bob88
Posted: Fri May 17, 2013 12:51 pm Post subject: Interior paint |
I would like advice about painting the interior of RV10 cabin. Is a primer needed over Van's QB wash primer? Specific type of paint for finish coat? At what point in the build process is best for painting interior?
cooprv7(at)yahoo.com Guest
Posted: Fri May 17, 2013 2:20 pm Post subject: Interior paint |
I used appliance epoxy spray can paint, no primer. It worked great, came out smooth and is holding up well after 7 years and 600 hours. Cheap and easy. I'd suggest as soon as you get the top on and panels installed is a good time.
Marcus
On May 17, 2013, at 4:51 PM, "bob88" <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=400866#400866
rleffler
Posted: Fri May 17, 2013 2:29 pm Post subject: Interior paint |
The answer is, it depends. You'll need to consult with the top coat paint
vendor to see if the SW Wash Primer is ok or what appropriate action you'll
need to take. Each top coat paint has different requirements.
_________________ Bob Leffler
N410BL - Phase I
rv10flyer(at)live.com Guest
Posted: Fri May 17, 2013 3:02 pm Post subject: Interior paint |
I used Sherwin Williams home paint (VOC 0) its industrial strength- easy
clean up.. I applied microballons to the paint to make it thick and fill the
voids. With a thick roller it went on quite nicely. Cheap and easy touch-up,
although I haven't needed to.. Easy to clean after curing as well.
jeff(at)westcottpress.com Guest
Posted: Fri May 17, 2013 3:13 pm Post subject: Interior paint |
I suggest you get at it before you install the rudder pedals, upper forward fuselage and the cabin top, as access to areas around the forward area of the floor is much easier at that point. Also, get the cabin top while it's off the plane and you can shoot down at it outside. I used a spatter paint called Zolatone, on a base of Loehle's black highbuild primer with the intention of keeping things light and not installing any upholstery anywhere other than the seats.
Jeff Carpenter
40304
On May 17, 2013, at 1:51 PM, bob88 wrote:
104.61 KB |
4696 Time(s) |
77.78 KB |
4696 Time(s) |
112.55 KB |
4696 Time(s) |
woxofswa
Posted: Sat May 18, 2013 10:58 am Post subject: Re: Interior paint |
I used Stewart Systems primer and single part topcoat on the interior and had no problems. Very happy with the results and ease of use/cleanup.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Posted: Sat May 18, 2013 12:27 pm Post subject: Interior paint |
If you decide to put in Flightline's interior (I assume you aren't),
they provide some detailed information on what needs to be painted and
what will be hidden under the interior panels.
On 5/17/2013 4:51 PM, bob88 wrote:
Checked by AVG - www.avg.com
