Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Mon Jun 16, 2008 6:25 am Post subject: Tie Down Point |
The pre-drilled tie down point in the main wing looks to be to low down.
If you use the pre drilled holes the bottom of the tie down ring will be inside the wing sheeting. Is this the way every one has done it or have you moved it out one hole.
Ianrat
700.16 KB |
1218 Time(s) |
Davcoberly(at)wmconnect.c Guest
Posted: Mon Jun 16, 2008 9:01 am Post subject: Tie Down Point |
I ran into the same problem. I just moved it down one hole and put an L angle doubler behind the rib inline with the tie down holes to make up for the lost rivet. [quote][b]
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Mon Jun 16, 2008 5:24 pm Post subject: Re: Tie Down Point |
I don't see the problem with where it is located. All ya do with it is thread a rope through to attach it to the earth. I would leave it alone or call Zenith for an explanation.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
austria
Posted: Tue Jun 17, 2008 9:33 am Post subject: Re: Tie Down Point |
I solved the problem in this way.
Franz
1.4 MB |
1161 Time(s) |
Ianrat
Posted: Wed Jun 18, 2008 4:04 am Post subject: Re: Tie Down Point |
austria your idea looks good. I think that i will look into it.
Thank you
Ianrat
w8n2bup
Joined: 09 Apr 2008 Posts: 20 Location: Kansas City Area
Posted: Wed Jun 18, 2008 5:50 am Post subject: Re: Tie Down Point |
Roger at Zenith, has noted this before and said you can move it up one hole and then drill out three holes (every other) and put in 3/8 bolts and lock nuts. I chose to do this also because I had to put a spacer in to bring the tie down even with the precut slot and the rivets would not have been long enough.Also, these three bolts are stronger than all the rivets would have been.
Gig Giacona
Posted: Wed Jun 18, 2008 7:18 am Post subject: Re: Tie Down Point |
Precut slot for the tie-down. Really? Boy, you QBK guys have it easy.
| w8n2bup wrote: | | Roger at Zenith, has noted this before and said you can move it up one hole and then drill out three holes (every other) and put in 3/8 bolts and lock nuts. I chose to do this also because I had to put a spacer in to bring the tie down even with the precut slot and the rivets would not have been long enough.Also, these three bolts are stronger than all the rivets would have been. |
601XL Under Construction
Ianrat
Posted: Thu Jun 19, 2008 4:05 am Post subject: Re: Tie Down Point |
Not quick build! the standard kit now has most parts pre cut / formed and drilled. What a great kit.
Ianrat
Gig Giacona
Ianrat
Posted: Fri Jun 20, 2008 4:44 am Post subject: Re: Tie Down Point |
That about all you need. May be a maker pen!
w8n2bup
Posted: Mon Jun 23, 2008 5:31 am Post subject: Re: Tie Down Point |
Correction to my tie down ring response. I said I used (3) 3/8 bolts. I meant (3) 3/16 bolts.
