Garmin GPS Antenna Location
rv10free2fly(at)yahoo.com
PostPosted: Sat Jan 19, 2013 2:48 pm    Post subject: Garmin GPS Antenna Location Reply with quote
I'm looking for an appropriate spot to install the GPS antenna (puck teardrop style) for the Garmin unit and have read several posts of locations used by builders (i.e. cabin top, top of panel, top of coming before firewall and under the top cowl forward of the firewall.
The Garmin GTN-750 GPS antenna requires a ground plane if installed on composites, which isn't a real problem (compared with to my TCAS mount challenge!).
Is there any structural disadvantage of mounting the GPS antenna on the cabin top, as I'll need four attachment point (was thinking of using rivnuts and embedding them in the glass top and using a mesh ground plane under the GPS antenna. The main disadvantage of this installation is the you need to drill through the cabin top for the antenna cable!
The other option is just to mount the antenna on the front panel, however are there any issues with interference from any other avionics if located here?
I don't fancy mounting the antenna firewall forward!
Your thoughts would be very much appreciated please.
Warm regards
Patrick
On 18/01/2013, at 6:38 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Sean,
If I owe you anything for the brackets or if you'd like the nylon ones back please let me know?
Warm regards
Patrick
On 18/01/2013, at 2:28 AM, Seano <sean(at)braunandco.com> wrote:
> My new planearound anodized aluminum brackets are widened to accept bigger struts. The opening is 3/8" they work perfect for stock struts too.
> <photo.JPG>
> Sent from my iPhone
> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
> </b></font></pre>
Bajajim
PostPosted: Sat Jan 19, 2013 2:55 pm    Post subject: Garmin GPS Antenna Location Reply with quote
Firewall forward Works great!!!
I have 3 mounted an a Vans RV12 mount.
Great coverage...
Sent from my Verizon Wireless BlackBerry
PostPosted: Sat Jan 19, 2013 4:27 pm    Post subject: Garmin GPS Antenna Location Reply with quote
Any photos please Jim?
Any heating issues with the antenna?
Warm regards
Patrick
Great coverage...
Bob Turner
PostPosted: Sat Jan 19, 2013 4:53 pm    Post subject: Re: Garmin GPS Antenna Location Reply with quote
Mine is on top behind the baggage area, on the metal tailcone so the ground plane is a non issue. It has never failed to pull in plenty of satellites.
Bob Turner
RV-10 QB
cooprv7(at)yahoo.com
PostPosted: Sat Jan 19, 2013 5:11 pm    Post subject: Garmin GPS Antenna Location Reply with quote
I have the same location, same great results.
Marcus
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Sat Jan 19, 2013 5:50 pm    Post subject: Garmin GPS Antenna Location Reply with quote
Same here too.
Tim
Marcus
Bob Turner
RV-10 QB
robin(at)PaintTheWeb.com
PostPosted: Sat Jan 19, 2013 6:02 pm    Post subject: Garmin GPS Antenna Location Reply with quote
I have two Garmin GPS antenna firewall forward on the 8A and it works well. The only issue is Garmin suggests 6" separation and staggered from what I am told.
No way I would put them on my dash. Just too in your face. I try to keep the dash completely free of items.
Robin
[img]cid:image007.jpg(at)01CDF66F.1E97A5B0[/img][img]cid:image008.jpg(at)01CDF66F.1E97A5B0[/img][img]cid:image009.jpg(at)01CDF66F.1E97A5B0[/img]
 Filesize:  186.79 KB
 Viewed:  8067 Time(s)
 Filesize:  179.35 KB
 Filesize:  142.21 KB
Bajajim
PostPosted: Sat Jan 19, 2013 6:20 pm    Post subject: Garmin GPS Antenna Location Reply with quote
I will get some
PostPosted: Sat Jan 19, 2013 8:41 pm    Post subject: Garmin GPS Antenna Location Reply with quote
Guys is your COMM antenna also mounted out back there too?
Warm regards
Patrick
On 20/01/2013, at 12:19 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
Same here too.
Tim
> Marcus
> do not archive
> Bob Turner
> RV-10 QB
PostPosted: Sat Jan 19, 2013 9:10 pm    Post subject: Garmin GPS Antenna Location Reply with quote
My main comm antenna is on the bottom with a Bob Archer strip on the roof for comm 2.
Marcus
On Jan 19, 2013, at 23:45, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Warm regards
Patrick
Same here too.
Tim
> Marcus
> do not archive
> Bob Turner
> RV-10 QB
Bob Turner
PostPosted: Sat Jan 19, 2013 9:22 pm    Post subject: Re: Garmin GPS Antenna Location Reply with quote
Com 1 on belly, com 2 is Archer clone in wingtip. Nav is Archer in other wingtip. Only antennas on top are gps and ELT.
Bob Turner
RV-10 QB
n223rv(at)wolflakeairport
PostPosted: Sat Jan 19, 2013 10:10 pm    Post subject: Garmin GPS Antenna Location Reply with quote
Comm 1 and 2 are on the belly underneath the seats for me. All my GPS antennas (and GDL39) are under the cowl. All work great!!
-Mike Kraus
RV-4 sold Sad
RV-10 flying Smile
KitFox SS7 Radial building Smile
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=392689#392689
 Filesize:  580.4 KB
 Viewed:  8055 Time(s)
 Filesize:  550.91 KB
