David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Sat May 26, 2007 1:15 am Post subject: The things you find on the hangar floor ! |
Now who was it that wanted a twin engine Kolb ?
Well OK, Not a twin but single engine driving twin props.
Interesting eh ?
David.
852.8 KB |
629 Time(s) |
d-m-hague(at)comcast.net Guest
Posted: Sat May 26, 2007 3:46 am Post subject: The things you find on the hangar floor ! |
At 05:15 AM 5/26/2007, David Lucas wrote:
Interesting... what is it, what's it for?
-Dana
Okay, who put a "stop payment" on my reality check?
Posted: Sun May 27, 2007 4:19 am Post subject: The things you find on the hangar floor ! |
Some innovative design work there. Nice engine mount. The engine is
from the Daimler smart car,
3 cyl, 4 stroke , ??HP The problems of redrive and harmonics are
well taken care of. Hard to transmit
harmonics of any magnitude back through a belt that long. In
addition the props are in cleaner
air than if directly behind or front of the engine. The tail boom
can be located directly behind the
cabin even in pusher mode.
looks like a kraut mind at work :}
BB
David Lucas
Posted: Sun May 27, 2007 4:41 am Post subject: Re: The things you find on the hangar floor ! |
Slick BB got it ! The engine was developed from the 'smart' city car, a 700cc 3 cylinder turbocharged engine producing around 80HP at 5250 RPM with a 2.1 : 1 reduction belt drive and its quiet ! http://www.ecofly.de/english.htm
Thought it might be quite suitable for a Kolb, but it's also quite pricey at around €11,000 = US$ 14,500. Their flight tests say it equals or outperforms the Rotax 912 in all phases of flight.
The twin prop drive idea is for a pusher design the same guy was developing with the props out in clean air. I've added a photo from a brochure so it's not too good quality, just FYI.
Now who was it that was going to put two engines on their Kolb ?
David.
272.52 KB |
553 Time(s) |
a58r(at)verizon.net Guest
Posted: Sun May 27, 2007 10:23 am Post subject: The things you find on the hangar floor ! |
Several? couple? years ago I wondered whether an engine from a
hybrid...either existing or a future one, would be suitable for a
small /fat Ul/sport. Pretty soon they'll be in junk yards. Still
thinking/wondering.
regards,
Bob N. FireFly 070 Old Kolb
Rick Nelson
Joined: 16 May 2007 Posts: 4 Location: Huntsville, AL
Posted: Sun May 27, 2007 11:32 am Post subject: The things you find on the hangar floor ! |
Me too. Specifically, I have wondered about the three cylinder, 1.0
liter Honda engine from the Insight. A 650cc version was used in the
Honda Beat, which was not available in the US. I can't find anything
on the web that lists the weight of either engine. The 1.3 liter four
cylinder used in the Honda Fit also looks interesting.
Rick Nelson
On 5/27/07, Bob Noyer <a58r(at)verizon.net> wrote:
thinking/wondering.
regards,
Posted: Mon May 28, 2007 4:11 am Post subject: the things you find on the hangar floor ! |
Mr Funk also designed this in 1984
Has a familiar look about it
BB do not archive
pastedGraphic
14.36 KB |
545 Time(s) |
