Holding Nose up
Goto page 1, 2  Next
challgren(at)mac.com
PostPosted: Wed Jan 16, 2008 9:15 am    Post subject: Holding Nose up Reply with quote
Andy Shontz:
You asked;
"One thing, it appears as though on landing the nose comes down pretty
quick. I think other people have noted this one their XLs as well. Is
it fairly difficult to hold the nose up once the mains hit?"
I assume the XL is similar to the HDS and it was impossible to hold
the nose up on ours after touchdown. We solved that problem by
placing VG's on the bottom side of the horizontal stabilizer. With
the VG's there, you could aerodynamic brake down to about 20 mph.
Your other question:
" I was thinking a tail skid of some sort might be a good idea when I
get around to building the fuselage, to not only protect the fuselage
but also the rudder."
The HDS had a very effective tail skid in the tie down ring. I
discovered how effective it was when I failed to ask my BFR check
pilot how much he weighed. I had planned on 170# and after grinding
down the tail skid on takeoff I found he weighed 240#.
Stan
p.s. Let the flames began.
professor71(at)HOTMAIL.CO
PostPosted: Wed Jan 16, 2008 1:06 pm    Post subject: Holding Nose up Reply with quote
I have an HD which has a more similar wing to the XL and find that holding the nose up is not difficult if you come in at a little higher speed.
Stan I am interested in the HDS wing and wondered if you also put vgs on the wing and what kind of differences did you notice in climb and stall speeds.
Make distant family not so distant with Windows Vista® + Windows Live™. Start now! [quote][b]
daveaustin2(at)primus.ca
PostPosted: Wed Jan 16, 2008 3:59 pm    Post subject: Holding Nose up Reply with quote
John,
You'll find the details of my flight test with VGs on my 601 HDS in the archives. They are well worth the money.
Dave Austin 601HDS - 912, Spitfire Mk VIII
amyvega2005(at)earthlink.
PostPosted: Wed Jan 16, 2008 5:12 pm    Post subject: Holding Nose up Reply with quote
Stan,
it depends on how you place the main gear position, flat side forward and what engine weight you have. I put my mains flat side forward and can hold the nose off at 25 mph. I powered it with the 180lb jabiru so it works out well that way. if you endine is lighter say a 912 ULS, they recommedn the mains at flat side rear facing.
Juan
vgstol(at)bigpond.net.au
PostPosted: Wed Jan 16, 2008 7:36 pm    Post subject: Holding Nose up Reply with quote
For info on the HDS wing with VGs have a look at http://www.stolspeed.com/content.php?id=57
JG
Terry Phillips
PostPosted: Wed Jan 16, 2008 9:57 pm    Post subject: Holding Nose up Reply with quote
Dave
I have searched the Matronics Zenith-list archives for this w/o success. I guess that I just cannot find the right search string. Or perhaps I should be searching some other archive. Could you post a URL that would direct me to the thread containing the details cited below?
Thanks for your help.
Terry
At 06:53 PM 1/16/2008 -0500, you wrote:
John,
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 slow build kit - Tail is finished; working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
ashontz
PostPosted: Thu Jan 17, 2008 2:15 pm    Post subject: Re: Holding Nose up Reply with quote
Thanks. Interesting adaptation. I'll keep that in mind when I get to the fuselage. I'd like to be able to hold nose off and be in better control of things and aerodynamically brake the way I learned in a Cessna 152. Just seems right to me. Plus, if I ever NEED to keep the nose up, like a short or soft-field landing, I'll be able to do it.
challgren(at)mac.com wrote:
Andy Shontz:
You asked;
Stan
PostPosted: Thu Jan 17, 2008 5:39 pm    Post subject: Holding Nose up Reply with quote
i am able to hold the nose off up to apprx. 20 mph. with full back stick. tail skiid for a cessna works well if you tend to flare too much.
Juan
Terry Phillips
PostPosted: Sat Jan 19, 2008 8:51 pm    Post subject: Holding Nose up Reply with quote
Stan
Thank you very much for your post. No flames here. I think you're onto something good.
It really got me to thinking about the aerodynamics of the horizontal stabilizer. Please indulge me while I ramble about this.
