wiring up regulator, help!
n100rh(at)sbcglobal.net
PostPosted: Wed May 23, 2007 6:37 am    Post subject: wiring up regulator, help! Reply with quote
Uncle!
I must be a total retard, I am so confused by the wiring of my 914... help!
As back ground information, I have a Control Vision Corp. EXP BUS 2 with
two batteries.
The current (sic) problem is not understanding how to wire up the
regulator at points R, B+, C. And, what to do with the capacitor. What
size wire, wires? come out of R and B+.
Can anyone direct me to another reference other than the Rotax manual
Thanks, anyone know a good counselor ?
Ralph
jodel(at)nildram.co.uk
PostPosted: Wed May 23, 2007 7:51 am    Post subject: wiring up regulator, help! Reply with quote
Try Page 25-11 from the Europa manual available at
http://www.europa-aircraft.biz/pdfs/buildersmanuals/CBM%20-%2025%20-%20ELECT
RICAL%20SYSTEM.pdf
Simon
josok-e(at)ukolo.fi
PostPosted: Wed May 23, 2007 10:11 am    Post subject: wiring up regulator, help! Reply with quote
Hi Ralph,
If you have are using the rotax standard alternator regulator combination, the R, B+ and C termanals are to be connected together.
Also the capacitor +! goes there.
Jos Okhuijsen
Visit - www.EuropaOwners.org
nwcmc(at)tiscali.co.uk
PostPosted: Wed May 23, 2007 10:50 am    Post subject: wiring up regulator, help! Reply with quote
On request from another builder I produced a diagram for an ExpbusII. I
have slightly downsized the attachment to comply with the forum
restrictions. If anyone wants an original contact me off forum.
Nigel Charles
 Filesize:  257.37 KB
 Viewed:  313 Time(s)
hansjd(at)online.no
PostPosted: Wed May 23, 2007 10:57 am    Post subject: wiring up regulator, help! Reply with quote
Hi Ralph.
I had the same problem - 914/Expbus. Made contact with Nigel Charles - who
very kindly constructed my system.
It's based on the Expbus wiring diagram and built up to my specifications.
Nigel has since laid it out in the Europa Flyer (issue 45, June 2005).
If you don't have this magazine, I'm sure Nigel will send you a copy of the
diagram.
Hope this helps
Hans
PostPosted: Wed May 23, 2007 11:25 am    Post subject: wiring up regulator, help! Reply with quote
Oops,
I see what has been in front of me all along. It's tough having ADDS.
The schematic even show the proper wire size... oh well. Sorry, I will
try to have a much harder question next time.
Thanks again to all,
Ralph
josok wrote:
Hi Ralph,
Jos Okhuijsen
PostPosted: Wed May 23, 2007 4:30 pm    Post subject: wiring up regulator, help! Reply with quote
Hans and all,
Thanks very much for the help, I seem to be over my mental block and
moving forward again. This has always been such a great group people.
Ralph
Hans J. Danielsen wrote:
Hi Ralph.
who very kindly constructed my system.
specifications. Nigel has since laid it out in the Europa Flyer (issue
45, June 2005).
of the diagram.
Hope this helps
Hans
