Adding a passenger to the Twinstar
Goto page Previous  1, 2
cristalclear13
PostPosted: Mon Jun 23, 2008 5:47 pm    Post subject: Re: Adding a passenger to the Twinstar Reply with quote
Wow, I go off to work (yes, back to the grindstone) and come home to lots of advice and even an ellery offer (um...no thx).
Waycross airport IS my normal airstrip, and I mentioned it had 6000ft to let you guys know that I know I have PLENTY of room.
Grant, I don't think your instructor weighs that much either...when he flew it did he add weight?
You asked about my signoff - that's a long story. I had to go to Tennessee to find an instructor familiar with Kolb. We flew a Kolb but it wasn't my Mark II, so that's why I haven't flown mine with someone in it. I know it'll carry two good size people because when I bought it the man took me up in it. After I bought it I started the process of getting the airworthiness certificate. Couldn't fly it until that was completed and once that was completed there was a five hour minimum solo flight restriction - couldn't even take up an instructor with me. Couldn't find anyone locally willing to fly off the five hours for me. And I couldn't solo my plane until someone signed me off to fly it. An endless red-tape circle!
With Jim's help (to whom I am eternally grateful) I got signed off. I've flown off the five hours. I'm close to getting my private certificate. And like John said, I'm eager to take someone up with me. Not to show off, but to share the joy of flying and the wonderful view. But as I hope you all can tell from my questioning, I'm very safety conscience and I tend to follow rules closely (thus the red-tape making me go in circles searching for a loop hole or way to be able to fly my plane legally). I, like John, certainly don't want to do anything to hurt anyone or myself. Everyone seems to have differing opinions of what is safe.
On the Mark II there is a middle bar that leans over into the passenger's seat making it only about 12 inches wide. If you're wider than that you have a bar jabbing you in the hip. That doesn't leave much room to add bags of anything or even a container. I mean...it's a small seat. For a quick flight around the pattern (and going up high enough to find the new approach speed) is all I'd probably take someone up for because any longer than that and they're going to have a mighty sore hip.
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
Snoopy Baxley
PostPosted: Mon Jun 23, 2008 7:00 pm    Post subject: Adding a passenger to the Twinstar Reply with quote
Hey Crystal and fellow Kolb friends
I trained in a Kolb Mk11 with a Rotax 503 before I soloed in my single place Kolb... I can still remember my instructor stressing air speed and altitude as my two best friends .. With a combined pilot and trainee weight of plus 400 pounds the Kolb flew more like a cargo plane than anything else but was still quite a very stable platform ... I had no problems landing or taking off just remembering taking a much longer distance for each ... Choosing to cut the engine off on landing to coast to a quicker stop on the 1600 foot grass strip we had landed in ... The main thing is to be safe and be prepared ... Take the advice of those that's been there before... Obey your instructor and know your airplane well.....
Stephen Baxley
2003 Kolb Firefly
South Georgia 17J
www.southernflyersul.com
Do not Archive
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
by0ung(at)brigham.net
PostPosted: Tue Jun 24, 2008 11:36 am    Post subject: Adding a passenger to the Twinstar Reply with quote
The W/B says the pilot weight should be a minimum of 195#. I weight 150#. So I need at least 45# ballast to fly solo. So with the proper ballast the plane will be 120# lighter with out my instructor in it.
If you put say 10 or 15 lbs in the nose,,, would do as much or more than 45 lbs in the seat. Putting the weight in the nose will give it a much greater moment arm.
And what should you expect..... take off will be only 2/3 as long and much quicker acceleration. Climb will be faster. The roll trim may be different. You will need less elevator trim... be prepared to be amazed.
Boyd Young
MKIIIC 912
225+ hours and counting.
pj.ladd(at)btinternet.com
PostPosted: Tue Jun 24, 2008 11:41 am    Post subject: Adding a passenger to the Twinstar Reply with quote
He paid around $120 for the flight but I
am not going to fly him until I feel a bit happier at the prospect. >>
Hi Cristal,
I wrote the above only yesterday. Unfortunately yeterday evening was soo
perfect that I took the bull by the horns, rang the guy who bought the
flight and offered to fly him .
Introduced the guy to the plane, did a walk round with him.Explained what I
was doing and strapped him in. Fired up and taxied out.
Now, the farmer has cut my field and there is hay lying everywhere, drying.
The strip has been raked clear but not the taxyway. Taxied out very
gingerly through the hay and went right to the end of the strip. Unusual as
I usually use only a part of it.