ZAC told me that the stabilizer airfoil is symetrical. Since the stabilizer exerts a downward force to balance the moment of the engine around the aircraft cg, the symetrical airfoil must be angled slightly downward to generate a downward force with neutral trim. After touchdown, with the nose up, the stabilizer would be angled upward, generating an upward force that would rotate the A/C around the mains, pushing the nose down. So, to hold the nose up after touchdown, you would need to pull the stick aft, forcing the elevator up. And, what Stan is saying, is that VGs on the underside of the stabilizer will increase up-elevator effectiveness (apparently) by reducing boundary layer separation on the bottom of the elevator. That all makes sense to me now.
So, I would like to ask Stan the usual questions, how many VG's? Where are they on the stab? Do you have any photos? Thank you for posting your experience.
This is a very interesting subject.
Terry
-----Original message-----
Date: Wed, 16 Jan 2008 10:33:29 -0700
To: Zenith List zenith-list(at)matronics.com
Subject: Holding Nose up
Andy Shontz:
You asked;
Stan
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
planecrazydld(at)yahoo.co
PostPosted: Sun Jan 20, 2008 4:18 am    Post subject: Holding Nose up Reply with quote
do not forget that the stabilizer's primary job is balancing the pitching moment of the airfoil. This why trim changes occur with loading and speed.
Terry Phillips <ttp44(at)rkymtn.net> wrote:[quote] --> Zenith-List message posted by: "Terry Phillips"
Stan
Terry
[quote] --> Zenith-List message posted by: Stanley Challgren
Andy Shontz:
You asked;
discovered how effective it was when I failed to ask my BFR check [quote][b]
PostPosted: Sun Jan 20, 2008 8:44 am    Post subject: Holding Nose up Reply with quote
Dave,
the VGs may be all well and good, i dont know much bout the effects of the VG in back to comment on that , however the hold of nose is mostly a CG effect. not just the weight but where the main wheels are. There are two ways the mains can go on an XL mians forward or back. if the mains are on and fix in position, just put some weight in tail. Does not have to be much.
I suggest trying that first. put a small 2 lb weight to the rear, first, then cruise down the runway, and adjust the weight until front nose wheel comes off at 25 mph plus.
Juan
PostPosted: Sun Jan 20, 2008 8:47 am    Post subject: Holding Nose up Reply with quote
to clarify, I do not have the nose sticking issue on my XL. Mine comes off at 20 mph approx. It is a weight issue. you need to adjust weight to the rear or adjust the main wheels forward.
Juan
dredmoody(at)cox.net
PostPosted: Sun Jan 20, 2008 9:24 am    Post subject: Holding Nose up Reply with quote
Your idea of adding a bit of weight far aft to help un-stick the nose wheel needs to be factored into weight and balance to see how much you are moving the CG. However, if it makes the plane un-stick more appropriately the chances are that the CG will be well inside the envelope since the mains are still in the design location.
A second thought is that if someone needs to add any weight that far back, it would be useful to do so in the form of a more robust tail skid, particularly since the operational affect would be to make a tailstrike more likely.
Just thinking out loud,
Dred
tonyplane(at)bellsouth.ne
PostPosted: Sun Jan 20, 2008 11:27 am    Post subject: Holding Nose up Reply with quote
Speaking ONLY for my XL; N493TG. (Serial Number 6-5342) - I can not hold the
nose up after landing.
1. Particulars:
A. Empty weight :799; empty CG 290 mm (My XL is probably one of the
heaviest empty - It has aux tanks, lighting/strobes all around, 6x600
tires/wheels/brakes with an 801 nose fork; dual sticks, and a lot of "stuff"
on the panel (EFIS, EIS, AP, T&B,Comm,Xpndr, AS/Atl steam gauges etc).. It
has a
purring Jab3300 and a ground adjustable Sensenich.
B. To "slightly" exceed aft cg (without baggage) would require zero
fuel and crew weight of about 540 lbs. To exceed fwd CG would require about
a 110 lb
pilot with full fuel (48 gal) at take-off. To exceed the CG limits, I would
have
to be extremely negligent. ((I did refuse to fly a 280# teen age "Young
Eagle". I weigh about 200/210 and still had a lot of fuel on board (over
gross) and an OAT of 94F
- We got him a ride in a twin that day)).
