Dash board edge trim
toaster73(at)embarqmail.c
PostPosted: Wed Sep 14, 2011 5:46 pm    Post subject: Dash board edge trim Reply with quote
I am finalizing the plane for weight and balance and making sure I have done everything I want to do. I am wondering what folks have done to soften the edge of the dash (the aft edge of the F-1071 FWD fuse top skin). I do not want to do anything too fancy but simple and quick but nice looking. I noticed the Van's RV-10 has automotive type fuel line split down the middle and slipped over the edge, which is ok, I guess, but I would like a slight step above that solution.
Chris Lucas
#40072
N919AR
rene(at)felker.com
PostPosted: Wed Sep 14, 2011 6:22 pm    Post subject: Dash board edge trim Reply with quote
This is what I used….can’t remember how long….
http://www.cleavelandtoolstore.com/prodinfo.asp?number=GSF12
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Wednesday, September 14, 2011 7:42 PM
Subject: Dash board edge trim
Chris Lucas
#40072
N919AR
rleffler
Aircraft Door Seals will custom make a glareshield to your template. I had one in my Cherokee and really liked it. It has a nice padded brow. I’m thinking about doing the same in my RV-10. I think it looks nicer that the cloth that Abby sells. But again, that’s my opinion.
Sent: Wednesday, September 14, 2011 9:42 PM
Chris Lucas
#40072
N919AR
 Filesize:  109.28 KB
 Viewed:  7749 Time(s)
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
ricksked(at)cox.net
PostPosted: Wed Sep 14, 2011 7:10 pm    Post subject: Dash board edge trim Reply with quote
Get with Abby from flightline interiors. She has a great glareshield cover and edge.
RickRV-10 x 2
RV Central Las Vegas
On Sep 14, 2011, at 7:18 PM, "Rene" <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Chris Lucas
#40072
N919AR
pitts_pilot(at)bellsouth.
PostPosted: Thu Sep 15, 2011 9:20 am    Post subject: Dash board edge trim Reply with quote
You might try the automotive door edge trim ..... comes in colors too.
Linn
On 9/14/2011 9:42 PM, Chris wrote: [quote] <![endif]--> <![endif]-->
Chris Lucas
#40072
N919AR
larkrv10(at)yahoo.ca
PostPosted: Thu Sep 15, 2011 11:50 am    Post subject: Dash board edge trim Reply with quote
Years ago we replaced our glareshield cover when we replaced the windshield in our Cardinal, with a piece of leather we bought. After having a friend cut and sew it to the proper shape, we then glued it down. All in all a bad idea, as the leather shrunk, and we ended up ripping it all out for a commercially made cover anyway.
Rick
#40956
Southampton, Ont
--- On Thu, 9/15/11, Rick <ricksked(at)cox.net> wrote:
Subject: Re: Dash board edge trim
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Received: Thursday, September 15, 2011, 3:07 AM
Rick RV-10 x 2
Rene'
801-721-6080
Chris Lucas
#40072
N919AR
9
johngoodman
PostPosted: Fri Sep 16, 2011 9:03 am    Post subject: Re: Dash board edge trim Reply with quote
I got some rubber edge trim from McMaster-Carr. Here is a link:
http://www.mcmaster.com/#trim-molding/=e37ooh
As far as the covering on the glareshield, I painted the metal flat black. So far it has held up great. For the avionics vent fans, I went with some 80mm computer fans with a flush grill cover, that double as defoggers.
rv10rob(at)gmail.com
PostPosted: Fri Sep 16, 2011 9:23 am    Post subject: Dash board edge trim Reply with quote
Same here--flat black paint looks great.  I used the Cleveland ending.  I did not add a vent/defrost fan, which is my biggest regret thus far.  It's way too hot behind the panel.
-Rob
80 hours
On Fri, Sep 16, 2011 at 10:03 AM, johngoodman <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)> wrote:
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
#40572 First flight was on 25 June, 2011
http://forums.matronics.com/viewtopic.php?p=352468#352468
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
PostPosted: Fri Sep 16, 2011 11:02 am    Post subject: Dash board edge trim Reply with quote
John,
Sounds good, I too have flat black paint and 2 fans, do you know what exact Mcmaster part number you got, the link just takes me to the many choices.
Chris
drfred(at)suddenlinkmail.
PostPosted: Fri Sep 16, 2011 11:06 am    Post subject: Dash board edge trim Reply with quote
I used the flat black paint and the edge cover and it has worked well for me.
Make sure you put in black fan grill covers! Don't use the shiny ones or you will have the reflection in your windshield. Don't ask me how I know.......
Dr Fred.
dmaib(at)mac.com
PostPosted: Fri Sep 16, 2011 11:31 am    Post subject: Dash board edge trim Reply with quote
I too painted the panel top flat back and could not be happier with
it. I used some trim from an auto parts store that looks pretty much
like the far right choice in the top row of John's link. I also used
the same trim for my wing-to-fuselage gap and it has worked great,
David Maib
40559 Flying
just turned over 400 hours.
On Sep 16, 2011, at 2:55 PM, Chris wrote:
John,
the many choices.
Chris
johngoodman
PostPosted: Fri Sep 16, 2011 2:32 pm    Post subject: Re: Dash board edge trim Reply with quote
Chris,
The one I ordered was Style 6, 8507K15 - 6 feet. But, a lot of the others will fit as well. Since you are already there, take a look at 1120A411. That's the stuff I used for the door edge trim - I love it.
toaster73(at)embarqmail.c wrote:
John,
Chris
arplnplt(at)gmail.com
PostPosted: Fri Sep 16, 2011 7:25 pm    Post subject: Dash board edge trim Reply with quote
I used black spray on truck bed liner for my dash. Very tough and has a nice textured finish.
Dave Leikam
On Sep 16, 2011, at 1:55 PM, Chris wrote:
John,
Chris
