Pete Fowler
Posted: Fri Jan 07, 2011 10:15 am Post subject: Anyone know where I can find a Housai exhaust valve guide? |
I've tried all the usual suspects with no luck.
jlpartington(at)att.net Guest
Posted: Fri Jan 07, 2011 6:44 pm Post subject: Anyone know where I can find a Housai exhaust valve guide? |
doug sapp
To: yak-list(at)matronics.com
Sent: Fri, January 7, 2011 12:15:58 PM
Subject: Anyone know where I can find a Housai exhaust valve guide?
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net (pfdesign1(at)cox.net)>
http://forums.matronics.com/viewtopic.php?p=325920#325920
Harv
Posted: Sat Jan 08, 2011 1:20 pm Post subject: Re: Anyone know where I can find a Housai exhaust valve guid |
Do you have a part number for the valve guide?
I've a contact in China that can pretty much find anything.,
Harv
tjyak50
Posted: Sun Jan 09, 2011 7:27 am Post subject: Re: Anyone know where I can find a Housai exhaust valve guid |
Pete:
If the guide is bad, why not just replace the cylinder. I think that will be a lot easier, faster and probably cheaper in the long run.
Getting the guide in and out (straight) is a trick.
Tj
dougsappllc(at)gmail.com Guest
Posted: Sun Jan 09, 2011 9:03 am Post subject: Anyone know where I can find a Housai exhaust valve guide? |
Guys,I have put out some feelers in China. Should have word back in about 2 weeks.
I do have intake seats and springs in stock as well as a 2 or 3 exhaust valves. At this time used serviceable "as removed" cyls are in stock. By spring we will have overhauled cyls in stock for the 285 hp HS6A engines.
Doug
On Sun, Jan 9, 2011 at 7:27 AM, tjyak50 <tomjohnson(at)cox.net (tomjohnson(at)cox.net)> wrote:
[quote] --> Yak-List message posted by: "tjyak50" <tomjohnson(at)cox.net (tomjohnson(at)cox.net)>
Pete:
Tj
http://forums.matronics.com/viewtopic.php?p=326103#326103
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Nanchang CJ6
Posted: Mon Jan 17, 2011 12:09 am Post subject: Re: Anyone know where I can find a Housai exhaust valve guid |
Is this exhaust vavle you need in picture?
Maybe we can help you.
Sarah
| Pete Fowler wrote: | | I've tried all the usual suspects with no luck. |
21.15 KB |
5940 Time(s) |
_________________ Sarah's E-mail:lcdzkj@live.cn |