C. Trim required during cruise - a little nose up with one SOB, no
wing heaviness, roll trim slight to either side depending on fuel state,
passenger wt.
D. My landing gear was installed with the then build instructions,
which put the wheels further aft than the current build instructions, which
reverses the landing gear relative to mine, and places the wheels closer to
the CG. (GOOD!)
E. My elevator trim tab is the smaller one, not the current almost
full elevator span one. My full flaps can go to around 27/28 deg - I
believe I
read that the current flap actuator only provides 20 deg. I can not hold
approach speed with trim (I like to use 65 kts on final until over the
fence/trees) with flaps (flaps result in a significant nose down pitching
moment).
F. Total flight hours on 3TG to date: 343. Total: TO/LDG: 672
2. On 3TG's first flight at zero trim, full fuel,.zero flaps, I was going
to just let the airplane lift off, but when I was still stuck to the ground
at 70 kts, I applied back pressure and was airborne. I believe that 3TG
could possible use all the runway and not lift off without some "up"
elevator.
First landing was zero flaps -3TG flew like.... an airplane- no surprises.
3. As soon as 3TG touches, the nose comes down even with full aft stick.
As the nose is coming down, I release back pressure. If I do not release
back pressure, the nose will sometimes bounce- height of bounce depends on
sink rate.
If my speed is a "little" high at touch down and if I keep full up stick,
the nose
will bounce up higher and come down again and bounce again.
I usually use partial to mainly full flaps (depending on
cross wind/soft field), but landing without flaps is easier, in my opinion.
4. In my experience, with my XL, with its gear arrangement: THING TO
AVOID DURING LANDING!!
AVOID a high sink rate landing - low or high airspeed. The nose will bounce
you up dratimatically.
GO AROUND is recommended or the second bounce will be nasty.
If you get too slow close in, you increase your sink rate and pitch
authority will not help much in the flare -
recommend squeeze in some power to arrest sink and also so you have some
energy to flare
Tony Graziano
N493TG
Subject: Re: Holding Nose up
Date: Sun Jan 20 - 9:24 AM
Dred
PostPosted: Sun Jan 20, 2008 1:18 pm    Post subject: Holding Nose up Reply with quote
a while back there was a lot of discussion about main gear spring placement. Zenith advised back then that there are 2 correct placements: straight edge aft and straight wedge forward, depending on the installed engine weight. If your CG is correct and the nose falls through after touchdown - and the straight edge of the gear spring as aft, then reverse it to put the straight edge forward. If it already is straight edge forward then be very careful in adding weight aft and be certain to do all the possible W&B trade studies to be absolutely certain that you are going aft of the limit.
Aft CG (even within the limits) makes it VERY easy to overload ANY aircraft as they are a lot more responsive in pitch when CG is aft.
All a fwd CG usually does is cause the plane to stall faster - and it makes the plane "groove" more therefore less likely to respond to enthusiastic pitch control inputs.
Edward Moody II <dredmoody(at)cox.net> wrote:[quote] Your idea of adding a bit of weight far aft to help un-stick the nose wheel needs to be factored into weight and balance to see how much you are moving the CG. However, if it makes the plane un-stick more appropriately the chances are that the CG will be well inside the envelope since the mains are still in the design location.
Dred
PostPosted: Mon Jan 21, 2008 9:38 am    Post subject: Holding Nose up Reply with quote
On Jan 19, 2008, at 9:48 PM, Terry Phillips wrote:
Stan
Terry:
How many VG's? I believe there were 42 VG's on each side. I used the
same spacing and template on the underside of the stabilizer as I did
on the wing so there would have been about 2.5" between them. They
were placed at 10% of the chord. The below photos are of the wing.
Guess my neck was already stiff from working upside down applying them
so I skipped the photos.
Stan
Any Photos?
