Amount of smooth prime to do job
n616tb(at)btsapps.com
PostPosted: Sat Apr 28, 2007 2:05 pm    Post subject: Amount of smooth prime to do job Reply with quote
Hi all,
I have researched the archives about sealing up / priming my cowl for my RV-6. As expensive as this stuff is, I am wondering if a quart would be enough. The ACS website says 3 gallons to do a plastic airplane but all I need to do is the cowl and maybe some fairings. Will a quart do it?
wgill10(at)comcast.net
PostPosted: Sat Apr 28, 2007 4:05 pm    Post subject: Amount of smooth prime to do job Reply with quote
Tim,
I tried Van’s “thinned epoxy” coatings, but the 24 hour wait before sanding can make this a loooong process; however, it works and it’s inexpensive. After three coats of the thinned epoxy, I became impatient and switched to a primer/filler product by PPG that can be sprayed or brushed on. Attached are a few pictures of the product and the results. I have no experience with the smooth prime product.
RV-7 FWF
Lee’s Summit, MO
 Filesize:  252.43 KB
 Viewed:  361 Time(s)
 Filesize:  222.48 KB
 Viewed:  381 Time(s)
 Filesize:  220.74 KB
 Viewed:  396 Time(s)
kboatright1(at)comcast.ne
PostPosted: Sat Apr 28, 2007 4:44 pm    Post subject: Amount of smooth prime to do job Reply with quote
A quart worked just fine for me and I was pleased with the results.
However, some folks in the Canard community have bad things to say about the product. Some have seen bubbling that they attribute to smooth prime. The theory is that the smooth prime holds moisture and the moisture causes bubbling under the finish coat. I think the current institutional knowledge with the canard guys and gals is to make sure you give smooth prime much more drying time than the instructions call for, and to make sure you store the parts in a dry (not humid) environment before painting.
KB
Oldsfolks(at)aol.com
PostPosted: Mon Apr 30, 2007 3:10 pm    Post subject: Amount of smooth prime to do job Reply with quote
The smooth prime goes a long way. Unless your cowl is worse that mine was , a quart should be enough.
Moral of the previous reply : STAY AWAY from plastic airplanes !!!
Bob Olds RV-4 N1191X
Charleston,Arkansas
See what's free at AOL.com.
cjensen(at)dts9000.com
PostPosted: Mon Apr 30, 2007 3:44 pm    Post subject: Amount of smooth prime to do job Reply with quote
Staying away from plastic planes in the RV is really quite easy...unless they throttle back. Smile
Chuck Jensen
Bruce(at)glasair.org
PostPosted: Mon Apr 30, 2007 4:13 pm    Post subject: Amount of smooth prime to do job Reply with quote
Good one, Chuck.
Bruce
www.glasair.org