Told the passenger what was going to happen. Got him to move his hip away
from the dual throttle. Move his feet away from the pedals, move his left
arm so that I could operate the flaps
Ran through my mental checklist Controls, ballast, straps, intsruments trim
Flaps... At this point I decided that I should check to see if I had picked
up a load of hay round the mains or the tailwheel. Mains clear, eased my
straps to look out of the door to check the tailwheel. All OK. Tightened
straps completed checklist with Canopy( left over from gliding days) it
means check doors now, and Brakes, keep feet clear.
Opened the throttle, tail up, speed building.... we should be in the air by
now. Thinks...nil wind.....perhaps the passenger is heavier than
expected...going like the clappers now....too late to stop...hedge coming
up....drag the stick back and she reluctantly took off.
She was flying OK but not climbing as expected. Speed was ok so I just kept
going pretending to the passenger that all was normal. Arrived some time
later at 1000 ft and throttled back and finally had time to think.
You have got there by now. Right! . I had forgotten to set the takeoff Flap.
Enough for one flight you might think. But.. Flew to our home village,
passenger happily taking pics, circuited over the village and then flew on
when I noticed that the oil temp was in the red and the oil pressure had
dropped.
Very calmly I announced that something wasn`t quite right and it would be
prudent to fly back. Eased throttle and began to lose height and arrived at
the strip about 10 minutes later.. Pressure was still low but the temp had
eased a bit. Made a reasonable circuit apart from having to fight the
passenger for the flap lever, it really is an abortion, and then I messed up
the landing.
Allowing for the extra weight I arrived over the hedge at about 70 instead
of 60.In nil wind that was close to the ground speed. We whistled in. The
touchdown itself was a greaser but we took up about three quarters of the
strip wheras I am usually down in less than half. The passenger of course
thought this was quite normal.
Just to put the lid on everything. When I taxied in I found that the rear of
the plane was covered in oil Yuck. Engine frame, prop, fuselage, tail
feathers. It seems that when I changed the oil a couple of days ago I over
filled it, I hadn`t done an oil change before. and the excess had blown out
of the breather tube.
Luckily while I was cleaning up a couple of mates landed in a Jabiru and
kindly took my passenger off fora flight.
Over a beer later I was happy to hear my passenger say that although the
Jabiru was comfortable and quiet he preferred the Kolb beause of the
visibility.
If it can go wrong it will. All reminds me of a cartoon in a RAF
iinstructional magazine during the war. A whole bomber crew arriving at the
Pearly Gates saying "We forgot the checklist"
Today luckily has been quite nice weather and I have spent the day cleaning
oil from everything and arranging a bottle and a piece of hose for the blow
tube to lead into. Looking forward to checking the oil temp and pressure on
the next flight.
cheers
Pat
cristalclear13
PostPosted: Tue Jun 24, 2008 12:45 pm    Post subject: Re: Adding a passenger to the Twinstar Reply with quote
Pat
Pat, Thanks for sharing your experience. I'm glad you and your passenger made it safely home.
Cristal Waters
PostPosted: Tue Jun 24, 2008 1:35 pm    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat
Patrick:
"Taking the bull by the horns is a good way to get gored."
Glad you did not kill or injure your innocent passenger.
Over the years I have been flying Kolbs, I have made it a hard and fast rule
to test fly the airplane solo before I put an innocent passenger in the
other seat. Do that every day I fly passengers to insujre it is good to go.
If I discover there is something not normal about the airplane, or me, after
I am airborne, then it is only me and the Kolb that have to deal with the
problem.
In the US, if we build our Kolbs to be "homebuilt/experimental category",
normally, we must fly off a 40 hour test period, solo. We are not legally
authorized to fly a passenger until we have flown off our test time. This
gives the pilot a lot of time to get to know his airplane before he attempts
to fly with a passenger.
High engine oil temp and low oil pressure is a pretty good indication of an
impending engine failure. But you know all that, of course.
Take care,
hauck's holler, alabama
PostPosted: Wed Jun 25, 2008 1:42 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Hi John,Good one. I will remember that. After all my good advice to Cristal
about being properly prepared, I had to get it all wrong.
<<Over the years I have been flying Kolbs, I have made it a hard and fast
rule to test fly the airplane solo before I put an innocent passenger in the
other seat.>>
I had flown the day before. What I hadn`t done was fly since my oil change.
I dont see quite how , until I investigate further, but I suspect that the
low pressure and the high temps were related to the oil change somehow. Hot
oil on the sensor perhaps?
I drained the oil out yesterday and only refilled to a much lower level.