 Filesize:  105.64 KB
 Viewed:  511 Time(s)
 Filesize:  80.82 KB
 Viewed:  500 Time(s)
Terry Phillips
PostPosted: Tue Jan 22, 2008 10:57 pm    Post subject: Holding Nose up Reply with quote
Hi Paul
'Sorry it has taken so long to answer. I've been visiting my daughter in
Seattle. I forgot to take the charger for my laptop, so I've been
incommunicado for the past 4 days.
The way I visualize this, is that, ideally, the horizontal stabilizer
should be installed so that, at cruise with neutral trim and elevator, it
exerts a downward force that just balances the moment exerted by the heavy
weight of the engine at the front of the aircraft. I think that would be
the minimum drag design. ZAC told me that the zodiac stabilizer was
symmetrical--an inspection of the drawings would tell me the same thing, if
I was clever enough to look. So, I think, that, if the stabilizer was
parallel to the airstream flowing aft of the wings at cruise, then it would
not produce a force up or down. Since, in tractor designs, the function of
the stabilizer is to balance the weight of the engine up front, then the
stabilizer must be angled slightly upwards w.r.t. the airstream. Then, just
like when you angle your hand upward out the window of a moving car, it
would generate the required upward force. Since an airplane in flight will
rotate around the cg, the balancing moment must be w.r.t. the cg.
When the airplane touches down on the mains, the nose (hopefully) will be
upward. If the nose is high (relative to cruise angle of attack) then the
tail will be low, and the horizontal stabilizer will be making an upward
angle with respect to the airflow past the airplane. Thus (I think) that
the air flowing past the stabilizer will be pushing the stabilizer upward,
driving the nose wheel to the ground.
The elevator, of course, is designed to bend the air flow so that, by
pulling back on the stick, the force exerted by the stabilizer/elevator can
be changed from the upward force that would exist with a neutral elevator,
to a net downward force. But, if I interpret Stan's results correctly, the
unmodified zodiac elevator is incapable of holding the nose up after touch
down. But, Stan's addition of VGs to the underside of the stabilizer,
increased the effectiveness of the elevator on Stan's airplane. Then he
could hold the nose up until he slowed to 20 mph.
So that's what it looks like to me.
My understanding of VGs is that they function by causing the laminar
boundary layer over an airfoil to transition to a turbulent boundary layer.
Turbulent boundary layers (for reasons I do not understand) stay attached
better than laminar boundary layers. And by staying attached, the airflow
over the airfoil exerts a net lower pressure on the bottom of the
stabilizer/elevator (think Bernoulli's law), thus effectively pulling the
tail down (and the nose up).
There are a couple of other effects in play here.
One is that, on the ground, the plane will rotate around the mains, rather
than around the cg. The cg is forward of mains, so the moment arm of the
stabilizer around the center of rotation is shorter when the plane is on
the ground. So moment from the force produced by the stabilizer will be
less than the moment produced by the same force when the plane is flying.
So, on the ground, a greater downward force is needed to raise the nose
than when flying.
The second is that, when the plane is flying, the wings must cause the
airstream aft of the wings to deflect downward (to balance the upward lift
on the wings). So, the horizontal stabilizer sees an airstream that has a
net downward velocity. If the horizontal stabilizer is to generate a net
upward force at cruise, then it must be inclined upward at a great angle
than would be necessary if the airflow were horizontal. On the ground, the
wings still try to deflect the air flow downward. But the ground is in the
way. So the airstream the horizontal stabilizer/elevator sees will be
flowing nearly parallel to the ground. The horizontal air flow on the
ground should further increase the upward force generated by the horizontal
stabilizer.
So, why is Stan's result important to me, since zodiac's have been landing
just fine for years, plunking their nose down on the runway right after
touch down? One reason would be soft field takeoff and landing capability.
In a 152, a skilled pilot can land on the mains, and keep the nose up,
until, maybe 20 mph or less. And with full up elevator one can taxi a 152
with the nose way up in the air, thus reducing the nose wheel loading. I'd
like to be able to imitate that with my zodiac on some of the back country
airfields here in western Montana. So, I think Stan's result is pretty
exciting.
First I have this airplane to build!
Terry
At 04:09 AM 1/20/2008 -0800, you wrote:
Hi Terry,
I'm confused. Why does touching down change the force generated by the
stabilizer from downward to upward? Do you experience a huge difference
in control feedback when the wheels touch down?
