chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sat May 05, 2007 9:28 pm Post subject: Bottom Rudder Bracket attachment |
Hi Gang
I am using the latest plans 03/06 and have a Q. On page 6-B-2 bottom LH coner , it shows a lower rudder hinge. Ths hing USED to have 2 3/16" bolts 2 A5 rivets and a tiedown bolt on it with a row of 4 X A5 rivets behind. (older plans) on my plans it shows the rivets next to the tiedown bolt as being replaced bu 2 more 3/16" bolts , but the top RH corner of that Hinge picture still shows 6 X A5 with only 4 ++++.
Should there be 6 A5 rivets in the back row or 4??? is the 6 a mistake? as the 2 A5 rivets in the next row are now bolts??
Chris
Down Under..
Jaybannist(at)cs.com Guest
Posted: Sun May 06, 2007 6:07 am Post subject: Bottom Rudder Bracket attachment |
Chris,
My plans (dated 08/05) show the 4 AN3-5A bolts plus the tie-down ring in the aft row and 4 + marks for rivets in the forward row; but a note that says "six rivets A5", pointing to the forward row. I just looked at mine and I have 6 rivets.
Somewhere in the Zenith documents, they tell you NOT to count + marks for rivets and to go with what is called out. I guess this is an example of what they were talking about.
Jay in Dallas
"chris Sinfield" <chris_sinfield(at)yahoo.com.au> wrote:
Hi Gang
Chris
Down Under..
http://forums.matronics.com/viewtopic.php?p=111113#111113
wa7dvd
Joined: 27 Oct 2006 Posts: 11 Location: Salt Lake City, Ut
Posted: Sun May 06, 2007 2:54 pm Post subject: Re: Bottom Rudder Bracket attachment |
I think the reference to 6 A5 rivets is a carry over from earlier sets of plans. I have three versions and it is there in the all three. I believe it is counting 2 in one row (now replaced with AN-3 bolts) and 4 in the other row. The construction photos in the guide clearly show four rivets in the second row of the finished aircraft.
I hope in only needs four on the back row because that is how mine is built.
BK Johnson
N601BK (reserved)
chris Sinfield
Posted: Fri May 11, 2007 1:35 pm Post subject: Re: Bottom Rudder Bracket attachment on XL |
Hi Gang
Got up in the middle of the night down here and rang Zenith about the wording of the 6 holes. Yes it is a mistake on the plans and there should only be 4 rivet holes in the second row behind the tiedown point.
The 6 will be replaced with 4 on the next plans update.
Chris
Down Under..
Posted: Fri May 11, 2007 3:04 pm Post subject: Bottom Rudder Bracket attachment |
MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Sat Feb 23, 2008 10:59 am Post subject: Re: Bottom Rudder Bracket attachment |
OK so assuming that the prints are incorrect on the number of A5 rivets it says 6, someone has confirmed with Zenith that the correct # is 4, is the number of bolts still 4 as indicated in the drawings? Two are shown in the manual.... Yes, I understand the drawings take priority over the manual and not to count the x's for rivets. Anybody mind taking a look at their QB kit? How is Zenith installing them these days?
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
Posted: Sat Feb 23, 2008 11:23 am Post subject: Bottom Rudder Bracket attachment |
Take a look at these shots of my QBK.
-- Craig
30.91 KB |
753 Time(s) |
38.34 KB |
763 Time(s) |
34.47 KB |
798 Time(s) |
31.45 KB |
821 Time(s) |
MHerder
Posted: Mon Feb 25, 2008 6:22 am Post subject: Re: Bottom Rudder Bracket attachment |
Thank you Chris, I appreciate your time spent taking your pictures.
I have been building for a few months now, everyone I've come across has been so helpful. I appreciate all of you out there who are willing to take some time to help others out. I wonder what it would be like if I wasn't building a Zenith? Without so many helpful folks I would still have a pile of aluminum in my garage. Now I have a pile of aluminum that is beginning to resemble a plane! I had a question that I wrote to Zenith the other day, Sebastian replied via email in less than 30 minutes! I couldn't believe it.
Though I am new to the list, I look forward to offering my experience and advice as I progress. At this point I only feel qualified to instruct others on the techniques of drilling out and replacing rivets .
Jabiru 3300
Finally Flying |
