Trailing Edges
zackrv8
PostPosted: Thu Jun 08, 2006 1:49 pm    Post subject: Trailing Edges Reply with quote
Forgive me if this is in the archives, but I have a question about the Aileron and Flap trailing edges.
After mounting the flaps and ailerons onto the wing, the trailing edges do not match up. I was kind of hoping they would since the wings and flaps were not built in jigs per say. But they didn't.
To make everything line up, I need to pull the 2 flap attach bolts (wing root bolt left on). The flap actually needs to be raised a little (wing is vertical in the jig) to make the flap parallel to the top skin rivets. Then, the bolt holes don't line up. Bummer!
Has anbody else seen this and if you did, what did you do about it?
Zack
RV8 #80125
RV10 # 40512
Rick S.
PostPosted: Fri Jun 09, 2006 5:27 am    Post subject: Trailing Edges Reply with quote
Zack,
At first I thought the same thing, make sure the flap leading edge is up against the rear spar, that is it's neutral position. If your bottom skins are not on wait until they are before pressing the bushings into the flap brackets because the skins can't slip over the hinges. The bushings made the difference for me. I found as all the hardware was being installed everything seemed to line up fine after it was fully installed, torqued etc.
Rick S.
40185
Fuse/Finish
Rick S.
RV-10
40185
jaybrinkmeyer(at)yahoo.co
PostPosted: Fri Jun 09, 2006 10:58 am    Post subject: Trailing Edges Reply with quote
From your description I have the same flap/aileron trailing edge aligment issue
on one wing (less than 1/4" as I recall). A couple of folks have looked at it
(including the local EAA tech advisor) and no one has pointed at anything that
might be amiss.
One of the guys on the Vans builder line said that I might have warped or
twisted the flap slightly and that could attribute to the funky edge. I voted
to not build a show plan and just keep on going as nothing is falling off.
Hope this makes sense.
Jay
Slow build everything... Fuse
Time: 02:51:46 PM PST US
Subject: Trailing Edges
Zack
zackrv8
PostPosted: Fri Jun 09, 2006 11:43 am    Post subject: Re: Trailing Edges Reply with quote
Rick and Jay,
Thanks for the replies. I just found out that I indeed have a "twisted" flap. You have to take great care when builing those long pieces. Inducing a twist or warp is very, very easy.
My flaps are so bad (in my opinion) that I need to redo them. I will try drilling out the trailing edge rivets and use a heat gun to break the 2216 epoxy. If I booger it up, Vans will get more of my money!
For the rest of you building the flaps, take great care to follow the instructions and make sure you have a flat table and weigh the flap down like the plans call for.
Zack
RV8 #80125
RV10 # 40512
Vern(at)teclabsinc.com
PostPosted: Mon Jun 12, 2006 7:32 am    Post subject: Trailing Edges Reply with quote
Hi Zack,
I talked to Scott at Van's about control surface twist. He said for the
ailerons 3/16" was the QC limit for the QB ailerons that come into the
factory. This is measured by laying the aileron on a flat surface,
finding the corner that is not sitting flat on the table and measuring
the distant between that spot on the skin and the table top.
I also asked if the 3/16" rule applied to the flaps and was told if one
can get 3/16" or less great. But it is a very long surface and not as
critical as the aileron (though still important) because the flap is
fixed in position where the aileron "floats" in the air stream. So
twists in an aileron tend to change the air flow over them and push them
out of alignment in flight. Hope this is of help.
Vern Smith (#40324 flaps done going back to the fuel tanks!)
zackrv8
PostPosted: Mon Jun 12, 2006 8:55 am    Post subject: Re: Trailing Edges Reply with quote
Vern,
Roger everything you said. I agree. I mounted the right flap on the wing the other day and it was much, much straighter than the left flap. Definetly had a twist in the right flap. Mine was more pronounced than 3/16 inch.
Couple things bother me though...My right flap had the bad twist in it and it nested in between the top and bottom wing skin very nicely (this is the flap with the bad twist in it). However, the left flap which is almost straight, rubs pretty good between the top and bottom wing skins in the "flap up" position. Why?
Also, I noticed near the "wing root" area of the flap (both flaps actually), that the flap protrudes down below the bottom wing skin yet is flush with the bottom wing skin near the "outboard" area of the flap Again...why?