If the VGs have any impact at all on this phenomenon, it must be because
the VGs generate lift in the negative direction for the stabilizer. That
way the lift would be reduced as the airspeed and ground speed are reduced
during landing. I don't see how this is possible since the stabilizer has
a positive angle of attack after touchdown. However, the combined
stabilizer and elevator must have a negative total force on the airplane's
tail for the nose to be elevated on landing.
Maybe I'll just stay confused.
Paul
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Terry Phillips
PostPosted: Tue Jan 22, 2008 11:50 pm    Post subject: Holding Nose up Reply with quote
Whoops--got that backwards. The stabilizer generates a downward force, so
must be angled downward at neutral elevator and trim. What can I say--I'm a
geometrically challenged chemical engineer--that's why I'm not an ME. I
think I'll go to bed and try to rethink my reply in the morning.
Terry
At 11:46 PM 1/22/2008 -0700, you wrote:
Hi Paul
if I was clever enough to look. So, I think, that, if the stabilizer was
would not produce a force up or down. Since, in tractor designs, the
function of the stabilizer is to balance the weight of the engine up
front, then the stabilizer must be angled slightly upwards w.r.t. the
airstream. Then, just like when you angle your hand upward out the window
of a moving car, it would generate the required upward force. Since an
airplane in flight will rotate around the cg, the balancing moment must be
w.r.t. the cg.
can be changed from the upward force that would exist with a neutral
elevator, to a net downward force. But, if I interpret Stan's results
correctly, the unmodified zodiac elevator is incapable of holding the nose
up after touch down. But, Stan's addition of VGs to the underside of the
stabilizer, increased the effectiveness of the elevator on Stan's
airplane. Then he could hold the nose up until he slowed to 20 mph.
layer. Turbulent boundary layers (for reasons I do not understand) stay
attached better than laminar boundary layers. And by staying attached, the
airflow over the airfoil exerts a net lower pressure on the bottom of the
than when flying.
exciting.
Terry
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
psm(at)att.net
PostPosted: Wed Jan 23, 2008 3:46 am    Post subject: Holding Nose up Reply with quote
Hi Terry ,
Thanks for writing. I too am a retired challenged engineer, but my
field was electronics rather than those funny little chemical
things. (Actually, I started majoring in chemistry but managed to
screw that up -- but that is another story for another
day.) Fortunately, the area I am challenged in is not geometry --
especially when it comes to visualizing airplane dynamic
balances. (When I broke my relationship with the chemistry
department, I changed my major to Mathematics.)
Yes, the forces exerted by the stabilizer and elevator are generally
downward. Only when you push on the stick is there an upward force
from the elevator, and you don't tend to do that often. I figure
that means the leading edge of the stabilizer should be slightly down
compared to the trailing edge. I haven't yet set my stabilizer in
place so I am not sure how the design calls out this angle.
If you use tricycle gear configuration then the main wheels must be
behind the airplane's CG. If not, the tail will slide along the
runway rather than the nose gear meeting the runway. When landing,
the transition from controlling rotation around the CG to rotation
around the main wheels happens as you described nicely in your fist
message yesterday. Since the forces were in balance and probably
nicely trimmed out just before touching down it is the amount of
nose-down force caused by the relationship between the CG and the
main wheels that makes this whole story work. If the main wheels are
too far behind the CG then the nose will come crashing down as the
weight of the plane is transferred from the wings to the
wheels. This problem is more pronounced if the CG is at the front
end of the envelope.
You can spend a lot of time getting the CG to work for flying
conditions, and this has little impact on the behavior of the plane
when the wheels are holding the plane up. It is more important that
the flying stability is correct than the landing dynamics are
comfortable. That means (to me) that the way to correct the landing
situation is to move the wheels rather than moving the CG. For this
tendency that some (not all) Zodiacs seem to have to force the nose
down quickly on landing the solution seems to be to move the main
wheels forward. I don't know how much movement is needed, but the
first step is to mount the main gear with the flat edge forward to
make the wheels move a little forward of the position they would have
if the flat edge is mounted facing aft. If this isn't enough to fix
the landing difficulty then it starts getting a lot harder to change
the plane to get nicer landing behavior.
