elleryweld(at)aol.com Guest
Posted: Thu Feb 24, 2011 7:51 pm Post subject: Bad Prop Pics if you have dial up click Delete I have no id |
This is the end of the blade that fits the Hub below
[img]cid:tie_8CDA2B54D1495BE_1C44_CB7C[/img] [img]cid:tie_8CDA2B54D384A6D_1C44_CB7D[/img]a Warp Hub
Ellery Batchelder Jr.
1.32 MB |
1838 Time(s) |
1.62 MB |
1838 Time(s) |
Richard Pike
Posted: Fri Feb 25, 2011 7:14 am Post subject: Re: Bad Prop Pics if you have dial up click Delete I have no |
So far all the pictures you have posted both here and on FB look just like the Warp I had and broke in 1990, both inside and outside.
And I don't care who says what, or what your credentials are, I broke several of them, and back then they did have a blondish-tan foam core.
Richard Pike
MKIII N420P (420ldPoops)