Zack
RV8 #80125
RV10 # 40512
jesse(at)itecusa.org
PostPosted: Mon Jun 12, 2006 9:20 am    Post subject: Trailing Edges Reply with quote
I'm not sure what exactly you are saying in the last paragraph, but as far
as the flap hitting the fuse when it is in the up position, that is normal
from my experience. I guess it is good to have that as close as possible,
so they make it tight tolerance in design which requires some trimming to
get it to fit just right. We has to do some substantial trimming (filing
mainly) on all 4 flaps that I have fit to get them to fit nicely without
scraping/rubbing the fuse. As far as the twist, I have not noticed
anything, but we pretty much followed the pattern of weighing it down on the
table to hold it flat while riveting the trailing edge...I think.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
zackrv8
PostPosted: Mon Jun 12, 2006 12:57 pm    Post subject: Re: Trailing Edges Reply with quote
Jesse,
OK. Pictures are worth a thousand words. Below are several pics I took of the flap wing gap.
The first pic was taken between the two inboard flap hinges. Notice how the flap sticks out below the bottom skin.
The second picture is a closer look. Pretty ugly.
The third pic was taken right next to the middle flap hinge bracket. Perfect!
I write this in hopes that someone else will not go through the same thing I did.
I am not a first time builder. I have built a slow build RV8 and have a working knowledge of how Vans kits go together. However, this is stumping me at the moment.
So, because of these irregularities, I get to build new flaps. What I would like to know is if anyone else out there seeing the same thing I am?
Btw, this is a slow build RV10 kit.
Zack
 Filesize:  24.55 KB
 Viewed:  547 Time(s)
 Filesize:  26.56 KB
 Viewed:  542 Time(s)
 Filesize:  23.26 KB
 Viewed:  554 Time(s)
RV8 #80125
RV10 # 40512
PostPosted: Mon Jun 12, 2006 2:29 pm    Post subject: Trailing Edges Reply with quote
Thanks for the explanation. I haven't seen this on any of ours, or at least
haven't noticed it (and that shouldn't be hard to notice). It almost seems
as if the leading edge skin didn’t get pulled up tightly against the ribs.
I can't imagine how that could happen unless you got some bad hinge brackets
or the leading edge skin is bad. Even having a warped flap shouldn't do
that, singe the bracket is forward of the spar. Could it possibly be
something with the wing or wing brackets (I shudder to even mention this)?
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
PostPosted: Mon Jun 12, 2006 2:30 pm    Post subject: Trailing Edges Reply with quote
Hi Zack,
Don't know if I can be of much help. I jumped over the fuel tanks and
skinning the bottom of the wings so I'm not able to hang my flaps at
this time.
After looking at your pictures here are some things to think about. Is
the distance between the hinge pivot and the bottom skin the same for
each hinge (check both the wing half of each hinge and the flap half)?
Is the nose skin of the flap more reflexed (sagging) at the inboard end
of the flap? If you have access to a digital protractor clamp the flap
in place so it won't move and take angle readings off of the main skin
(from front to back) along the length of the flap and wing.
Here is the thinking behind it. If either half of the hinge points
progressively run down hill in reference to the skin the whole flap
would droop at one end. Don't know how this could happen with the
pre-punched kits.
If the protractor reading progressively gets worse down the length of
the flap then the problem may be the twist in the flap is centered
around the spar flap (this would cause the leading edge to droop and the
trailing edge to rise or via versa. Well that's my $.02.
Vern (#40324)
toaster73(at)earthlink.ne
PostPosted: Tue Jun 13, 2006 3:39 pm    Post subject: Trailing Edges Reply with quote
Zack
I checked my flaps, I have good alignment of the trailing edges of the flaps
and ailerons. I built one aileron all dorked up and twisted (in a hurry). SO
I built another one. But what I did notice on my flaps using your ruler
technique is that between the nose ribs of the flap along the leading edge
of the flap the nose seems to bulge out a bit and I get that nose area to
be a little lower than the bottom skin. If I move the flap from neutral
(neutral being the slightly reflexed position of the nose resting against
the rear spar at the ing root) the bottom nose of the flap moves in
alignment with the bottom skin in those bulging areas. It seems too that a
slight relocation of the hinge centers could affect things too, that could
be done by machining off center bushings but this would be a pain. I think
massaging the bulging area carefully could help too and also not setting the
flap at the full reflexed postion or a combination. I am going to stick with
mine. Since you have trailing edge problems you must have twist too.
