EL lighting-wire causing noise
james(at)etravel.org
PostPosted: Sun May 01, 2011 8:38 am    Post subject: EL lighting-wire causing noise Reply with quote
Gents,
I've bought some EL wire and an inverter, and I was thinking I'd run
two lengths of it to light the panel: one above the panel and one
above the sub-panel.
Yesterday I connected it up to try, and it makes a loud high-pitched
whine on the intercom headphones. I know that EL strips are used in
aircraft, so it's not EL per se that's the issue, which means it's
either wire, or the inverter.
Is there anything I can do practically to stop this, for example
shielding the box with metal or similar? I'll try a few things, but
if anyone has any experience, I'd appreciate any advice going.
Many thanks.
James
Jodel D150 in progress
enginerdy(at)GMAIL.COM
PostPosted: Sun May 01, 2011 11:50 am    Post subject: EL lighting-wire causing noise Reply with quote
EL is relatively high voltage, so it's a good idea to shield the feed wires between the inverter and EL, and make sure it's not running close to any audio lines.
Can you move any wires around and affect the sound? That might give you a clue of physically where to look for coupling.
--Daniel
On May 1, 2011, at 11:35 AM, James Kilford wrote:
Gents,
Many thanks.
James
PostPosted: Sun May 01, 2011 12:05 pm    Post subject: EL lighting-wire causing noise Reply with quote
Thanks Daniel. At the moment, the EL wire was all bunched up in the
footwell, a long way from anything except the headphone in use. I
just connected it temporarily to the L tank fuel sender power feed.
I'll try isolating it a bit more and see what I can fathom. My
concern is that it will just naturally radiate too much noise.
James
--Daniel
> Gents,
> Many thanks.
> James
PostPosted: Sun May 01, 2011 12:10 pm    Post subject: EL lighting-wire causing noise Reply with quote
Review chapter on noise in the 'Connection. You need to
identify the mode of propagation. Shielding is most
unlikely to fix the problem. Try running the lights from
an independent 12v source . . . like a pair of cheap
lantern batteries from WallyWorld . . . and see if
the noise goes away.
Eric M. Jones
PostPosted: Mon May 02, 2011 4:25 am    Post subject: Re: EL lighting-wire causing noise Reply with quote
My philosophy is that changing to an LED strip is the easy way to go. You can fix the EL problems, but does it make sense?
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Mon May 02, 2011 4:39 am    Post subject: EL lighting-wire causing noise Reply with quote
Eric, you might well be right -- I was looking on ebay last night, and
you can buy a reel of SMD LEDs, about 5m overall, for about £20 or
so... Seems like pretty good value to me.
What's the best way to dim them though? I guess they're pretty bright
to start off with.
James
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=338625#338625
Tim Olson
PostPosted: Mon May 02, 2011 4:45 am    Post subject: EL lighting-wire causing noise Reply with quote
That's exactly what I did when I had the same issue. Those EL lights
aren't the quietest things. The LED's are quiet though.
Tim Olson - RV-10 N104CD
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Eric M. Jones
PostPosted: Mon May 02, 2011 4:55 am    Post subject: Re: EL lighting-wire causing noise Reply with quote
I didn't mean surface mount leds, but LED ribbons or "flexstrips". Ebay has them as well as Deal Extreme (my favorite).
There is a mistaken idea that LEDs need Pulse-Width-Modulation or Quantum Heisenberg Compensators or some such....all untrue. Dimming them is just a matter of changing the dc voltage to them. Any dimmer, even a resistor, zener or potentiometer will do.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
N20DG
PostPosted: Mon May 02, 2011 6:40 am    Post subject: EL lighting-wire causing noise Reply with quote
Cruising around on E-Bay I've seen dimmers for the led light strips and have always thought I need to get them for the plane. Time will tell
Dick
#606/N20DG
In a message dated 5/2/2011 7:40:02 A.M. Central Daylight Time, james(at)etravel.org writes:
--> AeroElectric-List message posted by: James Kilford <james(at)etravel.org>
to start off with.
James
--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
<= Use ilities ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
PostPosted: Tue May 03, 2011 3:51 am    Post subject: EL lighting-wire causing noise Reply with quote
Yep, absolutely. This is the sort of thing I've seen:
http://cgi.ebay.co.uk/5M-White-SMD-3020-Waterproof-300p-LEDs-Strip-Light-Lamp-/260769350652
James
klehman(at)albedo.net
PostPosted: Wed May 04, 2011 4:41 pm    Post subject: EL lighting-wire causing noise Reply with quote
FWIW my EL lights are powered through the homemade analog dimmer circuit
on the aeroelectric pages and there is no noise evident at any
brightness. I think the circuit used a LM317 regulator.
Ken
> Jones"<emjones(at)charter.net>
> Eric M. Jones
> 113 Brentwood Drive
> (508) 764-2072
PostPosted: Thu May 05, 2011 6:53 am    Post subject: EL lighting-wire causing noise Reply with quote
Thanks Ken,
I've a couple in the electronics box from when I made some dimmed map
lights. I'll give that a try.
James
On 5 May 2011 01:35, Ken <klehman(at)albedo.net> wrote:
FWIW my EL lights are powered through the homemade analog dimmer circuit on
the aeroelectric pages and there is no noise evident at any brightness. I
Ken
> do not archive
>> Eric M. Jones
>> 113 Brentwood Drive
>> (508) 764-2072
PostPosted: Thu May 05, 2011 12:26 pm    Post subject: EL lighting-wire causing noise Reply with quote
If it is quiet I can look up the resistor values that I used to adjust
the voltages to something more suitable. I think full dim for my EL
inverter cube was around 5 or 6 volts so I altered the design a bit to
still have full range adjustment on the knob.
Ken
On 5/5/2011 10:50 AM, James Kilford wrote:
Thanks Ken,
James
> Ken
