air gizmo power plug
pbuttles(at)charter.net
PostPosted: Sun Apr 13, 2008 7:06 pm    Post subject: air gizmo power plug Reply with quote
anyone with a air gizmo with a garmin,what did you use for power plug to the garmin?
i dont know what to use to get the power to it without running cables in front
thanks everone for the throttle info .
Tracy
craig(at)craigandjean.com
PostPosted: Sun Apr 13, 2008 8:16 pm    Post subject: air gizmo power plug Reply with quote
My 296 fits fine with the cable shown in the attached picture. This is the older "396" dock before Air Gizmos redesigned it to accommodate the extra cable on the 496. The p/n of the cable I use is 010-10513-00. It ends in bare wires. Info here:
https://buy.garmin.com/shop/shop.do?pID=1083
-- Craig
 Filesize:  107.55 KB
 Viewed:  365 Time(s)
 Filesize:  105.39 KB
 Viewed:  365 Time(s)
 Filesize:  86.62 KB
 Viewed:  354 Time(s)
 Filesize:  90.44 KB
 Viewed:  357 Time(s)
notsew_evets(at)frontiern
PostPosted: Mon Apr 14, 2008 3:01 am    Post subject: air gizmo power plug Reply with quote
I have the Gizmo with my 296. I had to cut the stock power cord and run it
to a switch. Power panel to switch and then to Garmin.
I did the switch because the Garmin will not shut off on its own. If you
forget, you get a dead battery after a week in the hangar.
SW
PostPosted: Mon Apr 14, 2008 4:10 am    Post subject: air gizmo power plug Reply with quote
I did the switch because the Garmin will not shut off on its own. If you forget, you get a dead battery after a week in the hangar.
You can configure the 296 to turn off when external power is lost. Look under Setup, the "System" tab and "External Power Off". Choose "Turn Off" or "Stay On". Likewise for "External Power On" you can choose "Charge Battery" or "Turn On".
-- Craig
jmaynard
PostPosted: Mon Apr 14, 2008 4:59 am    Post subject: air gizmo power plug Reply with quote
Am I the only one getting a bunch of these?
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
PostPosted: Mon Apr 14, 2008 5:36 am    Post subject: air gizmo power plug Reply with quote
Me ? Read the instructions ???
Huh ?
SW
