Andair Fuel Valve
toaster73(at)earthlink.ne
PostPosted: Tue Aug 07, 2007 12:59 pm    Post subject: Andair Fuel Valve Reply with quote
Looked at the archives for some advice on which valve is the latest and greatest. SO what is the consensus these days on the model valve to go with and where is the best place to get one. Tim Olson, I think you mentioned if you did it over again you would utilize the universal joint out there no?.
Is the best mount setup to use extensions and mount the valve down in the tunnel or go for right up against the tunnel cover?
Looks like PN fs20x3 is the choice and have 90 deg elbow supplied by andair put on, but should I go with universal at both ends with 6inch ext.?
Chris Lucas
#40072
fuselage and mods (mods take time)
bldgrv10450(at)comcast.ne
PostPosted: Tue Aug 07, 2007 5:45 pm    Post subject: Andair Fuel Valve Reply with quote
Thanks for the meaningful questions about Andair. I am standing by to hear the feed back. The linkage sound like a good idea and I recall looking a one set-up with the fuel valve canted and moved forward just below the quadrant.
Paul Grimstad
RV10 40450
Portland, Or.
Tim Olson
PostPosted: Tue Aug 07, 2007 6:16 pm    Post subject: Andair Fuel Valve Reply with quote
Chris, I'm not 100% sure what valve would be best anymore because it's
been a LOOOOONG time now since I installed mine. I do think perhaps
the one that has the inlets at the 45 degree forward facing positions
would perhaps give better clearance than the one I used. The only
clearance issue is really the rudder cable area, and mine doesn't
contact it at all, but just requires some care to install well.
I can tell you this though. I'm 100% satisfied with going with that
Andair valve or any Andair valve. They're nice valves and I'd do it
again if I built another. I'm also 100% satisfied with using a
single flex line from the valve to the tank. I think that's the cat's
meow for routing.
As far as mounting the valve goes, if you put a swivel in it, I
think I'd only put one swivel in and mount the valve low in the
tunnel and put the swivel right on the valve so it's all stem to
the top. I have good reason for this. The way I have the valve
mounted (I don't have a swivel though) I was able to wrap the stem
in UHMW tape, and run the SCAT right through the area in the top
of the tunnel next to the valve. And, even if the stem touched
the SCAT, the tape prevents any wear. With a valve mounted up
high there, you'll have to squash and mash the SCAT tube
and force it to fit, or reduce it like some people have done.
Those are kind of hacked fixes IMHO, when you have the option to
mount the valve low and give plenty of room for the called-for SCAT.
I haven't seen the universal joint for a long time to remember how
tall it was, but my only concern with adding one would be that I
would want to leave at least 2 or 3" of stem at the top under the valve
to give clearance for that SCAT. Other than that, adding the
U-joint wouldn't be bad at all. The positive side is that with
that U-Joint you can be sloppier with the valve angle and mounting,
whereas I was required to have them line up fairly straight and
parallel to the tunnel cover surface, and cut the stem the exact
length so I could slide the stem in place, put the valve handle
over it, and tighten it down. I don't have a way to lock the
handle to the stem, given the install, but I worked hard to
make the fit as tight as possible so there's no way once the
handle is screwed down that it's coming apart. Much harder to
describe than to show in person. Either way, you will want to
order a 12" extension, because then you can cut one and if you
end up too short you have an entire spare half to re-cut one.
I don't know if the supplied elbow would be best, or if what I
did would be more compact, if you use the same valve as me.
I cut off the tip of the NPT threads, and used a die to cut
the threads a little further so that I'd shorten that stem
just another 1/16-1/8" to give a little clearance. That worked
well. But if the andair 90 is more compact, I'd go with that.
I couldn't get one easily when I was ordering. If you have
time to get the parts though, I'd look hard at the Left/Right
valve with the ports to the front on the 45's.
Good luck with it. It's working out great for me so far.
out there no?.