Ground ran the engine for a long period (It was too rough to fly) and
evrything seems OK. I good grind around the patch within gliding distance of
my strip seems to be indicated before going further. Luckily most of the
hayfields are cut so there are plenty of big field to put her down in if the
worst happens.
I managed not to scare my passenger anyhow. . He rang me up to thank me for
the flight and asked to fly again.
Cheers
Pat
PostPosted: Wed Jun 25, 2008 2:04 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat, Thanks for sharing your experience.>>
Hi Cristal,
Glad you liked it, and learned from it, I hope.. At least my stupidity can
do someone a bit of good.
They say that bad things happen in threes. In this case It was 1) Absolutely
zero wind, 2) Not putting in enough trim to compensate for the passenger
weight. 3) Missing the flap setting from my interrupted Check list.
Good .luck. Keep us posted with your progress.
Cheers
Pat
gaman(at)att.net
PostPosted: Wed Jun 25, 2008 4:50 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat,
What powers your Kolb?
PostPosted: Wed Jun 25, 2008 11:56 am    Post subject: Adding a passenger to the Twinstar Reply with quote
I have a Jabiru. The only engine which is cleared for use on the Xtra in the UK. The others put the weight above the ultralight limit.
Pat
Ricochet
PostPosted: Wed Jun 25, 2008 12:53 pm    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat,
What prop are you using with your Jab and how many blades?  Three blades on a pusher are reported to be considerably quieter than two, but wooden props are normally recommended, though perhaps difficult to find.  I've got a Jab on another bird and am considering hanging it on a Kolb, but not certain which one.  Kinda miss the Firestar I had and slewing sideways in a crosswind now and then.
Jerry
Pat
PostPosted: Thu Jun 26, 2008 6:39 am    Post subject: Adding a passenger to the Twinstar Reply with quote
What prop are you using with your Jab and how many blades?>>
Hi Jerry,
prop is 2 blade, wooden GT/157. 157 cms dia X 98cms pitch.
The dealer reports better performance with the Prince `P` tip.
I have found the combination very noisy indeed although I think it can only be the result of the `pusher` configuration as Jabi`s in normal tractor config are super quiet.
I would like to run the exhausts so that it is expelled outside the diameter of the prop to see if that makes it quieter. Unfortunately it would be pretty expensive to get a one off system made and there would be a weight penalty.We do not have your freedom to experiment and a change like that would need permission for a modification from the Light Aircraft Assoc.
Incidentally if anyone on the list has a noise problem, and a solution, I would be pleased to hear about it. The ordinary noise from a 912 and a Jabi are pretty similar so any comments would probably be valid
Cheers
Pat
PostPosted: Thu Jun 26, 2008 9:15 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Patrick:
We aren't flying Cessna Citations or Lear Jets. Some of us are building these things in the basement and flying them out of cow pastures. They are noisy as Hell and I don't know that anyone has built a quiet one yet. I think the problem is the engine and prop are on the wrong end. When I am at Lakeland and OSH, I am always amazed at how quiet the tractors are, powered with the same prop and engine I have.
Get a good ANR headset, learn how to fly your airplane, see if you can get to TBO next year, and enjoy the Hell out of it.
I plan on doing that, if I can. Tomorrow morning flying to Harris Field, Raleigh, MS, home of Paul Petty's ex-Father-In-Law. Going to do some Kolbra tweaking, get a BFR out of the way, eat some home grown vegetables and fried chicken. Hope to beat the thunderstorms by getting out of here early in the morning, and back home again early tomorrow morning. A 400 mile round trip flight is good for the soul. Haven't done a cross country since I returned from out West the first of June.
Two weeks until John Bickham's Nauga Field Flyin at Star Hill, LA. Everyone is invited. Prefer flying in, but if you can't fly, hitch a ride and get there the best way you can. I can assure you you will have a ball. These folks know how to take care of their guests. Most of the old gang that flew cross country flights with John W will be there to honor our old buddy, tell lies, eat good, and maybe play a little Knock Knock Poker if the weather turns sour. See ya'll there!!!
Take care,
2,800+ hours and counting in the old mkIII, Miss P'fer (p fer plane)
Cheers
Pat
gaman(at)att.net
PostPosted: Thu Jun 26, 2008 10:11 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat,
Noise is a problem.Here is a picture of my home made exhaust system.Also requires sealing the fuselage tube to keep exhaust from coming up the tube.
 Filesize:  17.74 KB
 Viewed:  521 Time(s)
PostPosted: Thu Jun 26, 2008 10:39 am    Post subject: Adding a passenger to the Twinstar Reply with quote
.Here is a picture of my home made exhaust system.>>
Hi,
I had something on those lines in mind. Did it accomplish anything?
