Interior paint
bob88
PostPosted: Fri May 17, 2013 12:51 pm    Post subject: Interior paint Reply with quote
I would like advice about painting the interior of RV10 cabin. Is a primer needed over Van's QB wash primer? Specific type of paint for finish coat? At what point in the build process is best for painting interior?
cooprv7(at)yahoo.com
PostPosted: Fri May 17, 2013 2:20 pm    Post subject: Interior paint Reply with quote
I used appliance epoxy spray can paint, no primer. It worked great, came out smooth and is holding up well after 7 years and 600 hours. Cheap and easy. I'd suggest as soon as you get the top on and panels installed is a good time.
Marcus
http://forums.matronics.com/viewtopic.php?p=400866#400866
rleffler
PostPosted: Fri May 17, 2013 2:29 pm    Post subject: Interior paint Reply with quote
The answer is, it depends. You'll need to consult with the top coat paint
vendor to see if the SW Wash Primer is ok or what appropriate action you'll
need to take. Each top coat paint has different requirements.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
rv10flyer(at)live.com
PostPosted: Fri May 17, 2013 3:02 pm    Post subject: Interior paint Reply with quote
I used Sherwin Williams home paint (VOC 0) its industrial strength- easy
clean up.. I applied microballons to the paint to make it thick and fill the
voids. With a thick roller it went on quite nicely. Cheap and easy touch-up,
although I haven't needed to.. Easy to clean after curing as well.
jeff(at)westcottpress.com
PostPosted: Fri May 17, 2013 3:13 pm    Post subject: Interior paint Reply with quote
I suggest you get at it before you install the rudder pedals, upper forward fuselage and the cabin top, as access to areas around the forward area of the floor is much easier at that point. Also, get the cabin top while it's off the plane and you can shoot down at it outside. I used a spatter paint called Zolatone, on a base of Loehle's black highbuild primer with the intention of keeping things light and not installing any upholstery anywhere other than the seats.
Jeff Carpenter
40304
 Filesize:  104.61 KB
 Viewed:  4809 Time(s)
 Filesize:  77.78 KB
 Filesize:  112.55 KB
woxofswa
PostPosted: Sat May 18, 2013 10:58 am    Post subject: Re: Interior paint Reply with quote
I used Stewart Systems primer and single part topcoat on the interior and had no problems. Very happy with the results and ease of use/cleanup.
Myron Nelson
Mesa, AZ
Flew May 10 2014
Mauledriver(at)nc.rr.com
PostPosted: Sat May 18, 2013 12:27 pm    Post subject: Interior paint Reply with quote
If you decide to put in Flightline's interior (I assume you aren't),
they provide some detailed information on what needs to be painted and
what will be hidden under the interior panels.
Checked by AVG - www.avg.com
