civengpe
Posted: Mon May 16, 2011 11:44 am Post subject: Baggage Door Opening Dimmensions |
Would you guys mind pointing me in the direction of where I can get the baggage door opening dimensions? I am about to order an article air cooler for my Cherokee and want to make sure it will fit in the 10.
Shannon [quote][b]
Posted: Mon May 16, 2011 1:04 pm Post subject: Baggage Door Opening Dimmensions |
It's an odd shaped opening. Rounded down to the nearest 1/4":
-The vertical at the front is 19.25"
- The horizontal at top is 20.25
- A diagonal of 28" from lower LH corner to upper right
- But then you have to remove a triangle at the lower bottom rear corner
that is 7" horizontally and 6" vertically
The whole affair looks like (I hope):
Hope that helps.
Bill "re-installing the panel, looking for a hangar" Watson
On 5/16/2011 3:41 PM, Shannon Hicks wrote:
Shannon
civengpe
Posted: Mon May 16, 2011 1:33 pm Post subject: Baggage Door Opening Dimmensions |
I think I understand... Does the attached drawing look about right?
On Mon, May 16, 2011 at 4:01 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
- But then you have to remove a triangle at the lower bottom rear corner that is 7" horizontally and 6" vertically
Hope that helps.
Shannon
http://forums.matronics.com
le, List Admin.
36.56 KB |
6082 Time(s) |
Posted: Mon May 16, 2011 3:12 pm Post subject: Baggage Door Opening Dimmensions |
That's it!
It's a very satisfying piece to assemble because it has a slight compound curve throughout it. Not sure how you would fabricate it without CAD and CNC... at least without n years of sheet metal experience... but it just clecos together and fits perfectly.
On 5/16/2011 5:28 PM, Shannon Hicks wrote: [quote]I think I understand... Does the attached drawing look about right?
Hope that helps.
Shannon
le, List Admin.
Lew Gallagher
Posted: Mon May 16, 2011 6:33 pm Post subject: Baggage Door Opening Dimmensions |
Hey Shannon,
I've made my own cooler/ac for the baggage compartment in the -10. I'll get dimensions of the cooler tomorrow -- it's about a perfect fit.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
rv10flyer(at)verizon.net Guest
Posted: Mon May 16, 2011 7:07 pm Post subject: Baggage Door Opening Dimmensions |
Is the article meant to be arctic air cooler? if so buy it from Lew, on this list, or make it yourself. much less expensive.
I need to get around to making mine one of these days.
Pascal
Sent: Monday, May 16, 2011 12:41 PM
Subject: Baggage Door Opening Dimmensions
Shannon[quote]
civengpe
Posted: Tue May 17, 2011 3:55 am Post subject: Baggage Door Opening Dimmensions |
Yes, it was supposed to be artctic. Auto correct on my phone got me again. I would be happy to buy it from Lew. Does anyone have his phone number?
Shannon On May 16, 2011 10:14 PM, "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:> Is the article meant to be arctic air cooler? if so buy it from Lew, on this list, or make it yourself. much less expensive.
Lew Gallagher
Posted: Tue May 17, 2011 4:11 am Post subject: Re: Baggage Door Opening Dimmensions |
OK Shannon,
The dimensions of the cooler I use are 14X14X24, and it tapers slightly toward the bottom so that it slides in perfectly.
I'll attach the pictures I posted earlier. The cooler is at Walmart now for less than $20. It's the 48 qt. Island Breeze by Igloo.
I've modified the a/c cooler I made for Wes by wiring the fans in series instead of parallel. This cuts the amps down and still puts out a lot of cool air and doesn't use the ice up so fast. The 12v computer fans I use are actually for servers and put out more cfm than any others I've run across.
I think the advantage of this style that I've put together is that it uses the heater core (out of junkyard cars) as a heat exchanger that actually pulls moisture out of the cabin instead of just blowing air over ice.
I haven't gotten around to making the plenum yet that would sit on the console between the seats with directional air vents ... stay tuned!
Later, - Lew
41.87 KB |
6035 Time(s) |
55.26 KB |
6035 Time(s) |
58.6 KB |
6035 Time(s) |
LarryRosen
Posted: Tue May 17, 2011 5:15 am Post subject: Baggage Door Opening Dimmensions |
Here is the earlier post with links to the pictures that Lew posted earlier.
Hey Patrick,
Here are a couple of pictures of the last one I made for the guy that flies a Cessna. He has his accessory outlet on the dash, so I made the in-line switch about two feet from the receptacle, with a total length of about 11 feet so that he can put the cooler in the back. The 4" ducts extend to 8 ft. and they are quick detach.
Thanks for the interest, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=305177#305177
http://forums.matronics.com//files/ac9_medium_194.jpg
http://forums.matronics.com//files/ac8_medium_937.jpg
http://forums.matronics.com//files/ac7_medium_697.jpg
On 5/17/2011 8:11 AM, Lew Gallagher wrote:
OK Shannon,
Later, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=340105#340105
http://forums.matronics.com//files/ac9_medium_100.jpg
http://forums.matronics.com//files/ac8_medium_709.jpg
http://forums.matronics.com//files/ac7_medium_257.jpg
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
