toaster73(at)embarqmail.c Guest
Posted: Wed Sep 14, 2011 5:46 pm Post subject: Dash board edge trim |
I am finalizing the plane for weight and balance and making sure I have done everything I want to do. I am wondering what folks have done to soften the edge of the dash (the aft edge of the F-1071 FWD fuse top skin). I do not want to do anything too fancy but simple and quick but nice looking. I noticed the Van's RV-10 has automotive type fuel line split down the middle and slipped over the edge, which is ok, I guess, but I would like a slight step above that solution.
Chris Lucas
#40072
N919AR
rene(at)felker.com Guest
Posted: Wed Sep 14, 2011 6:22 pm Post subject: Dash board edge trim |
This is what I used….can’t remember how long….
http://www.cleavelandtoolstore.com/prodinfo.asp?number=GSF12
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Wednesday, September 14, 2011 7:42 PM
Subject: Dash board edge trim
Chris Lucas
#40072
N919AR | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
rleffler
Aircraft Door Seals will custom make a glareshield to your template. I had one in my Cherokee and really liked it. It has a nice padded brow. I’m thinking about doing the same in my RV-10. I think it looks nicer that the cloth that Abby sells. But again, that’s my opinion.
Sent: Wednesday, September 14, 2011 9:42 PM
Chris Lucas
#40072
109.28 KB |
7864 Time(s) |
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
ricksked(at)cox.net Guest
Posted: Wed Sep 14, 2011 7:10 pm Post subject: Dash board edge trim |
Get with Abby from flightline interiors. She has a great glareshield cover and edge.
RickRV-10 x 2
RV Central Las Vegas
On Sep 14, 2011, at 7:18 PM, "Rene" <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Chris Lucas
#40072
N919AR01234567
8
Posted: Thu Sep 15, 2011 9:20 am Post subject: Dash board edge trim |
You might try the automotive door edge trim ..... comes in colors too.
Linn
On 9/14/2011 9:42 PM, Chris wrote: [quote] <![endif]--> <![endif]-->
Chris Lucas
#40072
N919AR
larkrv10(at)yahoo.ca Guest
Posted: Thu Sep 15, 2011 11:50 am Post subject: Dash board edge trim |
Years ago we replaced our glareshield cover when we replaced the windshield in our Cardinal, with a piece of leather we bought. After having a friend cut and sew it to the proper shape, we then glued it down. All in all a bad idea, as the leather shrunk, and we ended up ripping it all out for a commercially made cover anyway.
Rick
#40956
Southampton, Ont
--- On Thu, 9/15/11, Rick <ricksked(at)cox.net> wrote:
Subject: Re: Dash board edge trim
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Received: Thursday, September 15, 2011, 3:07 AM
Rick RV-10 x 2
9
| [quote][b]
johngoodman
Posted: Fri Sep 16, 2011 9:03 am Post subject: Re: Dash board edge trim |
I got some rubber edge trim from McMaster-Carr. Here is a link:
http://www.mcmaster.com/#trim-molding/=e37ooh
As far as the covering on the glareshield, I painted the metal flat black. So far it has held up great. For the avionics vent fans, I went with some 80mm computer fans with a flush grill cover, that double as defoggers.
John
_________________ #40572 Phase One complete in 2011 |
rv10rob(at)gmail.com Guest
Posted: Fri Sep 16, 2011 9:23 am Post subject: Dash board edge trim |
Same here--flat black paint looks great. I used the Cleveland ending. I did not add a vent/defrost fan, which is my biggest regret thus far. It's way too hot behind the panel.
-Rob
80 hours
On Fri, Sep 16, 2011 at 10:03 AM, johngoodman <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)> wrote:
| Quote: | --> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
John
#40572 First flight was on 25 June, 2011
http://forums.matronics.com/viewtopic.php?p=352468#352468
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Posted: Fri Sep 16, 2011 11:02 am Post subject: Dash board edge trim |
John,
Sounds good, I too have flat black paint and 2 fans, do you know what exact Mcmaster part number you got, the link just takes me to the many choices.
Chris
drfred(at)suddenlinkmail. Guest
Posted: Fri Sep 16, 2011 11:06 am Post subject: Dash board edge trim |
I used the flat black paint and the edge cover and it has worked well for me.
Make sure you put in black fan grill covers! Don't use the shiny ones or you will have the reflection in your windshield. Don't ask me how I know.......
Dr Fred.
dmaib(at)mac.com Guest
Posted: Fri Sep 16, 2011 11:31 am Post subject: Dash board edge trim |
I too painted the panel top flat back and could not be happier with
it. I used some trim from an auto parts store that looks pretty much
like the far right choice in the top row of John's link. I also used
the same trim for my wing-to-fuselage gap and it has worked great,
David Maib
40559 Flying
just turned over 400 hours.
On Sep 16, 2011, at 2:55 PM, Chris wrote:
John,
the many choices.
Chris
johngoodman
Posted: Fri Sep 16, 2011 2:32 pm Post subject: Re: Dash board edge trim |
Chris,
The one I ordered was Style 6, 8507K15 - 6 feet. But, a lot of the others will fit as well. Since you are already there, take a look at 1120A411. That's the stuff I used for the door edge trim - I love it.
John
| toaster73(at)embarqmail.c wrote: | John,
Chris
arplnplt(at)gmail.com Guest
Posted: Fri Sep 16, 2011 7:25 pm Post subject: Dash board edge trim |
I used black spray on truck bed liner for my dash. Very tough and has a nice textured finish.
Dave Leikam
On Sep 16, 2011, at 1:55 PM, Chris wrote:
John,
Chris