-Chris Lucas
#40072 (fuselage)
zackrv8
PostPosted: Tue Jun 13, 2006 4:23 pm    Post subject: Re: Trailing Edges Reply with quote
Guys,
Again, I agree with everything you guys are saying that are possible reasons for the twist in the flaps and the bulging of the nose skin of the flaps below the bottom wing skin.
Because of the geometry of the way the flaps move when extended, they move away from the wing. I noticed on one flap/aileron alignment that the trailing edges match up perfectly when the flap is resting its nose against the back spar. As Chris said, the flaps are reflexed in their neutral position. However, the bottom of the flap bulges below the skin. I can move the flap just a hair and the bulging flap problem goes away (because of the geometry). But then the trailing edges don't line up.
So, maybe the flap nose skin is not up tight against the nose ribs. Maybe the spar is so twisted that it forces the nose ribs downward. Either way, I can't accept it.
So, I will build 2 new flaps. This time, I will deviate from the plans just a little. I will pin the skeleton on the wing first and check alignment. I may then clamp the aileron and flap trailing edges together in alignment with some very long straight edges. Then, I may even rivet the sucker together right on the wing. That way, it should turn out fairly well in alignment. The wing should make a perfect jig for holding the skeleton in place while riveting.
What do you guys think? Think it can be done that way?
Tim, I am very curious if you have any of these flap problems that I have been talking about.
zack
RV8 #80125
RV10 # 40512
PostPosted: Tue Jun 13, 2006 5:03 pm    Post subject: Trailing Edges Reply with quote
As far as riveting the trailing edge while mounted on the wing, I don't know if I recommend this.  Do you use Proseal on the trailing edge?  This is how we do them...
We rivet the thing together as per the plans, then we take 1.5" or so aluminum angle with holes the same as the trailing edge, proseal the trailing edge and then cleco through the trailing edge and two of these angles, one on top and one on bottom and let the proseal dry overnight while the flap/aileron/rudder/elevator is laying flat on a flat surface (adding weight is a good idea also).  The next day we take off the angles, pass a bit through the holes to clean out the proseal, scrub all proseal off the skins, then back rivet the whole thing, alternating 7-10 holes (easiest by marking "1 through whatever" the whole way down) on the steel table surface (can also be done on steel angle hanging off the edge of the table).  This ends up in a perfect fit every time and a very straight trailing edge.  Once the proseal sets up, you can check for good alignment prior to riveting.  We have had one time where something moved and the alignment was lost, so we opened up the trailing edge, cleaned off all the proseal, and started over.
This may be the way most people do it, and it may be the way the plans say to do it, but I haven't read the plans on this part.  I just have seen them done this way so that's how we do them.  One set of 2 pieces of angle the length of the flap can be used for all 7 parts that require leading edge material.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Tim(at)MyRV10.com
PostPosted: Tue Jun 13, 2006 5:23 pm    Post subject: Trailing Edges Reply with quote
Zack,
I hope I'm the Tim you meant....so I'll throw in my 1 cent. (I'd throw
in 2, but I don't know if I have that much left. Wink )
I'm just confused about what I'm seeing back and forth in the emails.
I saw your 3 pictures and I can't even begin to imagine how it came out
that way. I'm not trying to be insulting, so please don't take it that
way, but man, somethings wrong there. (I know you know that. Wink )
I only wish I could come up with a good reason.
I would durn well hope that the problem isn't with how the flap attach
brackets are, that are riveted to the wing....if they're bad, I'd hope
that they're bad on the FLAP side, not the wing side. You may want
to use a ruler and square and whatever you can, and verify that the
approximate orientations and distances to the holes on the flap brackets
on the WING side are all symmetrical with eachother. I mean, measure
from the skin edge or rivet line, or center of rear spar, to the holes
in the flap brackets, and make sure they're all identical. I'm
almost 100% sure they should be. If they are, then you can breathe
and sleep better knowing that the wing is OK, and the flaps are all
that's wrong.
When you get them right, it will be just like you imagine....they'll
all look like your 3rd picture. When the flaps are all the way up to
the rear spar, they're actually reflexed about 3 degrees I think.
I *think* if I remember right, that's the orientation I had them when
I lined up the trailing edges with my ailerons.
Now, I built that section 100% following the plans. I don't know if
you had bad parts, or slipped up somewhere, but if the parts were good,
I don't think it would be that easy to make that nasty looking of
a mistake. Make sure when you get the new parts that they're
also all symmetrical.
