civengpe
Posted: Mon Feb 06, 2012 12:00 pm Post subject: Dimpled When I Shouldn't Have |
My first thought was to not give this a second thought and drive on, but thought I should see what the collective wisdom has to say...
I finally finished running all (I hope) of my wires and conduits to the back and began the process of permanently installing the baggage and rear seat floors. While installing the nut plates in the rear seat floors, I noticed that Van's had specified k1000-8. Well these didn't work since the #19 holes were dimpled. I grabbed the k1100-8s and merrily went on my way. It wasn't until today that I noticed I was not supposed to dimple the #19 holes [img]cid:gtalk.320(at)goomoji.gmail[/img].
Herein lies the issue. I have completed riveting the rear baggage floor ad seat back hinges. It just looks like these are for the access cover and I can dimple these as well. Do you think I need to fix this?
Shannon
41153
606 Bytes |
2106 Time(s) |
131.93 KB |
2106 Time(s) |
61.25 KB |
2106 Time(s) |
Kellym
Posted: Mon Feb 06, 2012 12:22 pm Post subject: Dimpled When I Shouldn't Have |
Your proposed substitution should work fine. No need to fix anything.
Kelly
On 2/6/2012 12:53 PM, Shannon Hicks wrote:
| Quote: | My first thought was to not give this a second thought and drive on,
was not supposed to dimple the #19 holes .
fix this?
Shannon
41153
KCHD |
mike.nova1973(at)gmail.co Guest
Posted: Mon Feb 06, 2012 12:41 pm Post subject: Dimpled When I Shouldn't Have |
I did the same thing and it worked just fine and looked good to.
On Feb 6, 2012, at 1:53 PM, Shannon Hicks <civeng123(at)gmail.com> wrote:
| Quote: | My first thought was to not give this a second thought and drive on, but thought I should see what the collective wisdom has to say...
I finally finished running all (I hope) of my wires and conduits to the back and began the process of permanently installing the baggage and rear seat floors. While installing the nut plates in the rear seat floors, I noticed that Van's had specified k1000-8. Well these didn't work since the #19 holes were dimpled. I grabbed the k1100-8s and merrily went on my way. It wasn't until today that I noticed I was not supposed to dimple the #19 holes <320.png>.
Shannon
41153
<Capture.JPG>
<Capture2.JPG>
