Firestar I question
jindoguy(at)gmail.com
PostPosted: Sun Jan 13, 2008 7:38 am    Post subject: Firestar I question Reply with quote
I'm getting the Firestar ready for its certification inspection and I'm curious about the leading edge tubes that stick out of the wing root about a foot. Any idea what they do? I'd just as soon cut them off and plug them, but not if they actually have a purpose. TIA.
Rick
planecrazzzy
PostPosted: Sun Jan 13, 2008 9:17 am    Post subject: Re: Firestar I question Reply with quote
I use mine to keep the wing secure in the transport mode....
Gotta Fly...
Mike & "Jaz" in MN
PS I would also like to secure them to each other in flight for a little
extra strength...
 Filesize:  61.78 KB
 Viewed:  551 Time(s)
 Filesize:  56.93 KB
 Viewed:  547 Time(s)
 Filesize:  55.24 KB
 Viewed:  543 Time(s)
vincenic1(at)embarqmail.c
PostPosted: Sun Jan 13, 2008 10:40 am    Post subject: Firestar I question Reply with quote
Rick,
I find the tube extensions useful when folding and unfolding the wings.
I trailer my plane each time it is used and use a tripod to support the
unfolded wing prior to inserting the pins. The tripod supports the
outer end of the wing and the tube extension supports the front edge of
the wing by resting on the top of the full enclosure. Makes the folding
and unfolding a one-man job. Also, the extension is used in the folded
plane to tie the wings together.
Vince Nicely
Firestar II 503 DCDI 465 hours
Rick
Dana
PostPosted: Sun Jan 13, 2008 2:39 pm    Post subject: Firestar I question Reply with quote
I've seen Kolbs both with and without the extensions. My Ultrastar has the
extensions, and there's another section of tubing that slips over them and
joins them together when the wings are unfolded. Whether that piece is
actually necessary I don't know, it should stiffen the wings a bit and it
also helps to support the fabric center gap seal (clear plastic, actually,
on mine). IIRC it's not shown that way on the drawings, though. I've
never flown the plane without it, but I figure it can't hurt.
-Dana
Question Authority and the authorities will question you!
gaman(at)att.net
PostPosted: Sun Jan 13, 2008 5:44 pm    Post subject: Firestar I question Reply with quote
Those leading edge extensions are real handy if you fold and unfold regularly.if you have the long windshield installed,the tubes rest on the "U" frame so you can rest the tip of the wing on the ground and walk to the fuselage to install the pin.With out them,you must support the wing leading edge as you work your way to the cage to install the pins.The dihedral will not allow the extensions to line up to tie them together easily.
Dana Hague <d-m-hague(at)comcast.net> wrote:[quote] --> Kolb-List message posted by: Dana Hague
[quote]I'm getting the Firestar ready for its certification inspection and I'm
a foot. Any idea what they do? I'd just as soon cut them off and plug [quote][b]
ElleryWeld(at)aol.com
PostPosted: Sun Jan 13, 2008 6:00 pm    Post subject: Firestar I question Reply with quote
My gap seal hooked to the tubes your talking about cutting off, if it wer me I would take advantage of all the uses of them and not cut them off.
Holding wing in place while installing pins, and a good place to secure the wings in a trailer, or on a open trailer, I use them to secure the wings when I hauled it down the road tail first without a trailer, but its your plane have fun trying to find another handy tool built in that makes life easier with a Kolb or cut them off and come up with alternative ways to do what they can do for you.
its your decision have fun with it
Ellery in Maine
Start the year off right. Easy ways to stay in shape in the new year.
Dana
PostPosted: Sun Jan 13, 2008 7:55 pm    Post subject: Firestar I question Reply with quote
The Ultrastar is different, the extended tubes actually make it _more_
difficult to unfold the wings, since the pivot point is at the main spar
and not the rear... the rear fitting is its own support as you lift the
wingtips up. There's so little dihedral (if any) that slipping the splice
tube into place is no problem.
-Dana
Nowadays only a lawyer can tell legal from illegal, and the lawyers don't
know the difference between right and wrong.
