Gear Legs wheel replacement
rv9jim(at)juno.com
PostPosted: Mon Oct 22, 2007 11:14 am    Post subject: Gear Legs wheel replacement Reply with quote
Dave,
What you do is to remove the pant. next, you remove the nut plate
adapter from the nut leaving a (I believe a 11/16") hole. You put a
pipe, about 12 to 15" long into the hole and put a jack on the end of the
pipe. Jack the wheel up and then remove the nut (hopefully you pulled
the key and loosened it a bit before you jacked it up) and slide the
wheel outward on to the pipe. Once the wheel is removed far enough, you
put a stand under the axle and let the jack down. Remove the wheel and
pipe and do what ever.
I modified my axle nuts to do this in the future. There is not a
good way to do tire repair or what ever with the fairings in place. I
did not relish lifting the a/c at the wing. Its a cheep mod. A piece of
pipe and a small jack with a jack stand is all you need.
Jim
n616tb(at)btsapps.com
PostPosted: Mon Oct 22, 2007 11:38 am    Post subject: Gear Legs wheel replacement Reply with quote
The problem I had with this method was the height of the pipe to the floor.
I didn't have a jack that would get under it. Even my floor jack was too
low so I went with the avery system. Both use the same principle however
and it works great.
[quote] --
altoq(at)cebridge.net
PostPosted: Mon Oct 22, 2007 12:23 pm    Post subject: Gear Legs wheel replacement Reply with quote
Dave,
I got this somewhere. Whoever came up with it should realy get the credit
but I don't know who that is. It seemed simple enough to duplicate that's
what I planed to do.
John D.
 Filesize:  26.72 KB
 Viewed:  662 Time(s)
 Filesize:  59.86 KB
 Viewed:  697 Time(s)
 Filesize:  66.52 KB
 Viewed:  738 Time(s)
 Filesize:  99.91 KB
 Viewed:  705 Time(s)
 Filesize:  122.02 KB
 Viewed:  719 Time(s)
mike109g6(at)insideconnec
PostPosted: Mon Oct 22, 2007 12:53 pm    Post subject: Gear Legs wheel replacement Reply with quote
Brown tools or Avery sells it. I just saw it.
Mike H
kahuna
PostPosted: Tue Oct 23, 2007 5:14 am    Post subject: Gear Legs wheel replacement Reply with quote
Yes,
Works as advertised. I got one of these a week ago and was able to easily change a tire with no swapping of jacks, blocks and so forth.
While its an expensive little bugger, im hoping between my use and loaning out to buddies, it will pay for itself.
No reason why it would not work on all kinds of planes too. The pipe in the axle method requires a hollow axle. This gismo does not.
Link to site here that sells the "handy Jack". Site d/l time is ridicules for some reason.
http://aviationtechproducts.com/html/products_pics.html#RVJACK
Best,
[img]cid:1__=08BBF9EEDFD47C958f9e8a93df938(at)us.ibm.com[/img]"John D. Heath" <altoq(at)cebridge.net>
[img]cid:3__=08BBF9EEDFD47C958f9e8a93df938(at)us.ibm.com[/img]
To
<rv-list(at)matronics.com> [img]cid:3__=08BBF9EEDFD47C958f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: Gear Legs wheel replacement [img]cid:3__=08BBF9EEDFD47C958f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF9EEDFD47C958f9e8a93df938(at)us.ibm.com[/img]
Dave,
John D.
[attachment "jack00215go6.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1270.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1271.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1272.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1273.jpg" deleted by Michael W Stewart/Atlanta/IBM]
 Filesize:  105 Bytes
 Viewed:  11324 Time(s)
 Filesize:  1.23 KB
 Viewed:  11323 Time(s)
 Filesize:  45 Bytes
Dale Ensing
PostPosted: Tue Oct 23, 2007 5:57 am    Post subject: Gear Legs wheel replacement Reply with quote
I sense a reluctance by some to use a wing jack. I have been using a wing jack on my 6A since day one. Is there a problem with wing jacks on RVs that I may not be aware of.
Dale Ensing
 Filesize:  105 Bytes
 Filesize:  45 Bytes
 Viewed:  11325 Time(s)
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
PostPosted: Tue Oct 23, 2007 6:07 am    Post subject: Gear Legs wheel replacement Reply with quote
I use them every time I fly. Without lifting my wings it would be no fun; plus I would probably hit the fence. <grin>
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing
Sent: Tuesday, October 23, 2007 8:57 AM
To: rv-list(at)matronics.com
Subject: Re: Gear Legs wheel replacement
Dale Ensing
 Filesize:  105 Bytes
 Viewed:  11322 Time(s)
 Filesize:  73 Bytes
 Filesize:  73 Bytes
dale1rv6(at)comcast.net
PostPosted: Tue Oct 23, 2007 8:39 am    Post subject: Gear Legs wheel replacement Reply with quote
I have been using a wing jack, but am going to change to the cable/lever type on axel. If sh__ happens it will be less to repair. Accidents are never planned, right?
Happy landings,
Dale
Sent: Tuesday, October 23, 2007 9:57 AM
Dale Ensing
 Filesize:  73 Bytes
 Filesize:  73 Bytes
 Filesize:  105 Bytes
joelhaynes
PostPosted: Thu Oct 25, 2007 1:11 pm    Post subject: gear legs wheel replacement Reply with quote
If your plane is nose heavy when picked up by the jack points I would sure
double check my weight and balance. I am not saying either way because I
don't know, but it would seem a little forward. Of course with a pilot in
there it would be different. Were the tanks full?
You want your airplane to be nose heavy when you jack it up by the jack points. That means the CG is where it is supposed to be. Remember aerodynamics 101: the wings lift and the tail gets pushed down in flight.
Joel Haynes
RV-7A N557XW
Bozeman, MT Email and AIM finally together. You've gotta check out free AOL Mail!
panamared5(at)brier.net
PostPosted: Fri Oct 26, 2007 5:28 am    Post subject: gear legs wheel replacement Reply with quote
Huh??(at)*&??
I have been jacking my RV up for five years at the tiedown points and
never has the tailwheel left the ground.
I must be violating aerodynamics 101, of course I do not believe that
Bernoulli was right!
RV6 "Wicked Witch of the West"
Bubblehead
PostPosted: Fri Oct 26, 2007 8:13 am    Post subject: Re: Gear Legs wheel replacement Reply with quote
I'm not sure why Bob with the RV-6 has not had a problem, although maybe an RV-6 is different in this way.
I think my cg is right where it needs to be. I looked at my weight and balance charts and found out:
The main gear wheels are at 68.76"
CG of plane, no pilot, with half fuel is 77.8. Since this is aft of the mains and forward of the tail wheel the plane sits fine on the ground.
Since the fuel cg is at 80", and the jacking location is aft of the fuel, I would guess the tie down/jacking hole is about 85" aft of datum. I'm not at the airplane so am just guessing at this.
Since the jacking position is between the cg and tail wheel, it takes load off the tail wheel and will ultimately lift if off the ground.
Keller, TX
RV-8 N247TD
T.gummo(at)verizon.net
PostPosted: Fri Oct 26, 2007 9:44 am    Post subject: Gear Legs wheel replacement Reply with quote
It is a non-problem if you do one wing at a time. It is when you do both
that the tail comes up.
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
pcowper(at)webtv.net (Pet
PostPosted: Sun Oct 28, 2007 10:19 am    Post subject: gear legs wheel replacement Reply with quote
"I have been jacking my RV up for five years at the tiedown points and
never has the tailwheel left the ground."
Does your hanger face into a headwind?!!
Pete Cowper
RV-8 #81139 (working on fuselage)
