cpayne(at)joimail.com Guest
Posted: Wed Jul 04, 2012 12:21 pm Post subject: Sneak Peek |
Here is a look at a prototype of a distributor cap I'm developing. It is designed to work with automotive wire on either a standard magneto or a magneto converted to Electronic Ignition. This configuration secures spiro-wrapped wire more securely than screwing a pin through it with the stock cap. It also has wider contacts for a slightly longer firing time to facilitate the multiple spark feature in EI.
Notice that 1 piece replaces both cap and cover. Larger 10mm wire for high energy systems can be used if desired.
See it at Oshkosh, I'll bring it up for the maintenance seminar.
Craig Payne
1.01 MB |
1852 Time(s) |
1.08 MB |
1852 Time(s) |
Posted: Wed Jul 04, 2012 2:51 pm Post subject: Sneak Peek |
GOOD IDEA!
From: owner-yak-list-server(at)matronics.com on behalf of Cpayne
Sent: Wed 7/4/2012 4:18 PM
To: yak-list
Subject: Sneak Peek
Craig Payne
Posted: Wed Jul 04, 2012 4:28 pm Post subject: Sneak Peek |
Great idea Craig!
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 7/4/2012 3:18 PM, Cpayne wrote:
| Quote: | Here is a look at a prototype of a distributor cap I'm developing. It is designed to work with automotive wire on either a standard magneto or a magneto converted to Electronic Ignition. This configuration secures spiro-wrapped wire more securely than screwing a pin through it with the stock cap. It also has wider contacts for a slightly longer firing time to facilitate the multiple spark feature in EI.
Craig Payne
pilko2(at)btinternet.com Guest
Posted: Thu Jul 05, 2012 1:07 am Post subject: Sneak Peek |
FYI.
kp
1.01 MB |
1826 Time(s) |
1.08 MB |
1826 Time(s) |
