RobHickman(at)aol.com Guest
Posted: Tue Sep 04, 2007 1:00 pm Post subject: Lancair Panel |
Has anyone installed one of the Lancair panels with the Throttle quadrant?
I am looking for pictures of one.
Rob Hickman
N402RH RV-10 Finish Kit.
AOL.com.
scottmschmidt(at)yahoo.co Guest
Posted: Tue Sep 04, 2007 1:42 pm Post subject: Lancair Panel |
Here are a few. Let me know if you want more offline. I moved the console back about 1" from what
the stock setting is to give my hand more room between the throttle and dimmer knobs. This
also meant all new custom cables for the throttle.
Scott Schmidt
scottmschmidt(at)yahoo.com
77.41 KB |
442 Time(s) |
63.82 KB |
449 Time(s) |
71.47 KB |
428 Time(s) |
54.24 KB |
409 Time(s) |
AV8ORJWC
Posted: Tue Sep 04, 2007 6:12 pm Post subject: Lancair Panel |
Scott Schmidt has and it’s a beauty. I will forward a shot direct to your email address. Scott can give more details.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RobHickman(at)aol.com
Sent: Tuesday, September 04, 2007 1:57 PM
Subject: Lancair Panel
Rob Hickman
AOL.com.
[quote] [b]
Mike Whisky
Posted: Wed Sep 05, 2007 11:33 am Post subject: Re: Lancair Panel |
Scott,
where can I order the cables for throttle, Mixer and Prop to the length required?
I use the center console from Henkjan so this puts the throttle at least 3 inches back. I also had to construct new mounts for the throttle quadrant (see attached CAD pictures).
Michael
www.wellenzohn.net
52.61 KB |
389 Time(s) |
61.67 KB |
425 Time(s) |
827.84 KB |
476 Time(s) |
_________________ RV-10 builder (flying)
#511 |
rv10(at)sinkrate.com Guest
Posted: Wed Sep 05, 2007 1:29 pm Post subject: Lancair Panel |
Michael,
John Cox has offered several builders assistance in getting custom cables
made. Check with him.
On another note...
In looking at your panel mockup in one of the pictures it appears we are
planning a very similar panel. Are your paper printout instruments to
scale? How did you do that? If the graphics are already to scale that you
have can you email me the files to print maybe?
-Ben
Portland, OR
#40579
wcurtis(at)nerv10.com Guest
Posted: Wed Sep 05, 2007 5:10 pm Post subject: Lancair Panel |
Michael,
Based on the position of your avionics stack you may want to check the clearance with the middle bracket. The depth of the Garmin 430 with connector is 11 inches and if you leave your stack in that position, you would have to cut a LOT of the middle bracket away. The Garmin 330 is also lengthy at 11.5 inches. The distance between the instrument panel and the middle panel is 9.5 inches. For this reason, I left the middle bracket untouched and put my avionics stack just to the right of it.
http://wcurtis.nerv10.com/91Panel/index.html
http://wcurtis.nerv10.com/08fuselage/fuselage31s.html
William
Posted: Wed Sep 05, 2007 5:16 pm Post subject: Lancair Panel |
Lancair supplied me with a few different panel designs and I then started taking pictures off the Internet, imported them into Photoshop and started laying different ideas out.
I used Photoshop to reduce different pictures from the Internet.
I think my final version with Lancair was v.14 by the time I was finished.
Scott Schmidt
Posted: Wed Sep 05, 2007 5:19 pm Post subject: Lancair Panel |
What I did was hook up the cables that Van's sent me to the engine side and then measured the additional length I would need to tie them into the throttle quadrant.
I called Van's direct and they took the old cables back, and ordered new custom cables. They said it could be 4 weeks but showed up in about 10 days.
Scott Schmidt
AV8ORJWC
Posted: Wed Sep 05, 2007 6:21 pm Post subject: Lancair Panel |
Scott’s approach is not unlike that used by Jim Hergert in his national award winning N6XE (Sexy). Once your conceptual plan is developed, put it to construction board or thin gatorboard and begin working the ergonomics and functional reach issues. A few hours conceptually flying your conceptual panel will save hundreds in actual installation and years of flying enjoyment.
I believe Tim could even chime in on how many iterations he used to get it right. It doesn’t hurt opening the discussion to a handful of close friends to find potential weaknesses in design.