Chris Lucas
#40072
n8zg(at)bellsouth.net
PostPosted: Tue Aug 07, 2007 7:09 pm    Post subject: Andair Fuel Valve Reply with quote
Paul -
The FS20x3 valve has a 180-degree swing between left and right tanks, and is a VERY tight fit in the -10 tunnel. The FS20x7 series fits much easier and (I think) looks nicer. Reports from folks using the 6-inch extension have been positive, few have needed universal joints (one, that I know of). If you choose to use the extension, with a little care in fitting the lower mount plate, you can forego the universal joints (about $45 each).
As for sourcing, I'd recommend you go direct to Andair and order from the website. It will be faster, less expensive, and you're more likely to get exactly what you asked for. Be prepared - the exchange rate is painful...
You want the FS20x7T EXT...
FS = Fuel Selector
20 = Line Diameter in 0.5 mm increments (3/8" or AN6)
x = male output fitting (or F for Female)
7 = valve body style (7 indicates the two-port 90-deg swing body, Left at 335-, Right at 45- and off at 180-deg)
T = 90-deg male AN6 inlet fittings - more compact, fewer joints and less expensive than screwing AN6 90-deg adapters into female fittings.
EXT = 6-inch extension unles you specify something else (if memory serves)
Now, pay attention - The standard extension kit includes a black anodized bezel with engraving that results in "silver" lettering. If you want a "silver" (clear anodized aluminum) bezel with black and red lettered engravings, you need to specify that in the comments (or special instructions) section.
neal
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad
Sent: Tuesday, August 07, 2007 8:44 PM
Subject: Re: Andair Fuel Valve
Paul Grimstad
RV10 40450
Portland, Or.
LloydDR(at)wernerco.com
PostPosted: Wed Aug 08, 2007 5:05 am    Post subject: Andair Fuel Valve Reply with quote
I also used the Andair setup, just in Duplex form. Like Tim I would
recommend using the 12" extension, this makes it very easy to place the
valve at the bottom of the tunnel and freeing up allot of room for the
SCAT tubing to pass through.
You can see in the attached photos, specifically 134 what Tim was
talking about needing to get the valve level so that the extension will
pass through the upper whole in the tunnel. I made the bracket at the
bottom with a cross support that way I could use washers to adjust the
fore and aft angle on the extension.
In the 405 photo you can see the different fittings offered from Andair,
in hind sight there are several things I would have changed on my
original order from Andair, as it was a bit of trial and error in the
beginning. On their website http://www.andair.co.uk/ , the automated
configuration tool does not show all of the optional fittings in
building the valve, you have to call for these, but what I ordered was a
duplex and you will only need a single, but the important part is to go
to the accessories page and get the EF20 for your two side fittings and
then use the MF20 for your feed to the bulk head
http://www.andair.co.uk/system/index.html with these fittings installed
it makes it a very simple and clean install and you can use single
flared fittings at each location rather than having to use
adapters/elbows etc.
Hope this helps
Dan
N289DT RV10E Flying
 Filesize:  38.03 KB
 Viewed:  385 Time(s)
 Filesize:  156.17 KB
 Viewed:  409 Time(s)
rvbuilder(at)sausen.net
PostPosted: Wed Aug 08, 2007 5:45 am    Post subject: Andair Fuel Valve Reply with quote
Below is what I did using the valve Neal is talking about.  Works well.
http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&category=1703&log=15806&row=6
Michael Sausen
-10 #352 Limbo
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neal George
Sent: Tuesday, August 07, 2007 10:08 PM
Subject: RE: Andair Fuel Valve
Paul -
FS = Fuel Selector
neal
Paul Grimstad
RV10 40450
Portland, Or.
----- Original Message -----
From: toaster73(at)earthlink.net (toaster73(at)earthlink.net)
Sent: Tuesday, August 07, 2007 1:58 PM
Subject: Andair Fuel Valve
Chris Lucas
#40072
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com
ScooterF15
PostPosted: Wed Aug 08, 2007 5:48 am    Post subject: Andair Fuel Valve Reply with quote
Chris,
There will never be a consensus on any topic... except maybe that the RV-10 is the airplane of choice.
Mods do take time. Personally, I went with the standard Van's fuel valve. It works great. I did make one mod that allows for error-resistant (I won't claim error-proof) operation without having to look down. I put 2 screws with 1/4" aluminum tube spacers in the tunnel cover. I simply grab the screw and squeeze the lever until it lines up. For OFF you rotate the lever aft. Very simple. See attached picture.
