Baggage Door Opening Dimmensions
civengpe
PostPosted: Mon May 16, 2011 11:44 am    Post subject: Baggage Door Opening Dimmensions Reply with quote
Would you guys mind pointing me in the direction of where I can get the baggage door opening dimensions?  I am about to order an article air cooler for my Cherokee and want to make sure it will fit in the 10.
Shannon [quote][b]
Mauledriver(at)nc.rr.com
PostPosted: Mon May 16, 2011 1:04 pm    Post subject: Baggage Door Opening Dimmensions Reply with quote
It's an odd shaped opening. Rounded down to the nearest 1/4":
-The vertical at the front is 19.25"
- The horizontal at top is 20.25
- A diagonal of 28" from lower LH corner to upper right
- But then you have to remove a triangle at the lower bottom rear corner
that is 7" horizontally and 6" vertically
The whole affair looks like (I hope):
Hope that helps.
Bill "re-installing the panel, looking for a hangar" Watson
Shannon
civengpe
PostPosted: Mon May 16, 2011 1:33 pm    Post subject: Baggage Door Opening Dimmensions Reply with quote
I think I understand...  Does the attached drawing look about right?
On Mon, May 16, 2011 at 4:01 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
- But then you have to remove a triangle at the lower bottom rear corner that is 7" horizontally and 6" vertically
Hope that helps.
Shannon
http://forums.matronics.com
le, List Admin.
 Filesize:  36.56 KB
 Viewed:  6147 Time(s)
PostPosted: Mon May 16, 2011 3:12 pm    Post subject: Baggage Door Opening Dimmensions Reply with quote
That's it!
It's a very satisfying piece to assemble because it has a slight compound curve throughout it. Not sure how you would fabricate it without CAD and CNC... at least without n years of sheet metal experience... but it just clecos together and fits perfectly.
On 5/16/2011 5:28 PM, Shannon Hicks wrote: [quote]I think I understand... Does the attached drawing look about right?
Hope that helps.
Shannon
le, List Admin.
Lew Gallagher
PostPosted: Mon May 16, 2011 6:33 pm    Post subject: Baggage Door Opening Dimmensions Reply with quote
Hey Shannon,
I've made my own cooler/ac for the baggage compartment in the -10. I'll get dimensions of the cooler tomorrow -- it's about a perfect fit.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
rv10flyer(at)verizon.net
PostPosted: Mon May 16, 2011 7:07 pm    Post subject: Baggage Door Opening Dimmensions Reply with quote
Is the article meant to be arctic air cooler? if so buy it from Lew, on this list, or make it yourself. much less expensive.
I need to get around to making mine one of these days.
Pascal
Sent: Monday, May 16, 2011 12:41 PM
Subject: Baggage Door Opening Dimmensions
Shannon[quote]
civengpe
PostPosted: Tue May 17, 2011 3:55 am    Post subject: Baggage Door Opening Dimmensions Reply with quote
Yes, it was supposed to be artctic.  Auto correct on my phone got me again.  I would be happy to buy it from Lew. Does anyone have his phone number?
Shannon On May 16, 2011 10:14 PM, "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:> Is the article meant to be arctic air cooler? if so buy it from Lew, on this list, or make it yourself. much less expensive.
Pascal
Shannon
Lew Gallagher
PostPosted: Tue May 17, 2011 4:11 am    Post subject: Re: Baggage Door Opening Dimmensions Reply with quote
OK Shannon,
The dimensions of the cooler I use are 14X14X24, and it tapers slightly toward the bottom so that it slides in perfectly.
I'll attach the pictures I posted earlier. The cooler is at Walmart now for less than $20. It's the 48 qt. Island Breeze by Igloo.
I've modified the a/c cooler I made for Wes by wiring the fans in series instead of parallel. This cuts the amps down and still puts out a lot of cool air and doesn't use the ice up so fast. The 12v computer fans I use are actually for servers and put out more cfm than any others I've run across.
I think the advantage of this style that I've put together is that it uses the heater core (out of junkyard cars) as a heat exchanger that actually pulls moisture out of the cabin instead of just blowing air over ice.
I haven't gotten around to making the plenum yet that would sit on the console between the seats with directional air vents ... stay tuned!
Later, - Lew
 Filesize:  41.87 KB
 Viewed:  6100 Time(s)
 Filesize:  55.26 KB
 Filesize:  58.6 KB
non-pilot
Fly off completed !
LarryRosen
PostPosted: Tue May 17, 2011 5:15 am    Post subject: Baggage Door Opening Dimmensions Reply with quote
Here is the earlier post with links to the pictures that Lew posted earlier.
Hey Patrick,
Here are a couple of pictures of the last one I made for the guy that flies a Cessna. He has his accessory outlet on the dash, so I made the in-line switch about two feet from the receptacle, with a total length of about 11 feet so that he can put the cooler in the back. The 4" ducts extend to 8 ft. and they are quick detach.
Thanks for the interest, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=305177#305177
http://forums.matronics.com//files/ac9_medium_194.jpg
http://forums.matronics.com//files/ac8_medium_937.jpg
http://forums.matronics.com//files/ac7_medium_697.jpg
On 5/17/2011 8:11 AM, Lew Gallagher wrote:
OK Shannon,
Later, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=340105#340105
http://forums.matronics.com//files/ac9_medium_100.jpg
http://forums.matronics.com//files/ac8_medium_709.jpg
http://forums.matronics.com//files/ac7_medium_257.jpg
Larry Rosen
#40356
N205EN (reserved)
<http>
