Sealing the Oil Cooler
philperry9(at)gmail.com
PostPosted: Tue Nov 22, 2011 2:12 pm    Post subject: Sealing the Oil Cooler Reply with quote
Last night I installed the oil cooler onto the airbox and noticed it's a very leaky setup.  Attached is a photo of the *inside* of the airbox and you'll notice some big gaps on the corners and even a gap down the sides.
Has anyone sealed these?  I'm thinking of putting a fillet of red rtv along the edges and a blob in the corners to keep the air moving through the cooler and not around it.
Phil
 Filesize:  702.83 KB
 Viewed:  3253 Time(s)
pitts_pilot(at)bellsouth.
PostPosted: Tue Nov 22, 2011 2:24 pm    Post subject: Sealing the Oil Cooler Reply with quote
sides.
That's what I did.
Linn
Phil
aerosport1
PostPosted: Tue Nov 22, 2011 3:01 pm    Post subject: Sealing the Oil Cooler Reply with quote
Phil I sealed mine but used a silver RTV high temp which does not show as much as the red
Geoff
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Tuesday, November 22, 2011 5:09 PM
Subject: Sealing the Oil Cooler
Phil
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
robin(at)PaintTheWeb.com
PostPosted: Tue Nov 22, 2011 3:20 pm    Post subject: Sealing the Oil Cooler Reply with quote
Because Geoff's RV-10 looks amazing even from inside the oil cooler wedge!
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs
Sent: Tuesday, November 22, 2011 2:59 PM
Subject: RE: Sealing the Oil Cooler
Geoff
Phil
==============[/b][/quote] sts This Month --[/b][/quote] And Get Some AWESOME FREE Gifts!)[/b][/quote] ick on[/b][/quote] t[/b][/quote] d[/b][/quote] aeroelectric.com">www.aeroelectric.com[/b][/quote] http://www.buildersbooks.com">www.buildersbooks.com[/b][/quote] .homebuilthelp.com">www.homebuilthelp.com[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] b>[/quote] bsp;   -Matt Dralle, List Admin.[/b][/quote] ==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp;   -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
bgill1(at)charter.net
That’s what I did. Lot more of the red high temp RTV on the baffles and sealing around the engine as well.
Byron
N253RV still in phase one but loving it more each day.
Phil
PostPosted: Tue Nov 22, 2011 3:43 pm    Post subject: Sealing the Oil Cooler Reply with quote
I'm going to be hiding all my firewall awesomeness behind a split cowling and paint!
One the topic of baffles and installing RTV.  Has anyone found an applicator that's long (~12 Inches) and skinny (~3/16") for pumping the stuff into some pretty tight spots?  It seems like there could be a pneumatic applicator or a mechanical plunger type that would get you into some pretty tight spots.
On Tue, Nov 22, 2011 at 5:20 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Geoff Combs
Geoff
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Phillip Perry
Phil
============== sts This Month -- And Get Some AWESOME FREE Gifts!) ick on t d aeroelectric.com">www.aeroelectric.com http://www.buildersbooks.com">www.buildersbooks.com .homebuilthelp.com">www.homebuilthelp.com bution">http://www.matronics.com/contribution b> bsp;                   -Matt Dralle, List Admin. ============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp;    - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp;  - List Contribution Web Site - e> bsp;                   -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ==============
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
get="_blank">http://www.matronics.com/Navigator?RV10-List
speckter(at)comcast.net
PostPosted: Tue Nov 22, 2011 4:20 pm    Post subject: Sealing the Oil Cooler Reply with quote
Grab a plastic straw from Mc Donalds and cram it on the end of your applicator and reach as far as you want.
Gary Specketer
Sent: Tuesday, November 22, 2011 6:41:00 PM
Subject: Re: Sealing the Oil Cooler
Robin
Geoff
Phil
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
get=_blank>http://www.matronics.com/Navigator?RV10-List
arplnplt(at)gmail.com
PostPosted: Tue Nov 22, 2011 9:57 pm    Post subject: Sealing the Oil Cooler Reply with quote
I did the same.
Dave Leikam
Phil
<photo.JPG>
