Tie Down Point
Ianrat
PostPosted: Mon Jun 16, 2008 6:25 am    Post subject: Tie Down Point Reply with quote
The pre-drilled tie down point in the main wing looks to be to low down.
If you use the pre drilled holes the bottom of the tie down ring will be inside the wing sheeting. Is this the way every one has done it or have you moved it out one hole.
Ianrat
Tie Down Ring
 Filesize:  700.16 KB
 Viewed:  1235 Time(s)
Davcoberly(at)wmconnect.c
PostPosted: Mon Jun 16, 2008 9:01 am    Post subject: Tie Down Point Reply with quote
I ran into the same problem. I just moved it down one hole and put an L angle doubler behind the rib inline with the tie down holes to make up for the lost rivet. [quote][b]
Ron Lendon
PostPosted: Mon Jun 16, 2008 5:24 pm    Post subject: Re: Tie Down Point Reply with quote
I don't see the problem with where it is located. All ya do with it is thread a rope through to attach it to the earth. I would leave it alone or call Zenith for an explanation.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
austria
PostPosted: Tue Jun 17, 2008 9:33 am    Post subject: Re: Tie Down Point Reply with quote
I solved the problem in this way.
Franz
 Filesize:  1.4 MB
 Viewed:  1191 Time(s)
Ianrat
PostPosted: Wed Jun 18, 2008 4:04 am    Post subject: Re: Tie Down Point Reply with quote
austria your idea looks good. I think that i will look into it.
Thank you
Ianrat
w8n2bup
PostPosted: Wed Jun 18, 2008 5:50 am    Post subject: Re: Tie Down Point Reply with quote
Roger at Zenith, has noted this before and said you can move it up one hole and then drill out three holes (every other) and put in 3/8 bolts and lock nuts. I chose to do this also because I had to put a spacer in to bring the tie down even with the precut slot and the rivets would not have been long enough.Also, these three bolts are stronger than all the rivets would have been.
Gig Giacona
PostPosted: Wed Jun 18, 2008 7:18 am    Post subject: Re: Tie Down Point Reply with quote
Precut slot for the tie-down. Really? Boy, you QBK guys have it easy. Smile
W.R. "Gig" Giacona
601XL Under Construction
Ianrat
PostPosted: Thu Jun 19, 2008 4:05 am    Post subject: Re: Tie Down Point Reply with quote
Not quick build! the standard kit now has most parts pre cut / formed and drilled. What a great kit.
Ianrat
Gig Giacona
PostPosted: Thu Jun 19, 2008 10:29 am    Post subject: Re: Tie Down Point Reply with quote
Wow... they have changed a bunch of stuff. Do you still need a drill and shears to build the kit? Smile
Ianrat
W.R. "Gig" Giacona
Ianrat
PostPosted: Fri Jun 20, 2008 4:44 am    Post subject: Re: Tie Down Point Reply with quote
That about all you need. May be a maker pen!
w8n2bup
PostPosted: Mon Jun 23, 2008 5:31 am    Post subject: Re: Tie Down Point Reply with quote
Correction to my tie down ring response. I said I used (3) 3/8 bolts. I meant (3) 3/16 bolts.
