rv10free2fly(at)yahoo.com Guest
Posted: Sat Jan 19, 2013 2:48 pm Post subject: Garmin GPS Antenna Location |
I'm looking for an appropriate spot to install the GPS antenna (puck teardrop style) for the Garmin unit and have read several posts of locations used by builders (i.e. cabin top, top of panel, top of coming before firewall and under the top cowl forward of the firewall.
The Garmin GTN-750 GPS antenna requires a ground plane if installed on composites, which isn't a real problem (compared with to my TCAS mount challenge!).
Is there any structural disadvantage of mounting the GPS antenna on the cabin top, as I'll need four attachment point (was thinking of using rivnuts and embedding them in the glass top and using a mesh ground plane under the GPS antenna. The main disadvantage of this installation is the you need to drill through the cabin top for the antenna cable!
The other option is just to mount the antenna on the front panel, however are there any issues with interference from any other avionics if located here?
I don't fancy mounting the antenna firewall forward!
Your thoughts would be very much appreciated please.
Warm regards
Patrick
On 18/01/2013, at 6:38 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Sean,
If I owe you anything for the brackets or if you'd like the nylon ones back please let me know?
Warm regards
Patrick
On 18/01/2013, at 2:28 AM, Seano <sean(at)braunandco.com> wrote:
> My new planearound anodized aluminum brackets are widened to accept bigger struts. The opening is 3/8" they work perfect for stock struts too.
> <photo.JPG>
> Sent from my iPhone
> <pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
> </b></font></pre>
Bajajim
Posted: Sat Jan 19, 2013 2:55 pm Post subject: Garmin GPS Antenna Location |
Firewall forward Works great!!!
I have 3 mounted an a Vans RV12 mount.
Great coverage...
Sent from my Verizon Wireless BlackBerry
Posted: Sat Jan 19, 2013 4:27 pm Post subject: Garmin GPS Antenna Location |
Any photos please Jim?
Any heating issues with the antenna?
Warm regards
Patrick
Great coverage...
Bob Turner
Posted: Sat Jan 19, 2013 4:53 pm Post subject: Re: Garmin GPS Antenna Location |
Mine is on top behind the baggage area, on the metal tailcone so the ground plane is a non issue. It has never failed to pull in plenty of satellites.
_________________ Bob Turner
RV-10 QB |
cooprv7(at)yahoo.com Guest
Posted: Sat Jan 19, 2013 5:11 pm Post subject: Garmin GPS Antenna Location |
I have the same location, same great results.
Marcus
Bob Turner
RV-10 QB
Tim Olson
Posted: Sat Jan 19, 2013 5:50 pm Post subject: Garmin GPS Antenna Location |
Same here too.
On Jan 19, 2013, at 7:11 PM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:
Marcus
Bob Turner
RV-10 QB
Posted: Sat Jan 19, 2013 6:02 pm Post subject: Garmin GPS Antenna Location |
I have two Garmin GPS antenna firewall forward on the 8A and it works well. The only issue is Garmin suggests 6" separation and staggered from what I am told.
No way I would put them on my dash. Just too in your face. I try to keep the dash completely free of items.
Robin
[img]cid:image007.jpg(at)01CDF66F.1E97A5B0[/img][img]cid:image008.jpg(at)01CDF66F.1E97A5B0[/img][img]cid:image009.jpg(at)01CDF66F.1E97A5B0[/img]
186.79 KB |
7977 Time(s) |
179.35 KB |
7977 Time(s) |
142.21 KB |
7977 Time(s) |
Bajajim
Posted: Sat Jan 19, 2013 6:20 pm Post subject: Garmin GPS Antenna Location |
I will get some
Posted: Sat Jan 19, 2013 8:41 pm Post subject: Garmin GPS Antenna Location |
Guys is your COMM antenna also mounted out back there too?
Warm regards
Patrick
On 20/01/2013, at 12:19 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
Same here too.
> Marcus
> do not archive
> Bob Turner
> RV-10 QB
Posted: Sat Jan 19, 2013 9:10 pm Post subject: Garmin GPS Antenna Location |
My main comm antenna is on the bottom with a Bob Archer strip on the roof for comm 2.
Marcus
On Jan 19, 2013, at 23:45, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Warm regards
Patrick
Same here too.
> Marcus
> do not archive
> Bob Turner
> RV-10 QB
Bob Turner
Posted: Sat Jan 19, 2013 9:22 pm Post subject: Re: Garmin GPS Antenna Location |
Com 1 on belly, com 2 is Archer clone in wingtip. Nav is Archer in other wingtip. Only antennas on top are gps and ELT.
RV-10 QB |
Posted: Sat Jan 19, 2013 10:10 pm Post subject: Garmin GPS Antenna Location |
Comm 1 and 2 are on the belly underneath the seats for me. All my GPS antennas (and GDL39) are under the cowl. All work great!!
-Mike Kraus
RV-4 sold
RV-10 flying
KitFox SS7 Radial building
On Jan 20, 2013, at 6:22 AM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
580.4 KB |
7965 Time(s) |
550.91 KB |
7965 Time(s) |
