Sneak Peek
cpayne(at)joimail.com
PostPosted: Wed Jul 04, 2012 12:21 pm    Post subject: Sneak Peek Reply with quote
Here is a look at a prototype of a distributor cap I'm developing. It is designed to work with automotive wire on either a standard magneto or a magneto converted to Electronic Ignition. This configuration secures spiro-wrapped wire more securely than screwing a pin through it with the stock cap. It also has wider contacts for a slightly longer firing time to facilitate the multiple spark feature in EI.
Notice that 1 piece replaces both cap and cover. Larger 10mm wire for high energy systems can be used if desired.
See it at Oshkosh, I'll bring it up for the maintenance seminar.
Craig Payne
 Filesize:  1.01 MB
 Viewed:  1864 Time(s)
 Filesize:  1.08 MB
mark.bitterlich(at)navy.m
PostPosted: Wed Jul 04, 2012 2:51 pm    Post subject: Sneak Peek Reply with quote
GOOD IDEA!
From: owner-yak-list-server(at)matronics.com on behalf of Cpayne
Sent: Wed 7/4/2012 4:18 PM
To: yak-list
Subject: Sneak Peek
Craig Payne
dsavarese0812(at)bellsout
PostPosted: Wed Jul 04, 2012 4:28 pm    Post subject: Sneak Peek Reply with quote
Great idea Craig!
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Craig Payne
pilko2(at)btinternet.com
PostPosted: Thu Jul 05, 2012 1:07 am    Post subject: Sneak Peek Reply with quote
FYI.
kp
 Filesize:  1.01 MB
 Viewed:  1838 Time(s)
 Filesize:  1.08 MB
