Fuselage weight
jhasbrouck(at)woh.rr.com
PostPosted: Wed May 02, 2007 4:29 pm    Post subject: Fuselage weight Reply with quote
Question for anyone to answer: What is your best guess of the fuselage
weight with the cabin top and tail cone on but no interior or avionics? No
gear or engine mount either ( no finish kit yet ). Moving to the hangar
this weekend an trying to recruit enough help to load this bad boy. Best
guess is two guys each side and one on the tail would do it but the more the
merrier. Using a flat trailer. Suggestions?........john
John Hasbrouck
#40264
rene(at)felker.com
PostPosted: Wed May 02, 2007 4:53 pm    Post subject: Fuselage weight Reply with quote
I did it with 4 people. Back, front, side, side. And a fifth to move the
platform I used to build it on.
Rene' Felker
N423CF
40322
801-721-6080
jim(at)CombsFive.Com
PostPosted: Wed May 02, 2007 5:05 pm    Post subject: Fuselage weight Reply with quote
I just moved mine about a month ago. I had made a set of wheels and bolted them to the wing spars. My 16 year old sons and I rolled it onto a 18 foot trailer with 4 foot ramps. I don't have scales but I can pick up the front by myself. The CG in this configuration is somewhere around the front part of the rear seats.
I unloaded it from the trailer by myself at the airport. The wheels were great.
Picture is attached.
These are coming off in the next week or so for the real legs!
Jim C
N312F
40192
 Filesize:  118.66 KB
 Viewed:  467 Time(s)
jesse(at)saintaviation.co
PostPosted: Wed May 02, 2007 6:31 pm    Post subject: Fuselage weight Reply with quote
4 people. One on each gear leg, one on tail & one backup for where needed.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
352-427-0285
greytex
PostPosted: Wed May 02, 2007 6:49 pm    Post subject: Fuselage weight Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jim, I want to make something along the same lines. my QB will be here Fri or Sat . do you have a sketch or just deminsions and material used. would appreciate any help. Thanks
John Cram
40569 emp complete in the hanger and waiting
PostPosted: Wed May 02, 2007 7:17 pm    Post subject: Fuselage weight Reply with quote
I will put something together.
Jim C
Date: 2007/05/02 Wed PM 10:49:23 EDT
Subject: Re: Fuselage weight
John Cram
Vern(at)teclabsinc.com
PostPosted: Thu May 03, 2007 8:51 am    Post subject: Fuselage weight Reply with quote
Jim,
Thank you for an elegant solution. I was just thinking last night, how
am I going to move this thing around after the tail cone is attached?
What timing:)
Thanks again,
Vern Smith (#324 ready to attach tail cone)
greytex
PostPosted: Thu May 03, 2007 11:24 am    Post subject: Fuselage weight Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> jim, would you be interested in selling them when you install the mains. I am building in the Houston area.
PostPosted: Thu May 03, 2007 5:21 pm    Post subject: Fuselage weight Reply with quote
John,
Attached is a set of instructions.
Someone else may want to build a set.
How about we do this.
You pay the shipping and you can "Use" these. When finished they have to be provided to another -10 builder (Who also pays to have them shipped).
I will have to figure out how to box them up.
Provide me a "ship to" address (Off List!).
Jim Combs
40192
N312F
Date: 2007/05/03 Thu PM 03:23:41 EDT
WheelSet-Fuse.pdf
 Filename:  WheelSet-Fuse.pdf
 Filesize:  370.01 KB
 Downloaded:  419 Time(s)
