Steve Boetto
Posted: Sat Dec 22, 2007 5:35 am Post subject: Mission Specific |
Click here: 20 Aqualane Dr, Winter Haven, FL 33880, USA - Google Maps
150 feet, Glassy Water, No Pig Here
My Playground, Notice all the lakes and also Lakeland Airport to the west. Click on the map link above.
By the Way, Very few aircraft of any kind can be off and gone in 150' on Glassy water.
Steve B
Firefly 007/Floats
See AOL's top rated recipes and easy ways to stay in shape for winter.
Description: |
Filesize: |
18.87 KB |
Viewed: |
372 Time(s) |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Dec 26, 2007 10:27 am Post subject: Re: Mission Specific |
That a great environment you have out there for your plane.
If I had more lake around here in SoCal I'd also put on floats but I worry about landing on land with a power out on floats.
Any idea what would happen if you did?
Perhaps a mono float setup that I had been thinking about would allow me to keep my wheels.....problem is always the weight thought being part 103 and even the Max gross weight of the design.
What is the max part 103 allowance for floats?
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Dana
Posted: Wed Dec 26, 2007 2:33 pm Post subject: Mission Specific |
At 01:27 PM 12/26/2007, jb92563 wrote:
Quote: | If I had more lake around here in SoCal I'd also put on floats but I worry
Seaplane pilots I know don't worry about putting down on land; the floats
just slide... could even be better than puttling wheels down on soft ground.
Quote: | What is the max part 103 allowance for floats?
30 lbs per float, 10 lbs for each outrigger float.
-Dana
"Gold cannot always get you good soldiers, but good soldiers can always
get you gold"-- Niccolo Machiavelli
Steve Boetto
Posted: Wed Dec 26, 2007 6:07 pm Post subject: Mission Specific |
In a message dated 12/26/2007 5:34:23 P.M. Eastern Standard Time, d-m-hague(at)comcast.net writes:
Quote: | Seaplane pilots I know don't worry about putting down on land; the floats
-Dana
Thanks Dana that sounds right although if you have a mono you might get a few more pounds for the main float. as far as in the rough landings, I would rather have those big collapsible gear under me.
Dana
Posted: Wed Dec 26, 2007 6:39 pm Post subject: Mission Specific |
At 09:07 PM 12/26/2007, N27SB(at)aol.com wrote:
Quote: | 30 lbs per float, 10 lbs for each outrigger float. Thanks Dana that sounds right although if you have a mono you might get a few more pounds for the main float. as far as in the rough landings, I would rather have those big collapsible gear under me. |
As far as I can see, there is no mention of mono floats, just "30 lbs per float". In the case of flying boats, it's still 30# (plus the 10 for each outrigger).
I like the idea of the mono float for the US, to keep the spray off the prop. One thought I had was two floats (so you get the 60#) very close together, with a solid web between (almost like a tunnel hull racing boat). You could still add outrigger floats if necessary.
I still think I'd rather go into, say, a plowed field with non amphibious floats than straight wheels. There are quite a few videos on youtube of seaplanes landing (and even taking off!) on wet grass.
-Dana
The only correct outcome to an armed robbery attempt is a dead armed robber. [quote][b]
Steve Boetto
Posted: Thu Dec 27, 2007 7:20 am Post subject: Mission Specific |
In a message dated 12/26/2007 9:39:59 P.M. Eastern Standard Time, d-m-hague(at)comcast.net writes:
Quote: | I like the idea of the mono float for the US, to keep the spray off the prop. One thought I had was two floats (so you get the 60#) very close together, with a solid web between (almost like a tunnel hull racing boat). |
Ray,
EP Dalton in KEY West offers a splash guard for the quicksilver Sprint 2 just as you described
Steve
Firefly 007/Floats
Description: |
Filesize: |
29.39 KB |
Viewed: |
379 Time(s) |
Steve Boetto
Posted: Thu Dec 27, 2007 7:25 am Post subject: Mission Specific |
Dana,
This is a shot from a few years ago of the Factory Xtra flown by Bryan Melborn on Boetto/Melborn Experimental Amphib Floats. Kolbs look great on Floats.
Steve
Firefly 007/Floats
Description: |
Filesize: |
21.54 KB |
Viewed: |
362 Time(s) |
Steve Boetto
Posted: Thu Dec 27, 2007 7:39 am Post subject: Mission Specific |
-Dana |
Dana, Have you done any water flying, There is a major difference in Seaplanes (MonoHull) and Floatplanes.
Water Handling
Looks
Flight qualities
I personally like the look of a Floatplane and everthing that goes with it. Mono floats added to land plane tend to look Goofy.
Rare photo of Ultrastar on floats
Quote: |
Steve
Firefly 007/Floats
Description: |
Filesize: |
30.69 KB |
Viewed: |
359 Time(s) |
Dana
Posted: Thu Dec 27, 2007 10:16 am Post subject: Mission Specific |
At 09:44 AM 12/27/2007, N27SB(at)aol.com wrote:
Water Handling
Looks
Flight qualities
Rare photo of Ultrastar on floats...
That DOES make a nice looking floatplane!
Sadly, I have done no float flying, other than as a passenger years ago, and a number of R/C seaplanes over the years. I'd like to change that though... and the airport I'm currently flying from is right on the river and has a seaplane ramp. I agree that a mono float would look goofy on a high wing plane, but with the twin float spray shield it wouldn't be an issue (i.e. there'd be no point to a mono float). I'd be interested to know how the Ultrastar behaved on floats... quite well, I imagine.
-Dana
Can I deduct last years taxes as a bad investment? [quote][b]
Steve Boetto
Posted: Thu Dec 27, 2007 6:01 pm Post subject: Mission Specific |
In a message dated 12/27/2007 1:17:48 P.M. Eastern Standard Time, d-m-hague(at)comcast.net writes:
Quote: | I'd be interested to know how the Ultrastar behaved on floats... quite well, I imagine.
-Dana
According to my friend it was very quick off the water and flew very nice.