Pat
Ricochet
PostPosted: Thu Jun 26, 2008 10:50 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat,
As a former Jab-powered Titan driver, both the four and the six, and now in a tractor, I can vouch for what you say.  Pushers are inherently noisy because the propeller is chopping disturbed air from over the wings.  With a 2-blade, both blades are chopping at the same time, kinda doubling the noise produced, hence the advantage of a 3-blade is that only one blade is chopping the air. Another lesson learned is that shorter props, and hence less tip speed, are quieter.  I was swinging 58 inch props which were much quieter than friends who put on 62 inch props.  Warp drive props, I have since learned, are presumably okay for the Jabs, and hence a 3-blade setup is possible.
Jerry
On Jun 26, 2008, at 7:36 AM, pj.ladd wrote:
[quote]What prop are you using with your Jab and how many blades?>>
Hi Jerry,
Cheers
Pat
Ricochet
PostPosted: Thu Jun 26, 2008 10:59 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Oh, yeah, Pat, another claimed way to reduce noise was to install a prop extension, pushing the prop back one to three inches.
Jerry
On Jun 26, 2008, at 11:09 AM, gary aman wrote:
[quote]Pat,
Cheers
Pat
<CIMG1758.JPG>
PostPosted: Thu Jun 26, 2008 11:13 am    Post subject: Adding a passenger to the Twinstar Reply with quote
We aren't flying Cessna Citations or Lear Jets. Some of us are flying them out of cow pastures. They are noisy as Hell and I don't know that anyone has built a quiet one yet.>>
Hi John,
I fly from a cow pasture too, but we just do not have the room that you do in the States. You can`t start an engine here without annoying somebody and unless you get the plane noise certificated you will not fly. I am noise legal but it is still noisy. The guy who owns the strip is very twitchy as there is a movement in the local village to close it. In spite of the fact that it has been there more than 30 years. The trouble is a complaint to the local Council is almost always carried through in spite of the hundreds in the area who do NOT complain. Consequently we never do circuits or fly close to the strip. Take off and fly away is the rule.
<< I think the problem is the engine and prop are on the wrong end. When I am at Lakeland and OSH, I am always amazed at how quiet the tractors are, powered with the same prop and engine I have.>>
Ithink you are right. A Jabiru flew into my strip a couple of days ago and it was like a sewing machine.Almost noiselss at 300 feet.
<<Get a good ANR headset,>>
Tried to get a ANR retrofit for my headphones. Would you believe that the series I have are the only ones in the manufacturers range which cannot be converted . In any case I am not particularly bothered, its other people. This week from 1500 ft I broke up an open air Shakespeare play rehearsal.. I have been threatened with sudden death if I pull the same stunt on a performance night..
learn how to fly your airplane, and enjoy the Hell out of it.>> I am learning and I am really enjoying it
<< Hope to beat the thunderstorms by getting out of here early in the morning,>>
We have the hell of a thunderstorm going on at the moment. Rain is sheeting down and its the first night of the Outdoor Shakespeare performance. Wendy is in it and will NOT be pleased..
Two weeks until John Bickham's Nauga Field Flyin at Star Hill, LA. Everyone is invited. Prefer flying in, but if you can't fly, hitch a ride and get there the best way you can.>>
Definitely will not be making it to the States this year Say `Hello` to all those I met at MV last year.
Cheers
Pat
PostPosted: Thu Jun 26, 2008 11:16 am    Post subject: Adding a passenger to the Twinstar Reply with quote
Pushers are
over the wings.>>
Hi Jerry,
that is about the conclusion I have come to. Messing with props is again not a simple operation here.
Cheers
Pat
gaman(at)att.net
PostPosted: Thu Jun 26, 2008 2:50 pm    Post subject: Adding a passenger to the Twinstar Reply with quote
Pat,
Would you prefer the truth or do you want me to tell you how much it helped?I lined the entire cabin and over head center cover with 1/2" denso foam sound control foam.Doesn't weigh much and now I can actually use the intercom at 2700 rpm,but not at full throttle.It's not the engine,it's the prop.It sounds so good at 1800 I wish it would fly at that rpm.I really thought that a geared engine would get the prop noise down to a tolerable level,but I can't address that.I think Mr. Pike has made some cabin mods that may be more productive in suppling cleaner air flow to the prop,which may reduce noise.Like John said,I guess I'll just have to get OVER it and enjoy the flight!
Page 2 of 2
