post subject: Fuel tank caps for 601XL Reply with quote
Here are photos of the fuel neck with the cap on. It shows the bevel or flange at the top of the fuel neck, but there is no corresponding bevel in the top of the fuel tank hole. It screws in, but stops at the bottom of the flange.
 Filesize:  42.9 KB
 Viewed:  610 Time(s)
 Filesize:  31.18 KB
 Viewed:  571 Time(s)
 Filesize:  25.23 KB
 Viewed:  526 Time(s)
Aerolitellc(at)aol.com
PostPosted: Sun Jun 29, 2008 12:17 am    Post subject: Fuel tank caps for 601XL Reply with quote
Looking at your pics my hunch was correct... you have the skins too close to the tank. I have the same caps you do and if you only use one row of cork on the bottom you will have close to a 10 to 12 mm gap between the tank and the top of the skin then you build around the filler neck with a couple of layers of cork to make up the difference and to level out the top of the neck. I will be building mine in a week and it takes me 2 weeks to finish them so I will post some pics on my web site.
You can call if you need anything else 502-644-8123
Jeff
zenithlist(at)yahoo.com
PostPosted: Sun Jun 29, 2008 2:07 pm    Post subject: Fuel tank caps for 601XL Reply with quote
So what is the proper number of cork layers between the top of tank and top leading edge skin? How about between the bottom of tank and bottom of leading edge skin?
--- On Sun, 6/29/08, Aerolitellc(at)aol.com <Aerolitellc(at)aol.com> wrote:
From: Aerolitellc(at)aol.com <Aerolitellc(at)aol.com>
Date: Sunday, June 29, 2008, 1:12 AM
Jeff
PostPosted: Sun Jun 29, 2008 2:23 pm    Post subject: Fuel tank caps for 601XL Reply with quote
I think if I remember correctly it was 1 layer on the bottom is all and more at the top. In other words just as much as needed on the bottom to keep it from touching the skins. Also make sure your vent isn't holding the tank forward and off the spar. Like I said you can call if you like.
Jeff
Ron Lendon
PostPosted: Sun Jun 29, 2008 2:55 pm    Post subject: Re: Fuel tank caps for 601XL Reply with quote
While you're waiting, take a look here and maybe get some ideas.
http://picasaweb.google.com/ron.lendon/FuelFiller
I think I was doing this sometime around the 8th month of 2007 if you want to look it up in the kitlog.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
PostPosted: Mon Jun 30, 2008 7:17 am    Post subject: Fuel tank caps for 601XL Reply with quote
Thanks everyone for the help. We are in the process of moving everything to a new workshop.Unfortunately, it won't make me any smarter. We put two layers of cork under the tank. I am anxious to get everything "unbuttoned" and try again.  Thanks again.
