Dimpled When I Shouldn't Have
civengpe
PostPosted: Mon Feb 06, 2012 12:00 pm    Post subject: Dimpled When I Shouldn't Have Reply with quote
My first thought was to not give this a second thought and drive on, but thought I should see what the collective wisdom has to say...
I finally finished running all (I hope) of my wires and conduits to the back and began the process of permanently installing the baggage and rear seat floors.  While installing the nut plates in the rear seat floors, I noticed that Van's had specified k1000-8.  Well these didn't work since the #19 holes were dimpled.  I grabbed the k1100-8s and merrily went on my way.  It wasn't until today that I noticed I was not supposed to dimple the #19 holes [img]cid:gtalk.320(at)goomoji.gmail[/img].
Herein lies the issue.  I have completed riveting the rear baggage floor ad seat back hinges.  It just looks like these are for the access cover and I can dimple these as well.  Do you think I need to fix this?
Shannon
41153
 Filesize:  606 Bytes
 Viewed:  2058 Time(s)
 Filesize:  131.93 KB
 Filesize:  61.25 KB
Kellym
PostPosted: Mon Feb 06, 2012 12:22 pm    Post subject: Dimpled When I Shouldn't Have Reply with quote
Your proposed substitution should work fine. No need to fix anything.
Kelly
was not supposed to dimple the #19 holes .
fix this?
Shannon
41153
Kelly McMullen
KCHD
mike.nova1973(at)gmail.co
PostPosted: Mon Feb 06, 2012 12:41 pm    Post subject: Dimpled When I Shouldn't Have Reply with quote
I did the same thing and it worked just fine and looked good to.
I finally finished running all (I hope) of my wires and conduits to the back and began the process of permanently installing the baggage and rear seat floors. While installing the nut plates in the rear seat floors, I noticed that Van's had specified k1000-8. Well these didn't work since the #19 holes were dimpled. I grabbed the k1100-8s and merrily went on my way. It wasn't until today that I noticed I was not supposed to dimple the #19 holes <320.png>.
Shannon
41153
<Capture.JPG>
<Capture2.JPG>