Don’t forget serviceability after you put down your manufacturer hat.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Wednesday, September 05, 2007 6:15 PM
Subject: Re: Re: Lancair Panel
Scott Schmidt
----- Original Message ----
Sent: Wednesday, September 5, 2007 3:25:37 PM
Subject: RE: Re: Lancair Panel
--> RV10-List message posted by: "Ben Westfall" <rv10(at)sinkrate.com>
Michael,
On another note...
-Ben
Portland, OR
#40579
Tim Olson
Posted: Wed Sep 05, 2007 6:48 pm Post subject: Lancair Panel |
I got mine right the first time. I just threw all the photo cutouts
down and cut the holes where they landed. Actually, I think
I went through something like 26 revisions on the PC, bouncing
them off a few experts in the process, just getting the ergonomic
concepts developed. Then, I made the 100% full-scale cutouts
and cut a cardboard panel with all screw holes traced in proper
location, and cut it out to fit in the plane. Then, I worked
to 1/16" resolution moving the cutouts around to verify clearance
from screws, nutplates, ribs, edges, overlapping pieces, and everything
that could get in the way, to ensure that what I was dreaming up
would actually fit, and fit in the closest to perfect location
that I could find. (i.e. trying to do things like keeping the EFIS
screens as high up on the panel as possible, and trying to keep
the radio stack as high up as possible without interfering with
the center rib) Once I had everything on cardboard in position
with proper clearances, I placed the cardboard in position in
the plane with the upper fwd fuselage installed, and installed
cushions on the seats and everything so my seated height
would be about right. The rudder pedals were put in also, to
ensure that I was seated in a close approximation to where I'd
really be while flying. Then, I verified that it all felt right,
and all switches were in locations I was happy with, and that
they wouldn't interfere with movements, that some were immediately
accessible (fuel boost, flaps, ...) with hands on the throttle.
So 26 computer-based revs, and then probably only 1 or 2 major
revs on cardboard, but with oodles of time spent tweaking positions
and some minor layouts. At that point, it was THEN a
"got it right the first time" job when I went to cut metal. At
this point, I couldn't be happier with the layout, and people
who have had the opportunity to sit and fly behind it seem to
like how it came together.
It's definitely the part of the plane you want to spend the most
time thinking about. There's NO other piece of the plane that
you'll spend more time looking at, touching, and utilizing
than the panel.
John W. Cox wrote:
[quote] Scott’s approach is not unlike that used by Jim Hergert in his national
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Scott Schmidt
*Sent:* Wednesday, September 05, 2007 6:15 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Re: Lancair Panel
Scott Schmidt
ron.mcgann(at)baesystems. Guest
Posted: Wed Sep 05, 2007 7:20 pm Post subject: Lancair Panel |
I used a similar strategy to Tim, but used plexi instead of cardboard.
The instruments were installed in the plexi and I could easily see any
obstructions behind the panel. Once everything fit and felt right -
panel cuttin' time. Result is an ergonomic solution with 3 GRT screens
and backup steam gauges with no mods required to the F-1044 or F-1045
ribs.
Ron
187 finishing (does it ever end?????)
Mike Whisky
Posted: Wed Sep 05, 2007 10:50 pm Post subject: Re: Lancair Panel |
Thanks for the advice guys,
I actually just pinned some pictures of my desired avionics on the panel to get a more realistic feel while making plane noises
I am currently designing my panel also in the 3D CAD system but once I have a virtually solution I will transfer it into scale pictures and put it into the cockpit. I had to wait until I can sit in the plane to really feel the distance and ergonomics.
I bought the VP-200 and in Osh and now have to see where I will put it.
Maintenance accessibility is important, how many times did you guys (flying) had to open the tunnel so far and what for?
Michael
Since I got some requests about the avionic stack pictures I attached the file for printout. However I don´t know if this is to scale because it is a Visio file originally.
www.wellenzohn.net
1.02 MB |
455 Time(s) |
#511 |
john_rv10(at)yahoo.com Guest
Posted: Fri Sep 07, 2007 11:49 am Post subject: Lancair Panel |
Rob,
The attached photo of an early Lancair panel with a quadrant is from Tony Sustare of Accuracy Avionics.
Sent: Wednesday, 5 September 2007 6:57 AM
Rob Hickman
AOL.com.
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
47.8 KB |
463 Time(s) |
