philperry9(at)gmail.com Guest
Posted: Tue Nov 22, 2011 2:12 pm Post subject: Sealing the Oil Cooler |
Last night I installed the oil cooler onto the airbox and noticed it's a very leaky setup. Attached is a photo of the *inside* of the airbox and you'll notice some big gaps on the corners and even a gap down the sides.
Has anyone sealed these? I'm thinking of putting a fillet of red rtv along the edges and a blob in the corners to keep the air moving through the cooler and not around it.
Phil
702.83 KB |
3204 Time(s) |
Posted: Tue Nov 22, 2011 2:24 pm Post subject: Sealing the Oil Cooler |
On 11/22/2011 5:08 PM, Phillip Perry wrote:
| Quote: | Last night I installed the oil cooler onto the airbox and noticed it's
sides.
That's what I did.
Linn
aerosport1
Posted: Tue Nov 22, 2011 3:01 pm Post subject: Sealing the Oil Cooler |
Phil I sealed mine but used a silver RTV high temp which does not show as much as the red
Geoff
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Tuesday, November 22, 2011 5:09 PM
Subject: Sealing the Oil Cooler
Phil
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Tue Nov 22, 2011 3:20 pm Post subject: Sealing the Oil Cooler |
Because Geoff's RV-10 looks amazing even from inside the oil cooler wedge!
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs
Sent: Tuesday, November 22, 2011 2:59 PM
Subject: RE: Sealing the Oil Cooler
Geoff
Phil
==============[/b][/quote] sts This Month --[/b][/quote] And Get Some AWESOME FREE Gifts!)[/b][/quote] ick on[/b][/quote] t[/b][/quote] d[/b][/quote] aeroelectric.com">www.aeroelectric.com[/b][/quote] http://www.buildersbooks.com">www.buildersbooks.com[/b][/quote] .homebuilthelp.com">www.homebuilthelp.com[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] b>[/quote] bsp; -Matt Dralle, List Admin.[/b][/quote] ==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
bgill1(at)charter.net Guest
That’s what I did. Lot more of the red high temp RTV on the baffles and sealing around the engine as well.
Byron
N253RV still in phase one but loving it more each day.
Phil
Posted: Tue Nov 22, 2011 3:43 pm Post subject: Sealing the Oil Cooler |
I'm going to be hiding all my firewall awesomeness behind a split cowling and paint!
One the topic of baffles and installing RTV. Has anyone found an applicator that's long (~12 Inches) and skinny (~3/16") for pumping the stuff into some pretty tight spots? It seems like there could be a pneumatic applicator or a mechanical plunger type that would get you into some pretty tight spots.
On Tue, Nov 22, 2011 at 5:20 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Geoff Combs
Geoff
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Phillip Perry
Phil
============== sts This Month -- And Get Some AWESOME FREE Gifts!) ick on t d aeroelectric.com">www.aeroelectric.com http://www.buildersbooks.com">www.buildersbooks.com .homebuilthelp.com">www.homebuilthelp.com bution">http://www.matronics.com/contribution b> bsp; -Matt Dralle, List Admin. ============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============== | Quote: |
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
speckter(at)comcast.net Guest
Posted: Tue Nov 22, 2011 4:20 pm Post subject: Sealing the Oil Cooler |
Grab a plastic straw from Mc Donalds and cram it on the end of your applicator and reach as far as you want.
Gary Specketer
Sent: Tuesday, November 22, 2011 6:41:00 PM
Subject: Re: Sealing the Oil Cooler
Robin
Geoff
Phil
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
blank>http://www.matronics.com/contribution
get=_blank>http://www.matronics.com/Navigator?RV10-List
arplnplt(at)gmail.com Guest
Posted: Tue Nov 22, 2011 9:57 pm Post subject: Sealing the Oil Cooler |
I did the same.
Dave Leikam
On Nov 22, 2011, at 4:08 PM, Phillip Perry wrote:
| Quote: | Last night I installed the oil cooler onto the airbox and noticed it's a very leaky setup. Attached is a photo of the *inside* of the airbox and you'll notice some big gaps on the corners and even a gap down the sides.
Phil
<photo.JPG>
