WillUribe(at)aol.com Guest
Posted: Wed Jul 18, 2007 11:13 am Post subject: Mushy control stick |
here is the old U-Joint.
36.42 KB |
491 Time(s) |
Posted: Wed Jul 18, 2007 11:59 am Post subject: Mushy control stick |
| wow! never knew there was a tiny U-Joint in there. Looked them up
in AC spruce.
| Paul Petty
Did you look at the prices???
_________________ John Hauck
Titus, Alabama |
JetPilot
Posted: Wed Jul 18, 2007 12:58 pm Post subject: Re: Mushy control stick |
| John Hauck wrote: | Mike:
The weakest, most flexible part of the Kolb wing is the bow tip. You
plan on turning the aileron counterbalance weight into a spade at the
weakest, most flexible point, outboard of the wing tip. Might want to
think on that a bit. Also, the counterbalance weight attachment was
not designed nor intended to have increased torsional loads.
All Kolbs inherently load up the ailerons at speeds over 50 to 60 mph.
You ain't gonna change that unless you cut the cord of the aileron in
half.
mkIII |
You are correct that it would put more stress on the bow tip, that could be a problem. The other answer would be to put a spade in the middle of the aileron underneath the wing, which is probably a better solution and gets rid of any unknowns like tip vorticies. Thanks for that advice, it will be a lot of extra work, but if I do this I will put standard spades in the middle of the ailerons.
I was wondering why my Kolb was heavy on the ailerons while Richard reports his to be light. I am cruising pretty fast with the 912-S, that is probably why they are stiffening up quite a bit.
Mike Bigelow
Kolb MK-III Xtra, 912-S |
Paul Petty
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Wed Jul 18, 2007 4:26 pm Post subject: Re: Mushy control stick |
| WillUribe(at)aol.com wrote: | here is the old U-Joint.
Get a sneak peek of the all-new AOL.com. |
Wonderful.. this is what's on my FS II's linkage... Mine's a pre-TNK FS II finished in 98.....
So, is this a joint that has hazards and needs replacement or ?
LS
_________________ LS
Titan II SS |
lucien
Posted: Wed Jul 18, 2007 4:39 pm Post subject: Re: Mushy control stick |
| jstewart(at)inebraska.com wrote: | Maybe take Kimberly's advice and reflex the ailerons a bit. That might help
a lot with the control forces.
J.D.
Hey JD,
I thought about it when I read Kimberly's post, but I'm actually used to the feel of it now and the plane flies perfectly the way it is.
I think the ailerons ride a hair bit up in the air already anyway... I'm going to look at that next time I'm up.
Sorry guys for the brief titan exchange - JD is the seller/builder/co-designer of my titan and builder extraordinaire...
LS
Titan II SS |
Richard Pike
Posted: Wed Jul 18, 2007 7:08 pm Post subject: Mushy control stick |
I think it is just not as precision as what they are currently using. On the
other hand, it only needs to work in a Kolb, not in a watch...
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
lucien
Posted: Wed Jul 18, 2007 7:18 pm Post subject: Re: Mushy control stick |
| Richard Pike wrote: | I think it is just not as precision as what they are currently using. On the
Richard Pike
Ok, just curious if it was an AD that I needed to call Kolb about or something like that...
The plane has about 500 hours on it and hasn't seemed to have problems with this joint, so I was just wondering if it was something that just hadn't been updated but needed to be.....
LS
Titan II SS |
ElleryWeld(at)aol.com Guest
Posted: Thu Jul 19, 2007 11:35 am Post subject: Mushy control stick |
I installed two of the new style U-Joints in my firestar when I rebuilt it a couple years ago and they are not cheap and not rubber coupled
Ellery, N447EB
Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [quote][b]
jindoguy(at)gmail.com Guest
Posted: Thu Jul 19, 2007 1:45 pm Post subject: Mushy control stick |
All, Go to McMaster.com page 1121. At the top of the page is a picture of several different u-joints. The one on the left is what you'd find if you cut off the protective bellows of that AN unversal joint. They have bellows for these and for a given size can save you a few bucks over ACS.
Rick
On 7/19/07, ElleryWeld(at)aol.com (ElleryWeld(at)aol.com) <ElleryWeld(at)aol.com (ElleryWeld(at)aol.com)> wrote: [quote] I installed two of the new style U-Joints in my firestar when I rebuilt it a couple years ago and they are not cheap and not rubber coupled
Ellery, N447EB
Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