The other side of the main wheel vs. CG question comes in when you
have 250 pound folks standing on the step behind the wing to get into
the plane. If the wheels are positioned nicely for the landing
dynamics to work out then the plane will tend to drop to its tail
when the big guy (or gal) tries to get in. As with chemical and
electrical engineering, airplane design is a game of trade-offs.
I hope this discussion helps us understand the landing issue. My
plan is to use the flat side of the main landing gear mounted forward
and hope for the best.
Good luck,
Paul
force, so must be angled downward at neutral elevator and trim. What
can I say--I'm a geometrically challenged chemical engineer--that's
why I'm not an ME. I think I'll go to bed and try to rethink my
Terry
Terry Phillips
PostPosted: Wed Jan 23, 2008 10:44 am    Post subject: Holding Nose up Reply with quote
Paul
Thank you for the post. This is all starting to make much more sense to me.
And the discussion has proven to me, once again, a truism from my working
days. Only by explaining something, giving a talk, whatever, do I really
begin to understand it. I learn even more when I get it wrong the 1st time.
I have read many posts on this forum about which way the landing gear
should face. Now, finally, I'm beginning to understand what the discussion
is all about.
And, now I see that VGs on the underside of the stabilizer, can delay the
low speed stall of the stabilizer airfoil that occurs at high angle of
attack (i.e., nose up upon landing). Thanks Paul, Stan, Tony, and all who
responded. I think I can build a better airplane now, and, stabilizer VGs
will be part of it. I think I'll head for the shop and see if it has warmed
up from this morning's low of 34°.
Terry
At 03:40 AM 1/23/2008 -0800, you wrote:
Hi Terry ,
Thanks for writing. I too am a retired challenged engineer, but my field
things. (Actually, I started majoring in chemistry but managed to screw
that up -- but that is another story for another day.) Fortunately, the
area I am challenged in is not geometry -- especially when it comes to
visualizing airplane dynamic balances. (When I broke my relationship with
the chemistry department, I changed my major to Mathematics.)
downward. Only when you push on the stick is there an upward force from
the elevator, and you don't tend to do that often. I figure that means
the leading edge of the stabilizer should be slightly down compared to the
trailing edge. I haven't yet set my stabilizer in place so I am not sure
If you use tricycle gear configuration then the main wheels must be behind
the airplane's CG. If not, the tail will slide along the runway rather
than the nose gear meeting the runway. When landing, the transition from
controlling rotation around the CG to rotation around the main wheels
happens as you described nicely in your fist message yesterday. Since the
forces were in balance and probably nicely trimmed out just before
touching down it is the amount of nose-down force caused by the
relationship between the CG and the main wheels that makes this whole
story work. If the main wheels are too far behind the CG then the nose
will come crashing down as the weight of the plane is transferred from the
wings to the wheels. This problem is more pronounced if the CG is at the
front end of the envelope.
You can spend a lot of time getting the CG to work for flying conditions,
and this has little impact on the behavior of the plane when the wheels
are holding the plane up. It is more important that the flying stability
is correct than the landing dynamics are comfortable. That means (to me)
that the way to correct the landing situation is to move the wheels rather
than moving the CG. For this tendency that some (not all) Zodiacs seem to
have to force the nose down quickly on landing the solution seems to be to
move the main wheels forward. I don't know how much movement is needed,
but the first step is to mount the main gear with the flat edge forward to
make the wheels move a little forward of the position they would have if
the flat edge is mounted facing aft. If this isn't enough to fix the
landing difficulty then it starts getting a lot harder to change the plane
The other side of the main wheel vs. CG question comes in when you have
250 pound folks standing on the step behind the wing to get into the
plane. If the wheels are positioned nicely for the landing dynamics to
work out then the plane will tend to drop to its tail when the big guy (or
gal) tries to get in. As with chemical and electrical engineering,
I hope this discussion helps us understand the landing issue. My plan is
to use the flat side of the main landing gear mounted forward and hope for
the best.
Good luck,
Paul
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Goto page 1, 2  Next
Page 1 of 2