-Jim
40134 - First annual taking longer than I'd like
In a message dated 8/7/2007 5:01:37 P.M. Eastern Daylight Time, toaster73(at)earthlink.net writes:
Chris Lucas
#40072
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
 Filesize:  36.71 KB
 Viewed:  387 Time(s)
 Filesize:  33.05 KB
 Viewed:  396 Time(s)
flysrv10(at)gmail.com
PostPosted: Wed Aug 08, 2007 6:32 am    Post subject: Andair Fuel Valve Reply with quote
You can also use the valve that comes withe the kit and purchase the Cleveland valve handle they make for RV10.  It looks nice and does not need any modifications.
Rob.
On Aug 7, 2007, at 4:58 PM, <toaster73(at)earthlink.net (toaster73(at)earthlink.net)> <toaster73(at)earthlink.net (toaster73(at)earthlink.net)> wrote:
Chris Lucas
#40072
rnewman(at)lutron.com
PostPosted: Wed Aug 08, 2007 12:07 pm    Post subject: Andair Fuel Valve Reply with quote
I need to weigh in on this one. I have an Andair valve installed in
our Glastar and we did have an issue with their Female Pipe Thread
inlets. I am installing an Andair valve in my RV-10 but with the
following note.
In the glastar, like the Rv-10, a 90 degree turn is needed after
exiting the valve. To do this we installed 90 elbows (AN822), AN flare
to male pipe thread. We had a terrible time getting the pipe threads
to seal with the proper clocking of the elbows. We tried many types of
sealant including the highly recommended Fuelube, Finally the only
thing that seemed to work was a product called Blue-Block which is much
more viscous than other sealants I've used and rated for gasoline. It
worked from 1999 till our conditional inspection in Nov of 2006. I
found that these fitting were still weeping fuel. I removed the
fittings and changed them over to the new modular 90 degree cast AN-6
series fittings that Andair now makes, thus completely eliminating the
tapered pipe thread connections from the system. (now flared AN
connections bolt right up to the Andair Valve heading in the right
direction).
The engineer in me though says, what caused these pipe threads to not
seal? Upon inspection of the old andair female pipe thread modular
adapters I noticed that the threads did not seem to be cut deep enough
into the part with respect to engaging the tapered thread. I believe
that this was causing the male pipe thread part (elbow) to bottom out
within the Andair part instead of allowing the joint to get suitably
tight by the tapered geometry.
So the lesson in my book is to check your fittings before assembly and
ensure they can fully engage.
On my RV-10 fuel valve I am using the one with the straight extension
and the cast 90 degree modular elbows.
Bob Newman
Tim Olson
PostPosted: Wed Aug 08, 2007 12:32 pm    Post subject: Andair Fuel Valve Reply with quote
You may have a point there. I *think* when I trimmed off the
nose of the fitting and re-cut more threads on that, that I
also pulled off the andair female NPT fittings (using the
4 screws), and used a tap to tap the threads slightly
deeper there too. I am not 100% sure of this as it's been
a while, but I believe that's the case. This allowed me
to thread the elbow closer and further into the valve.
It's not uncommon in dealing with some NPT stuff, so I didn't
maybe make as big a deal of it as some might. I just
prefer all my threaded fittings to fit with a few turns
holding them together. I do think those andair fittings
would be ideal if they can be used in the application though.
Also, I believe Neal had it right with the valve part number
that would be nicer to use than what I did. You guys building
later in the cycle are lucky to have such improvements. Gosh,
I almost wish I was still in the building process. Wink
following note.
direction).
Bob Newman
PostPosted: Wed Aug 08, 2007 7:02 pm    Post subject: Andair Fuel Valve Reply with quote
You are right Tim, I had the same issue, if a builder were to use the
female NPT fittings, and try to fit in 90degree elbows on both sides the
valve assembly would be too wide to fit in the tunnel, this was the
issue I ran into and is why I then had to order the fittings Andair had
with the 90 degree already in it, you could also use the banjo fittings,
that way you would get a full 180 degrees of movement for placing the
lines exactly where you wanted them.
Dan
