Bad Prop Pics if you have dial up click Delete I have no id
elleryweld(at)aol.com
PostPosted: Thu Feb 24, 2011 7:51 pm    Post subject: Bad Prop Pics if you have dial up click Delete I have no id Reply with quote
This is the end of the blade that fits the Hub below
[img]cid:tie_8CDA2B54D1495BE_1C44_CB7C[/img] [img]cid:tie_8CDA2B54D384A6D_1C44_CB7D[/img]a Warp Hub
Ellery Batchelder Jr.
 Filesize:  1.32 MB
 Viewed:  1805 Time(s)
 Filesize:  1.62 MB
Richard Pike
PostPosted: Fri Feb 25, 2011 7:14 am    Post subject: Re: Bad Prop Pics if you have dial up click Delete I have no Reply with quote
So far all the pictures you have posted both here and on FB look just like the Warp I had and broke in 1990, both inside and outside.
And I don't care who says what, or what your credentials are, I broke several of them, and back then they did have a blondish-tan foam core.
Richard Pike
MKIII N420P (420ldPoops)
