Etienne Verhellen
Posted: Tue May 14, 2013 7:19 am Post subject: RPM Generator |
Good morning All,
I am looking for a RPM Generator for my Yak-52 ...
Do you have one by any chance ?
Do you know where I could find one ?
I've tried all the usual suspects ... no luck so far.
Are there any electronic ones I could fit ?
If you have a RPM Generator for sale, please contact me off-list :
janie(at)yak52.fr
Thank you very much.
PS : I have a brand new YAK PROPELLER V530 TA-D35
with Hoffmann Leading edges FOR SALE.
In original Russian Transport Box with Paperwork. SEE PHOTOS BELOW.
Contact me if you are looking for an immaculate 2 bladed paddle prop. janie(at)yak52.fr or
etienne.verhellen(at)ba.com
http://forums.matronics.com/files/corsair_oe_eas_and_yak_52_g_cbss_212.jpg
http://www.aerobuzz.fr/IMG/jpg/G-CBSS_Yak-52_38_Zoersel_180812.jpg
http://www.aerobuzz.fr/IMG/jpg/SDC10253.jpg
http://www.aerobuzz.fr/IMG/jpg/Corsair_Yak-52.jpg
http://ukga.com/images/content/image29581.jpg
_____________________________________________________________
796.49 KB |
12108 Time(s) |
| FOR SALE, contact Etienne Verhellen, Belgium. |
824.34 KB |
12108 Time(s) |
FOR SALE. Contact : etienne.verhellen@ba.com |
2.94 MB |
12108 Time(s) |
2.92 MB |
12108 Time(s) |
2.81 MB |
12108 Time(s) |
2.82 MB |
12108 Time(s) |
GeorgeCoy
Posted: Tue May 14, 2013 7:35 am Post subject: RPM Generator |
Yes a good chance. I forwarded your request to my son Cliff. I believe he
has a serviceable one. It has been our experience that the problem is
usually a broken wire just behind the connector. If you have not
disassembled the connector, check it as a simple wire solder may solve our
problem.
George
Etienne Verhellen
Posted: Tue May 14, 2013 8:22 am Post subject: Re: RPM Generator |
Thank you very much George.
Can you please give me Cliff's e-mail address.
I will check the wiring behind the connector.
A quick remark :
I have received 3 offers for the big GSR-3000M Generator Unit ...
and a friend suggesting I replace the big and heavy Yak Generator by a 50 amp B&C alternator ... (probably a good idea !)
But just to confirm, I'm looking for the small DTA-2 Tacho-generator that drives the % RPM needle : see photo.
7.32 KB |
12056 Time(s) |
7.32 KB |
12056 Time(s) |
Etienne Verhellen
Posted: Wed May 15, 2013 5:07 am Post subject: Re: RPM Generator |
I have been informed by a very reliable source that the RPM generator for the Yak-52 is actually the DTE-6T.
See photo below : DTE-6T.
The DTA-2 Rpm generator is possibly from the Mi-2 helicopter ...
but I suspect it would work as well ...
Anyway, we have now found one and it will be installed on the aircraft
very soon. I'm sure Yak parts will be needed again in the future ...
275.31 KB |
11923 Time(s) |
_________________ Yak-50 Display Pilot - Airshows - Яковлев Як-50
Yak-52 training anywhere - FI(A) Aerobatic Instructor - Specialised Yak-52.
https://www.yakoteam.com/
https://www.yakovlevs.com/the-team/pilots-and-crew/ |
Etienne Verhellen
Posted: Wed May 15, 2013 1:29 pm Post subject: Re: RPM Generator |
Another view of the DTE-6T RPM generator for Yaks ...
1.42 MB |
11876 Time(s) |
Rob Rowe
Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
Posted: Thu May 16, 2013 4:28 am Post subject: Re: RPM Generator |
Etienne,
FWIW - the original equipment tach generator for the -52 is the DTE-2.
From the Russian documentation I have the suffix denotes the number of display units the generator can drive. Hence -2 allows it to drive both the front & rear displays in a -52. Accordingly for a -50 the standard fit is a DTE-1.
I've not seen a detailed spec for a DTE-6T to know whether this can be extrapolated, other than noting its use on Russian airliners where presumably the flight engineers display takes this total to at least 3. Other than that, from the limited info I've been able to find, it appears to have the same mechanical gearing & electrical voltage output as the other DTE devices.
Brgds, Rob
Etienne Verhellen
Posted: Sun May 19, 2013 7:11 am Post subject: Re: RPM Generator |
Rob, You know A LOT more about Yak tach generator than me !
Etienne.
