RPM Generator
Etienne Verhellen
PostPosted: Tue May 14, 2013 7:19 am    Post subject: RPM Generator Reply with quote
Good morning All, Very Happy
I am looking for a RPM Generator for my Yak-52 ...
Do you have one by any chance ? Cool
Do you know where I could find one ?
I've tried all the usual suspects ... no luck so far. Sad
Are there any electronic ones I could fit ? Question Question
If you have a RPM Generator for sale, please contact me off-list :
janie(at)yak52.fr
Thank you very much.
PS : I have a brand new YAK PROPELLER V530 TA-D35
with Hoffmann Leading edges FOR SALE.
In original Russian Transport Box with Paperwork. SEE PHOTOS BELOW.
Contact me if you are looking for an immaculate 2 bladed paddle prop. janie(at)yak52.fr or
etienne.verhellen(at)ba.com
http://forums.matronics.com/files/corsair_oe_eas_and_yak_52_g_cbss_212.jpg
http://www.aerobuzz.fr/IMG/jpg/G-CBSS_Yak-52_38_Zoersel_180812.jpg
http://www.aerobuzz.fr/IMG/jpg/SDC10253.jpg
http://www.aerobuzz.fr/IMG/jpg/Corsair_Yak-52.jpg
http://ukga.com/images/content/image29581.jpg
_____________________________________________________________
FOR SALE.
 Filesize:  796.49 KB
 Viewed:  12214 Time(s)
FOR SALE, contact Etienne Verhellen, Belgium.
 Filesize:  824.34 KB
FOR SALE.
Contact :
etienne.verhellen@ba.com
 Filesize:  2.94 MB
 Filesize:  2.92 MB
 Filesize:  2.81 MB
 Filesize:  2.82 MB
GeorgeCoy
PostPosted: Tue May 14, 2013 7:35 am    Post subject: RPM Generator Reply with quote
Yes a good chance. I forwarded your request to my son Cliff. I believe he
has a serviceable one. It has been our experience that the problem is
usually a broken wire just behind the connector. If you have not
disassembled the connector, check it as a simple wire solder may solve our
problem.
George
Etienne Verhellen
PostPosted: Tue May 14, 2013 8:22 am    Post subject: Re: RPM Generator Reply with quote
Thank you very much George.
Can you please give me Cliff's e-mail address.
I will check the wiring behind the connector.
A quick remark :
I have received 3 offers for the big GSR-3000M Generator Unit ...
and a friend suggesting I replace the big and heavy Yak Generator by a 50 amp B&C alternator ... (probably a good idea !)
But just to confirm, I'm looking for the small DTA-2 Tacho-generator that drives the % RPM needle : see photo.
 Filesize:  7.32 KB
 Viewed:  12162 Time(s)
 Filesize:  7.32 KB
Etienne Verhellen
PostPosted: Wed May 15, 2013 5:07 am    Post subject: Re: RPM Generator Reply with quote
I have been informed by a very reliable source that the RPM generator for the Yak-52 is actually the DTE-6T.
See photo below : DTE-6T.
The DTA-2 Rpm generator is possibly from the Mi-2 helicopter ...
but I suspect it would work as well ...
Anyway, we have now found one and it will be installed on the aircraft
very soon. I'm sure Yak parts will be needed again in the future ... Wink
 Filesize:  275.31 KB
 Viewed:  12029 Time(s)
Yak-50 Display Pilot - Airshows - Яковлев Як-50
Yak-52 training anywhere - FI(A) Aerobatic Instructor - Specialised Yak-52.
https://www.yakoteam.com/
https://www.yakovlevs.com/the-team/pilots-and-crew/
Etienne Verhellen
PostPosted: Wed May 15, 2013 1:29 pm    Post subject: Re: RPM Generator Reply with quote
Another view of the DTE-6T RPM generator for Yaks ...
 Filesize:  1.42 MB
 Viewed:  11982 Time(s)
Rob Rowe
PostPosted: Thu May 16, 2013 4:28 am    Post subject: Re: RPM Generator Reply with quote
Etienne,
FWIW - the original equipment tach generator for the -52 is the DTE-2.
From the Russian documentation I have the suffix denotes the number of display units the generator can drive. Hence -2 allows it to drive both the front & rear displays in a -52. Accordingly for a -50 the standard fit is a DTE-1.
I've not seen a detailed spec for a DTE-6T to know whether this can be extrapolated, other than noting its use on Russian airliners where presumably the flight engineers display takes this total to at least 3. Other than that, from the limited info I've been able to find, it appears to have the same mechanical gearing & electrical voltage output as the other DTE devices.
Brgds, Rob
Etienne Verhellen
PostPosted: Sun May 19, 2013 7:11 am    Post subject: Re: RPM Generator Reply with quote
Rob, You know A LOT more about Yak tach generator than me !
Etienne.