One other thing about building them straight.... I see you guys talking
about building some crooked ailerons and flaps. I just don't know
how they could come out that bad....and again, I'm not trying to
be insulting, so don't read any "tone" into that. All I can guess is
that 2 things are causing the problems:
1) Make sure you're using a nice, solid, flat 8' table to build these
on. My tables had doubled 2x4's and a nice solid rim around the top
with lots of under bracing and a 3/4" particle board top. Very nice
heavy tables.
2) I really think this is where people shouldn't be trying to get by
without the proseal. I set mine up, used that angle steel to cleco mine
to, as a backing plate, and used proseal to keep the edges together,
letting them cure for a night or two before I riveted. I can't say
that this is why they came out great, but I think that angle steel
idea (stolen from I think Mike Howe) was a real key, along with the
proseal.
Anyway, mine are super straight, no bows, no twists, and retracted the
bottoms are slightly reflexed, and the tops make a nice smooth line
all the way down the wing to the trailing edge. The forward nose is
straight, and runs into the rear spar evenly. Being a first time
builder, I guess I could call it beginners luck. But, you never
know if the parts were maybe bad in one batch or something. Stranger
things have happened. If you figure out the cause, post it. It will
be interesting.
zackrv8 wrote:
Guys,
zack
-------- RV8 #80125 RV10 # 40512
Tim(at)MyRV10.com
PostPosted: Tue Jun 13, 2006 5:30 pm    Post subject: Trailing Edges Reply with quote
PS to my previous post:
This page shows a picture of the flaps all laid up:
http://www.myrv10.com/N104CD/wing/20041214/RV200412120032.html
This one is a link to my flaps section:
http://www.myrv10.com/N104CD/wing/20041214/index.html
This one talks about the angle iron while doing the rudder.
http://www.myrv10.com/N104CD/rudder/20040325/index.html
Thinking back, I can't remember if I used it while prosealing the
flaps, or just used it during riveting. Anyway, from the flap
photo above, you can see that with a very sturdy and straight bench,
and overhanging the trailing edge, they'd still be straight while
curing proseal. Additionally, and NOT shown in the photo, while
I let the proseal cure, I piled on lots of weight to the flaps...
spare steel bars, boxes of clecos, and stuff like that....anything
I could find that would help distribute the weight and keep all
the whole length of both flaps tightly laying against the workbench.
Commenting on Jesse's post, he did a great job explaining....it's
really what I think is the "right" way to do this task, and probably
why he/we didn't have a problem with twists.
Jesse Saint wrote:
[quote] As far as riveting the trailing edge while mounted on the wing, I don't
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
zackrv8
PostPosted: Tue Jun 13, 2006 5:36 pm    Post subject: Re: Trailing Edges Reply with quote
Tim and all the others that have been so helpful....
The first thing I checked when things were not lining up was the hinge brackets on the wings. The are dead nuts on. Thank you Tim....I will sleep well tonight!
Anyway, I'll report back to you guys as soon as I get the new parts. Also thanks to the many suggestions out there for building straight control surfaces. You guys are the best for sharing!
Zack
RV8 #80125
RV10 # 40512
Albert Gardner
PostPosted: Tue Jun 13, 2006 7:47 pm    Post subject: Trailing Edges Reply with quote
Well, I didn't build the flap on the wing but I did make some brackets to
hold the flap hinges in alignment while I built it. In the picture, the
clamp at the nose is to pull the trailing edge tight and remove the waves.
Albert Gardner
Yuma, AZ
 Filesize:  48.3 KB
 Viewed:  491 Time(s)
RV-9A N872RV
RV-10 N991RV
indigoonlatigo(at)msn.com
PostPosted: Wed Jun 14, 2006 11:50 am    Post subject: Trailing Edges Reply with quote
After reading all the post that came after this email, I can't help but
wonder whether the flap brackets could be somehow accidentally mixed up so
that rt became left and left became right. I mean, backwards. Because of
the computer designing and hole seperation spacing, some of the kit parts
fit together even when they are backwards.
I am no where near this part of the project so forgive me if this is so
stupid of a posible answer to the problem.
JG.
Reply-To: rv10-list(at)matronics.com
Subject: Re: Trailing Edges
Date: Tue, 13 Jun 2006 17:23:00 -0700
Guys,
zack
RV8 #80125
RV10 # 40512
http://forums.matronics.com/viewtopic.php?p=40834#40834
