Warning tone
saolesen(at)sirentel.net
PostPosted: Sat Feb 12, 2011 11:04 am    Post subject: Warning tone Reply with quote
Hi Bob,
I designed a door-throttle warning system for my RV-10 that was heavily influenced by the Long-EZ canopy-throttle-gear warning system. It has a warning horn that goes off if the throttle is wide open and the door pins are not in the correct position. My problem is my Bose headsets are very good at canceling the horn noise. Is there a simple way to make a device to add an obnoxious tone through the audio panel? A couple of inputs to the device would also take care of the stall warning horn.
Sheldon Olesen
Door-Throttle_Warning_System_2.pdf
 Filename:  Door-Throttle_Warning_System_2.pdf
 Filesize:  59.81 KB
 Downloaded:  146 Time(s)
