saolesen(at)sirentel.net Guest
Posted: Sat Feb 12, 2011 11:04 am Post subject: Warning tone |
Hi Bob,
I designed a door-throttle warning system for my RV-10 that was heavily influenced by the Long-EZ canopy-throttle-gear warning system. It has a warning horn that goes off if the throttle is wide open and the door pins are not in the correct position. My problem is my Bose headsets are very good at canceling the horn noise. Is there a simple way to make a device to add an obnoxious tone through the audio panel? A couple of inputs to the device would also take care of the stall warning horn.
Sheldon Olesen
Door-Throttle_Warning_System_2.pdf |
59.81 KB |
126 Time(s) |
