james(at)etravel.org Guest
Posted: Sun May 01, 2011 8:38 am Post subject: EL lighting-wire causing noise |
Gents,
I've bought some EL wire and an inverter, and I was thinking I'd run
two lengths of it to light the panel: one above the panel and one
above the sub-panel.
Yesterday I connected it up to try, and it makes a loud high-pitched
whine on the intercom headphones. I know that EL strips are used in
aircraft, so it's not EL per se that's the issue, which means it's
either wire, or the inverter.
Is there anything I can do practically to stop this, for example
shielding the box with metal or similar? I'll try a few things, but
if anyone has any experience, I'd appreciate any advice going.
Many thanks.
James
Jodel D150 in progress
enginerdy(at)GMAIL.COM Guest
Posted: Sun May 01, 2011 11:50 am Post subject: EL lighting-wire causing noise |
EL is relatively high voltage, so it's a good idea to shield the feed wires between the inverter and EL, and make sure it's not running close to any audio lines.
Can you move any wires around and affect the sound? That might give you a clue of physically where to look for coupling.
--Daniel
On May 1, 2011, at 11:35 AM, James Kilford wrote:
Gents,
Many thanks.
James
Posted: Sun May 01, 2011 12:05 pm Post subject: EL lighting-wire causing noise |
Thanks Daniel. At the moment, the EL wire was all bunched up in the
footwell, a long way from anything except the headphone in use. I
just connected it temporarily to the L tank fuel sender power feed.
I'll try isolating it a bit more and see what I can fathom. My
concern is that it will just naturally radiate too much noise.
James
On 1 May 2011 20:46, Daniel Hooper <enginerdy(at)gmail.com> wrote:
--Daniel
> Gents,
> whine on the intercom headphones. Â I know that EL strips are used in
> shielding the box with metal or similar? Â I'll try a few things, but
> Many thanks.
> James
Posted: Sun May 01, 2011 12:10 pm Post subject: EL lighting-wire causing noise |
At 03:02 PM 5/1/2011, you wrote:
Review chapter on noise in the 'Connection. You need to
identify the mode of propagation. Shielding is most
unlikely to fix the problem. Try running the lights from
an independent 12v source . . . like a pair of cheap
lantern batteries from WallyWorld . . . and see if
the noise goes away.
Eric M. Jones
Posted: Mon May 02, 2011 4:25 am Post subject: Re: EL lighting-wire causing noise |
My philosophy is that changing to an LED strip is the easy way to go. You can fix the EL problems, but does it make sense?
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Mon May 02, 2011 4:39 am Post subject: EL lighting-wire causing noise |
Eric, you might well be right -- I was looking on ebay last night, and
you can buy a reel of SMD LEDs, about 5m overall, for about £20 or
so... Seems like pretty good value to me.
What's the best way to dim them though? I guess they're pretty bright
to start off with.
James
Tim Olson
Posted: Mon May 02, 2011 4:45 am Post subject: EL lighting-wire causing noise |
That's exactly what I did when I had the same issue. Those EL lights
aren't the quietest things. The LED's are quiet though.
Tim Olson - RV-10 N104CD
Eric M. Jones
Posted: Mon May 02, 2011 4:55 am Post subject: Re: EL lighting-wire causing noise |
I didn't mean surface mount leds, but LED ribbons or "flexstrips". Ebay has them as well as Deal Extreme (my favorite).
There is a mistaken idea that LEDs need Pulse-Width-Modulation or Quantum Heisenberg Compensators or some such....all untrue. Dimming them is just a matter of changing the dc voltage to them. Any dimmer, even a resistor, zener or potentiometer will do.
113 Brentwood Drive
(508) 764-2072
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Mon May 02, 2011 6:40 am Post subject: EL lighting-wire causing noise |
Cruising around on E-Bay I've seen dimmers for the led light strips and have always thought I need to get them for the plane. Time will tell
Dick
#606/N20DG
In a message dated 5/2/2011 7:40:02 A.M. Central Daylight Time, james(at)etravel.org writes:
| Quote: | --> AeroElectric-List message posted by: James Kilford <james(at)etravel.org>
to start off with.
James
Posted: Tue May 03, 2011 3:51 am Post subject: EL lighting-wire causing noise |
Yep, absolutely. This is the sort of thing I've seen:
http://cgi.ebay.co.uk/5M-White-SMD-3020-Waterproof-300p-LEDs-Strip-Light-Lamp-/260769350652
James
On 2 May 2011 13:55, Eric M. Jones <emjones(at)charter.net> wrote:
klehman(at)albedo.net Guest
Posted: Wed May 04, 2011 4:41 pm Post subject: EL lighting-wire causing noise |
FWIW my EL lights are powered through the homemade analog dimmer circuit
on the aeroelectric pages and there is no noise evident at any
brightness. I think the circuit used a LM317 regulator.
Ken
On 5/2/2011 8:43 AM, Tim Olson wrote:
> Jones"<emjones(at)charter.net>
> Eric M. Jones
> 113 Brentwood Drive
> (508) 764-2072
Posted: Thu May 05, 2011 6:53 am Post subject: EL lighting-wire causing noise |
Thanks Ken,
I've a couple in the electronics box from when I made some dimmed map
lights. I'll give that a try.
James
On 5 May 2011 01:35, Ken <klehman(at)albedo.net> wrote:
FWIW my EL lights are powered through the homemade analog dimmer circuit on
the aeroelectric pages and there is no noise evident at any brightness. I
Ken
> do not archive
>> Eric M. Jones
>> 113 Brentwood Drive
>> (508) 764-2072
Posted: Thu May 05, 2011 12:26 pm Post subject: EL lighting-wire causing noise |
If it is quiet I can look up the resistor values that I used to adjust
the voltages to something more suitable. I think full dim for my EL
inverter cube was around 5 or 6 volts so I altered the design a bit to
still have full range adjustment on the knob.
Ken
On 5/5/2011 10:50 AM, James Kilford wrote:
Thanks Ken,
James
> Ken
